Question about Epson Stylus C66 Inkjet Printer
Epson c66 ink and paper lights flashing alternately - nothing else happens.
  • Anonymous Apr 19, 2009
    Lights falsh alternately but printer is dead
  • 63 Answers
Turn the printer off. Open up the cover and check for any obstructions inside the printer. Double check if the ink cartridges are properly plugged in and the tray cover is closed. Turn the printer back on. If you still see the error message, it means that you are having a hardware issue. Then try to contact Epson Technical Support.
United States
Phone Number: (562)276-7525
Hours: Mon.- Fri. 6AM-8PM (PT)
Sat. 7AM-4PM (PT)
Canada
Phone Number: (905)709-2567
Hours: Mon.- Fri. 6AM-6PM (PT)
Posted on Feb 07, 2008
Ink light and paper light flash alternatively, printer does not work
Hi - According to the Epson manual that error indicates that paper may be blocking movement of the print head.
Turn off the printer, then open the cover and remove any jammed paper or foreign objects. Turn the printer on. If the lights continue to flash you're most likely going to need a dealer service.
Hope it's the paper.
Good Luck, Mikeywaf
Feb 28, 2011 | Epson Stylus C66 Inkjet Printer
Ink light and paper out light flash alternatively, printer will not work
clean the catrige, the page sensor, paper pick up roller, and tonner.
Epson Stylus C66 PRINTER KEEPS ON FLASHING RED LIGHTS ON THE INK BUTTON AND PAPER BUTTON
Check the status monitor on the PC, this will tell you the error. If service error it need the wast ink pad counter resetting
Mar 13, 2010 | Epson Stylus R265 InkJet Photo Printer
Flashing ink and paper lights
Bend a strong wire a hook it out of the left side until your are able to tough it with your hand. Then push towards the right where it should be parked. Good luck.
Jan 10, 2010 | Epson Stylus C66 Photo InkJet Printer
I recently replaced an ink cartridge on my Epson stylus C66 and now the ink light and paper light are flashing on and off in turn and I can't get the printer to work. Do you know if there's an easy way to...
yes, this means that the ink waste counter is already in its peak and you need to reset it. try to download the inkpad reset utility through your computer. you will know all of the details from there on once you read them.
it would be www.epson.com/ipr
Sep 23, 2009 | Epson Stylus C66 Inkjet Printer
Hi, epson c66 has 2 red lights on. no paper stuck and cant move the cartridges to change. any idea
hi dude
your printer's ink waste pads are full and the counter needs resetting Try this site and software
It allows resetting of the counters, and gives much more control over cleans etc. (Also will allow cleaning when the red Ink light is flashing)
Aug 10, 2009 | Epson Stylus C66 Inkjet Printer
My Stylus C66 won't work.
You have to replace all ink cartridges, it is somekind selling trick. I have epson printer too and it wont work if you replace just one ink, and i have 6 ink cartridges :D
Jul 06, 2009 | Epson CX8400 All-In-One InkJet Printer
Epson C66 red light stays on for ink
The first time you install ink cartridges, the printer must charge its print head for about 90 seconds. Wait until charging finishes (the green power.jpg power light stops flashing) before you turn off the printer, or
it may charge improperly and use excess ink the next time you turn it on. If the printer stops moving or making noise, but the green power.jpg power light is still flashing after 5 minutes, turn off the printer. If the light is still flashing when you turn it back on, contact Epson.
Turn off the printer, then make sure the ink cartridges are inserted completely and the ink cartridge cover is closed completely. Also make sure no packing material remains in the printer. Wait a moment, then turn the printer back on to clear the error.
Nov 13, 2008 | Epson Stylus C66 Photo InkJet Printer
Epsom stylus C66 inkjet printer
Hi
This problem is probably caused by a blockage in the ink waste pads. Over time, particularly with increased nozzle cleans the pads get saturated. These can be replaced by an Epson Engineer at a cost of about £30-£40 but probably more effective to buy a new printer. This usually happens when the printer is between 2-5 years old.
Hope this helps
Sarah
Oct 10, 2008 | Epson Stylus C66 Inkjet Printer
Epson Stylus C66 Inkjet Printer Logo
260 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
