Question about Garmin StreetPilot i3 GPS Receiver
Bought StreetPilot III used, can't locate satellites
I bought a used Garmin StreetPilot III, and it cannot locate the satellites. Any help would be appreciated.
  • Anonymous Feb 28, 2008
    can't load usb drivers setup
    just plugged inusb cord and other end to garmin
Buy an external antenna available from garmin
Posted on Feb 20, 2008
You may need an external aerial
Posted on Feb 07, 2008
Are you using it outside or in your car? Mine will not pick up sats fron inside my house.
Yooper-Al
Posted on Jan 30, 2008
Streetpilot III won't power on
The first solution is, of course, to try recharging your Streetpilot III by plugging it in to either your accessory outlet (cigarette lighter) in your car.......or a USB port on your PC. (preferably a USB2 outlet that has a higher power output).
Try charging for at least an hour with the 'other' cord, if the unit won't power up after using the 'first' one.
If the unit STILL won't power up after charging with BOTH cords (for an hour each), then either open the unit and replace the battery, or, sorry....if you're mechanically/electrically challenged......you're best to send your unit in to Garmin for repair, because it could be any number of different problems.
Michael
Feb 01, 2011 | Garmin Streetpilot III GPS Receiver
I used the Garmin Web Updater download to update software on my Garmin StreetPilot C340 GPS and it now indicates that I am in Olathe KS...I am in ND. How do I fix that?
Have you been outside with the unit since the update? Usually when you take the unit outside and turn it on, it reads the satellites and gets it's location from those.
Feb 01, 2010 | Garmin StreetPilot c340 GPS Receiver
Battery replacement now ca't find satellite Garmin c320
More than likely when you reinstalled the gps receiver (the board with the wires connected to it) at the top of the receiver you did not position it properly. If it is not positioned properly it will not receive a satellite signal
May 06, 2009 | Garmin StreetPilot C320 (010-00401-00) GPS...
Can't find satellites
Update the device at the Garmin Web-updater
http://www8.garmin.com/products/webupdater/
This can resolve transient GPS problems.
Failing that update the firmware.
http://www8.garmin.com/support/agree.jsp?id=995
Regards
Richard.
Apr 26, 2009 | Garmin StreetPilot i3 GPS Receiver
Trouble acquiring satellites
Garmin nuvi
will not acquire satellites
Apr 30, 2008 | Garmin StreetPilot C330 GPS Receiver
I have a Garmin GPS unit which is not able to locate a satellite.
I have a Garmin c330 Streetpilot GPS system. It says that it unable to locate a satellite
Mar 09, 2008 | Garmin StreetPilot C330 GPS Receiver
Aquiring satellites
Are you outside with a clear view of the sky? It should find satellites once the unit is turned on. Does it say "Looking for satellites" or "Acquiring satellites"?
If it is "looking for satellites" then it means that the unit have lost all data (time, date, location). If it is "acquiring satellites" then it have date and time, but not location.
Looking for satellites require a longer setup time (could be as much as 15 minutes). Acquiring satellites is much faster (not more than 2 minutes).
Date and time is updated from satellites once the unit gets a satellite lock.
Jan 31, 2008 | Garmin StreetPilot C330 GPS Receiver
Will not pick up satellites
Without more information, it is hard to help. However, when we bought ours, we had trouble getting the unit to locate the satellites. The fix, was to get in the car and drive with it for about 15 to 20 minutes. After about 10 minutes of driving, we kept inputting our home address (we also deleted the home address between inputs). After about 4-6 attempts it finally took and located the satellites. it has worked exceptionally well since then.
Dec 27, 2007 | Garmin StreetPilot c340 GPS Receiver
Showing distance from home when setting favorites
Opdave, turn it on, and go outside and let it see the satellites... My thought, the device has not recognized it is in a new location,,,, else Good Luck GB_C
Aug 28, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot i3 GPS Receiver Logo
189 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
