Question about Xerox DOCUMATE 510 Flatbed Scanner
Line through image
When I use the feeder, each page comes up with a vertical black line all the way down the middle of the document. This does not happen when I just put the document on the flatbed.
    President:
  • 2,072 Answers
There is some contamination on that side of the glass. Look on the side where you feed in the paper in the scanner.
Only takes a smallest of spots on the glass where the lamp parks in the document scanner mode.
Clean that throughly and see if maybe there is something on the bottom of the seal glass. Like i said, it can be a very small very hard to see mark on the glass.
Posted on Jan 31, 2008
Horizontal line on printed page
When you use the flatbed the copy is perfect because the ccd sensor is under the glass cover and obviously is free form dust/ dirt.
On the other hand if you use the feeder the ccd sensor is located in between the roller assembly (not sure exactly for this model).
This means that the page is scanned by the ccd in the feeder, any dirt on the ccd will appear as a black line. I assume that you are feeding papers from the side and not from the top that is why you get a horizontal line.
A quick test to see if the ccd sensor is dirty is to feed the paper from the top side to the feeder. If you get a vertical line it is a proof that your ccd sensor needs to be cleaned.
The worst case is that the sensor in the feeder assembly has a tiny spot that is damaged and it is causing the black line.
So , first try the test, then open the feeder assembly, locate the ccd and clean it. Hope that this helps.
Aug 31, 2016 | Samsung Xpress SL-M2675FN Laser...
Black vertical lines come and go for scans to computer and copies
I suspect the Document Feeder is not aligned properly and light is leaking in. You will need to have a technician in to check the alignment of the scanner to see if it needs to be readjusted. random black lines on edges usually indicate light leaking into the scan area.
Aug 28, 2017 | Xerox WorkCentre 3220
Vertical Black Line
Probably there is nothing wrong with that scanner, just open and clean document feder with alcohol or glass cleaner.
Mar 29, 2013 | Canon PIXMA MX870 Wireless Office...
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
When I scan pages in the computer using the document feeder a black line appears on the scanned pages. what can I do?
Try cleaning the PMT (Photo Multiplier Tube) - the glass tube that picks up the image. If there is a foreign body or dirt on the tube you will see a black line vertically (in the scan direction) on the page.
Apr 12, 2010 | Canon PIXMA MX310 All-In-One Printer
I have a black vertical line running down the middle of my copied pages - is this the same issue as the blade not cleaning the imager? I've blown out the inside & still there. Also, my '10' count...
For the line problem, open the doc feeder on top and clean the scanner glass.
For the number key problem. drip a small amount of WD-40 down into the sticking key.
Mar 10, 2010 | Sharp AL 1631 Copier
HP 4345 Dark Line in Middle of Scanned Image
The correct answer is to clean or replace the mylar sheet on the bottom of the adf
Mar 13, 2009 | HP LaserJet 4345mfp Printer
Full page vertical line appears on copy fed pages.
Open up the document feeder. You will probably find wite-out on the scanner glass.
Dec 12, 2008 | HP Officejet 5510 All-In-One Thermal...
Xerox DOCUMATE 510 Flatbed Scanner Logo
457 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
