Question about Fujitsu Siemens LifeBook E4010D Notebook
Port replicator When is doch the laptop in the port replicator it don't take power trough the replicator and stays on battery. When I plug it directly into the laptop it takes power form it. Is my replicator broken or another problem?
  • 1 more comment
  • gertdj350 Jan 30, 2008
    It's an original port replicator.
    Yes the AC adapter doesn't work trough the replicator.
  • gertdj350 Feb 03, 2008
    I checked all connections but everything seems allright. I can borrow another replicator in two weeks and I'll get back to you
  • gertdj350 Feb 06, 2008
    I hacve another replicator and it works again! THX for your help all!
  • 871 Answers
Hi there your Fujitsu Siemens LIFEBOOK E4010D PC Notebook has this problem and what you need to do is try it in another pc or laptop, if it still does that, you may have to replace it.
hope this helps.
fixya!
Posted on Jan 30, 2008
  • earl norman llanera
    earl norman llanera Jan 30, 2008
    your notebook is alright.hence, you need your replicator checked out on another pc or laptop.by this you will know if it need to be replaced or not.
    fixya!
    President:
  • 1,944 Answers
Are you using an original port replicator or a third party one?
  • 4 more comments
  • Damen Wong
    Damen Wong Jan 30, 2008
    Do you mean the AC adapter doesn't work through the replicator?
  • Damen Wong
    Also, check the conections.
  • Damen Wong
    Damen Wong Jan 31, 2008
    Maybe it's loose or there is dust on the connectors.
  • Damen Wong
    Damen Wong Feb 03, 2008
    Any updates?
  • Damen Wong
    Ok, keep us updated.
  • Damen Wong
    Damen Wong Feb 07, 2008
    I am glad it worked out for you =)
    Thanks for usinf FixYa!
Why won't my dell e-port ii replicator charge my latitude e5540?
1. battery is old and can't recharge.
2. Power supply are different, usually two type supported. 3.34/4.62 sometimes it permit to start but don't recharge if battery want exact Voltage.
3. You are using Power Supply for Laptop to E-port, that need 6.7A, so at same it can't recharge correctly your laptop
Jun 05, 2014 | Dell Precision Latitude E-Port Plus Port...
Lenovo usb port replicator problems power surge
You probably have a fried board in the port rep. after a power surge. Fixing it will probably cost you more that getting a replacement. Other option is to find a used one.
Jan 20, 2012 | Lenovo ThinkPad USB Port Replicator with...
Can a Dell Dimension 3000 connect to 5.1 surround sound
If your Laptop has a "Latitude C/Port Advanced Port Replicator" Then this Port Replicator connects Dell Latitude notebooks to peripheral devices such as a monitor, printer, keyboard and mouse. To accomplish this, connect your peripheral devices to the Dell port replicator itself, and leave them connected to it. Then connect your notebook to the port replicator to access the devices without having to attach them individually each time you want to use them. You can also set up speakers on the Dell Latitude C/Port port replicator to provide improved quality audio.
Follow following steps:
1) Place your Dell Latitude notebook in your C/Port Advanced Port Replicator and turn on the notebook using the power button.
  • 2) Place the speakers you want to connect to the port replicator on either side of the port replicator according to the Left and Right (L and R) labels on the speakers.
  • 3) Plug the audio line connector from the speakers into the audio line out plug on the port replicator. The audio line out plus is on the right-hand side of the port replicator base next to the infrared port, directly opposite the notebook ejection lever.
  • 4) Plug the power cable from the speakers into a power outlet if needed. Battery-powered speakers will not require this. Turn on the speakers following the manufacturer's instructions.
  • 5) Open your preferred music or audio software (such as Windows Media Player or iTunes) on your Dell Latitude notebook and play an audio file to hear the newly-attached speakers.
  • Dec 01, 2011 | Dell Dimension 3000 PC Desktop
    My laptop is installed in my port replicator; I also have a Dell monitor plugged in to the port replicator. For some reason, after having to re-boot my computer, the output is appearing on my laptop screen...
    Press Fn+F10 to toggle the display back and forth on the laptop screen and external monitor. Pressing the keys a third time would close the display on both displays. Thanks, Abhishek.
    Mar 09, 2010 | Toshiba Advanced Port Replicator III...
    Cant comp to work,it's plugged in and when you go
    Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
    Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
    Old software need new for 7570 on my laptop with vista.
    try a site called utorrent, they have everything and its free, its really easy it sets itself up automatically than you can download anything. try it out.
    Aug 07, 2009 | PfaFF Creative 7570
    External monitor issues with Toshiba Advanced Port Replicator III
    DebitGuy
    I have the exact same problem with a Tecra Laptop and a ViewSonic monitor - Did you manage to resolve this at all?
    Thanks in advance
    Stu
    Jan 08, 2009 | Toshiba Advanced Port Replicator III...
    Dell 8100 ethernet will not connect off the port replicator
    Let me give it a try ...
    There are a few possibilities but i'll cover 2 of them :
    1. There is a program that comes with your DELL that will save battery life by turning off your Network Card (LAN) I forgot what is the program name. But usually when you plug the power cable out, there will be notification at bottom right corner of your screen that told you so.
    2. I don't know if your port replicator connected to power adapter (is port replicator = docking ?). The fact that your LAN connected when it's on port replicator make my first conclusion more acceptable. Since port replicator got it's own power adapter, it will just turn the LAN on.
    Now if you want to check if thats the cause, just plug your notebook to it's power adapter/charger and plug your LAN Cable in. If it works than the problem is the nasty program from DELL.
    If you want to disable the program just go to Startup Tab at msconfig and disable (clear the check mark) for that nasty program
    Hope it helps
    Oct 28, 2008 | Dell Inspiron 8100 Notebook
    VAIO VGN-S460
    check adapter output also may be problem with dc socket on laptop loose or somthing.
    Apr 11, 2007 | Sony VAIO VGN-S460 Notebook
    Fujitsu Siemens LifeBook E4010D Notebook Logo
    364 people viewed this question
    Top Fujitsu Siemens Computers & Internet Experts
    Alun Cox
    Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
