Question about SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 4gb Restarts over and over
I have a Sansa e260 4gb and I was turning it on.
I pressed some of the buttons (Next, Play/Pause, Previous.....cause I was bored...), while it was starting up and then the screen stayed on its Sansa logo then fades into all white and repeats the Sansa logo and white screen fade.
I tried turning it on and off at first but that didn't work.
When I try to regularly connect it to the computer it still restarts over and over so I can't connect.
I've tried Recovery Mode and it says "USB cable connected Enter USB2.0 MSD mode", then when I try the Remove and Repair options it still doesn't work.
I've also tried disassembling it and taking out the battery for a few minutes and it still does that restarting thing.....WTF?!
help, please.
  • 3 more comments
  • d_h_reaper
    d_h_reaper Feb 17, 2008
    uh?
  • d_h_reaper
    That only goes to Recovery Mode.
    It can only go back to factory defaults if you use the Remove then Repair options on the Sansa Device Recovery Setup.
    And I’ve already tried…..and nothing’s happened.
    Thanks anyway.
  • d_h_reaper
    Hey, do I press the Record and middle buttons while on or off?!
    "Hope this will actually work."
  • Maurice White
    Maurice White Feb 17, 2008
    One day when listening to my SanDisk player it just froze. I waited until the battery died to try and turn it on again. When the battery died I turned it on and saw the Sandisk logo then it faded away and came on again repeating this process. I tried everything removing the battery and all the other restarting tips. Help a sister out cause I really miss listening to my music.
  • d_h_reaper
    Hey, "ivofreax10"!!!!!
    Do I press the recording key and the middle key while the mp3 is ON or OFF?!?!
    Cause I tried both and now I think my battery's dead...
When I had my e260 repeat the turn on sequence I had to reformat the unit and download new software from the help desk at Sansa.
This was the fix that finally did it- had to reformat all my data so it was lost, but unit works fine now.
sprayclosespray extender
Posted on Feb 17, 2008
Okay Mrsmiley I tryed the steps you provided for me and it did say that the device was found but, still just fades away. Any other advice?
  • Maurice White
    Thanx. Now can you walk me through the formatting steps?
  • Maurice White
    Maurice White Feb 18, 2008
    I tried every solution and FINALLY I found one that works. All you have to do is download a firmware updater. You can find it on the Sandisk website or just type it in on any search engine. When its finish downloading just connect your SanDisk player and it will update by itself. And soon you will be listening to the sounds of the Best Rapper Alive Lil Wayne lol.
I dont get u..
do i have to do it at the same time??
when its connected or not?
  • 54 Answers
Easy to fix. simply you have to set is back to factory settings. to do this you have to plug it into your computer, then push the hold button so the orange is showing. next you want to press and hold down the record button, and then press and hold down the power button at the same time. this should reset it back to factory defaults and you should be good to go.
best of luck : )
mrsmiley
Posted on Feb 14, 2008
    Sergeant:
    Champion:
  • 281 Answers
Press the recording key and the middle key of the mp3 for 6 seconds
How do i use the micophone
To start voice recording, follow these steps:
1. Press the Menu button to return to Main Menu.
2. Select Voice
3. Press Play/Pause to start recording.
4. To pause recording, press Play/Pause again
5. To stop recording, press Select. A pop-up window will appear on the screen. Select Yes to
save recording. The recording will be saved in the RECORD/VOICE folder.
6. Press 'button to return to the Voice Menu.
Jun 20, 2011 | SanDisk Sansa Clip MP3 Player
How to turn it on
To turn on the Sansa Shaker™ player, press and hold the Power/Pause/Play button for approximately 2 seconds or until you hear a 'Drum Roll"
May 12, 2010 | SanDisk Sansa c240 MP3 Player
Sansa Clip 8GB is stuck in pause mode
You mean it hangs up at pause mode and you can't turn off you device? if so, push up/press power button and hold for 10 to 20 seconds until the device turn off.
Then, turn on. if it' working. You should update new firmware.
Good luck
Jan 17, 2010 | SanDisk Sansa Clip MP3 Player
Sansa Clip Won't come from pause.
It might be a firmware issue you are having..Try going to the sandisk website to obtain a firmware update for your device..
I hope that helps
Thank you
Mar 04, 2009 | SanDisk Sansa Clip MP3 Player
Sandisk Sansa M240 Screen Busted
Hard w/o screen, here are the steps:
The Sansa Fuze has a built-in microphone allowing you to record your own voice, an
interview, or a speech.
1. Press the Home button to return to Main Menu.
2. Select Voice from the Main Menu.
3. Select Record Now.
4. To pause the recording, select Pause.
5. To stop the recording, select Stop.
6. Select Yes to save the recording.
7. Press the |<< button to return to the previous menu.
Dec 03, 2008 | SanDisk Sansa m240 MP3 Player
Once i turn it on i cant turn it off and when i go to listen to music it just goes and restarts itself
Sounds like it's froze and needs to be reset. -
Press to power on/off, enter menu, or hold 15
seconds to reset your Sansa.
Or-To reset the sansa = Hold down power button for20 seconds.
If that don't work let me know so i can try something Else?
P.S...Please rate accordingly...
Thank you
Computerrep
Feb 09, 2008 | SanDisk Sansa e260 MP3 Player
Dropped MP3 Player/blank screen
Try pressing and holding the power/ menu button while holding down the play/ pause button. Do this till the screen says goodbye or turns off!!
Dec 31, 2007 | SanDisk Sansa e250 MP3 Player
Sandisk m230 mp3 player
make sure the play button is not broken
Dec 26, 2007 | SanDisk Sansa m230 MP3 Player
Sandisk sansa c240 mp3 player voice recording problems
Try the latest firmware upgrade from the Sansa website
Aug 03, 2007 | SanDisk Sansa c240 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
91 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
