Samsung Big Screen
My tv keeps shutting off on its own. Sometimes it will only do it once during the evening and other times it just keeps turning off every few minutes or so. HELP!!
  • 1 more comment
  • cshores Feb 04, 2008
    My Samsung DLPTV's model no. is HLR5067WX/XAA. No version shows. Thanks.
    Thanks. I'll do that when I get home tonight and get back in the a.m.
  • cshores Feb 05, 2008
    Jay,
    The lamp no. is BP9601073A(P) and the color code is orange. There are no unusual sounds when the tv is turned off or on.
    What would the cost of a replacement be, just in case you think that's the cause of the problem?
    Chris
    Sergeant:
  • 261 Answers
First of all what is the model # and date of mfg, and also if there is one... On side of unit.. Version #. It could be fractured solder joints on Power supply board. Let me know if this gets you any closer. See you soon. Jay
Posted on Jan 31, 2008
  • 1 more comment
  • Jay Henderson
    Jay Henderson Feb 04, 2008
    This sounds like a lamp issue and i may actually have on in stock. Check the side of the case where the lamp is and get me the Lamp # It should be something like BP96-1072J (P) and have a color coded sticker which i need as well. If it fell off or something, i can get the info. Not to worry. Talk to you soon. Guru...Jay
  • Jay Henderson
    Also, does the set sound good....No high pitch squeal or anything? If it is it could be a color wheel going bad. Notice when you shut set down or power it up what the colorwheel sounds like. It should spin up to about 6000rpms and just be a faint sound in the background. But not whining. also when it shuts down, it should slow down gradually. If it is doing that it is most likely fine. Cheers. Guru...Jay
  • Jay Henderson
    Jay Henderson Feb 05, 2008
    Probably around 200.00 or so for the lamp...I will check and see if i have one. I used to work in the business, and have about 20 or more here at the house. Thanks...Let me know if you want one.
Why is my Samsung RF26XAERS refrigerator repetitively chiming, and how can I fix it?
NOISE? from the fridge inside? or from the outside compressor? In overstressed compressor or low freon level will make weird noises? a bad fan in freezer will? Even seen bad ice makers make weird noises? if the ice making is hindered by obstructions?
Aug 20, 2014 | Samsung RF26XAERS 26 Cu. ft. French Door...
Our TV keeps shutting it self off intermittenly. Sometimes it will stay on for hours, other times it shuts itself off every few min then will run again for hours. We are selling the TV, but would like to...
My Samsung big screen showed the same symptoms. It ended up being two $5 resisters that burned out a very short time after purchase. My extended warranty took care of it but it took several service calls and the end solution was to replace the entire light engine.
Most of the time heat is the cause for shut down. Check the vents which allow air to circulate thru the set, also be sure the fan is working.
The first thing a repair man will do is replace the bulb. If you can do it yourself you can save some $$.
My advice is to find a good TV guy. One who's been around for a while. Sorry couldn't be more help. Good Luck!
Dec 30, 2010 | Televison & Video
Samsung TV made a big ''POP''
replace the color wheel
Sep 13, 2009 | Televison & Video
I bought a Samsung Omnia about two months ago and have hardly used it but for about two weeks now it just keeps shutting off on it's own even when the battery is fully charged. Sometimes it goes off as...
you need to hard reset it. it will be like factory setting. follow below procedure to hard reset. you will loose personal data on phone memory like contacts,sms,settings, etc.
  1. Press reset pin button ONCE (do not hold)
  2. Once you see the Samsung Omnia appears on the screen, immediately press the SEND and END key simultaneously
  3. Then the screen appears asking you whether you are sure to format
  4. Press SEND to format or END to cancel
Jan 01, 2009 | Cell Phones
TV shuts off
prob  erratic connection  on pc board finding same problem.
Nov 24, 2008 | Samsung HL-P6163W 61" TV
Samsung SCH-u740 problem - front screen stays on and speakerphone switches automatically
I would recommend a hard-reset of the device. Keep in mind that this will delete all of your contact information and customized settings.
On a side note, be careful not to accidentally press the speaker-phone button on the right side of the phone during a call. I used to have this phone and I would sometimes do it without even realizing it.
Apr 24, 2008 | Samsung SCH-u740 Cellular Phone
My smart series magnavox keeps shutting off................
switch-mode power suppy is flaking out.
when it does that its hard on your high voltage circuits so get it fixed or it might turn to a huge bill.
Oct 21, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
227 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
