Question about Zenith P42W22B/H 42 in. Plasma Television
Power Supply Dead on Zenith P42W22H - where to order???
My Zenith Plamsa EDTV P42W22H has a dead power supply. Does anyone know how to order one? Is it something I can do myself? The shop said it was going to cost about $650. I don't even know if the TV is worth that much. What about salvage value?
Thanks!
The power supply is easy to change...i have many of the displays. Just remove the back cover...you'll see the power supply it has 2 screws holding it on and a couple wires...I'm not sure where to get a new one... You could try ebay.
Posted on Jan 21, 2010
Oihef [oief eofi a[odif
Posted on Feb 25, 2008
  • 2,323 Answers
Zenith z50pg10 its dead no click, no led blink nothing !
Zenith Flat panel TVs usually only have two boards in them Plasmas have a few more, doing a visual inspection of the power supply capacitors usually reveals swollen or bulging capacitors.
If the capacitors look good, voltage checks would be needed to isolate the problem to either the main board or power supply. Check for 5 volts to the IR board (& or keyboard) , if five volts is present suspect the main board
If this TV has voltages from power supply , suspect the Z, X and buffers
May 26, 2012 | Televison & Video
2 blinks. tv shut off
The power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
Aug 09, 2011 | Panasonic TH-42PD50U 42 in. Plasma EDTV
My zenith 50pc308 plasma wont power up, green light turns on and a little noise but no illumination.
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem,Take care.....
Sep 18, 2010 | Zenith Z50P3 50 in. Plasma TV
Whats wrong with tv?
U know basic electronic's,have tools and know basic soldering?Take the tv aparts.The power supply board,that the board where the power a/c cord plug into it.Searches the power supply board for these dying to be dead capacitors have gases leakages.These capacitors alway bulges up on it tops or puff up on it tops.Replaced these dying to dead capacitors.Or tries websites like shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jul 14, 2010 | Akai PDP4294 42 in. EDTV-Ready Plasma...
I am getting a flashing red light on my plasma 42" viera tv. How do i get the tv to turn back on
Ur tv the power supply board,that the board where the power a/c cord plug into it,have dead parts call capacitors,these capacitors are dead,they useally bulges up it tops or puff up on it tops.U know basic electronic's and soldering.Replaced these dead capacitors,will get ur power stable again and tv will work.Or tries websites like Shopjimmy.com or Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 30, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Zenith 50pc3db troubleshoot green blinking power light no picture
That flashing light is either a failure of the power supply and or one of the drive boards (Y-Sustain, Y-Drives, Z-Sustain) to display the image.
The main board is seeing a problem and that is why the green light is flashing. You may have heard of "POP" sound before your TV started this issue.
Looking through the back cover of your TV and seeing the power supply, if the large capacitors’ tops are swollen or split, then you will know that is a source of your problem(s).
Beyond just looking at the power supply, to correctly trouble shoot your issue would require some TV repair tools and a little knowledge of electronics.
Your Zenith/LG TV was made around 2007.
Let me know if I can help you out any more.
Good Luck.
May 23, 2010 | Televison & Video
Panasonic viera wont come on
The problem is not the power supply, is with the tunner board voltage. change the P.A board fix the problem.
Apr 08, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
TV will not respond. Red power light indicator
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Feb 25, 2010 | Akai LCT2070 20 in. EDTV-Ready LCD...
42 in lg plasma clicks on/off repeatedly when powereing on. Could it maybe the power supply?
Yes,most of the times couple capacitors burst open or puff up it dead,must change these capacitors in the power supply.Must know how to soolders?Or replaced the whole power supply refurbish board.Buy at Shopjimmy.com,Ebay.com.
Jan 14, 2010 | LG MZ-42PZ44 42 in. EDTV-Ready Plasma...
Dead set Electrohome 27E604HD
Q4 IS 20N60C
Q9 IS BC858
Q7 IS BC848
Sep 19, 2009 | ViewSonic N3250W Television
Zenith P42W22B/H 42 in. Plasma Television Logo
303 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
