Question about Toshiba DR4 DVD Recorder
D-VR4XSU Freezes Any time I try to turn on my recorder it just freezes and won't let you do anything. I can't even turn it back off without unplugging the thing.
  • kphillip Jan 30, 2008
    Please Help
  • Anonymous Mar 09, 2008
    Same problem. Have it fixed by a techncian twice already. He actually didn't know how it happened or how it worked again. The third time I brought it there, it worked at the store. Now, it wouldn't read any DVD with a message of invalid disc showing.
I've had mine for about a year and a half...biggest piece of **** I've ever had...and I told QVC about it. Never again anything with "Toshiba" on it.
Posted on Mar 28, 2008
My recorded tv freezes when trying to watch them
The whole thing freezes? As in the mouse or keyboard won't even work?
If it's just the video that freezes and you can shut it off, most likely it's a codec issue. Which is dumb since everything you're using came packaged together in the unit. Installing a third party codec pack would solve this issue.
Though, if you're whole PC is freezing when you try to play a video then I have a few other questions to ask you to narrow the potential problems down:
1. Open up the player that opens automatically when you try to watch something, but don't load a video into it. Did everything still freeze?
2. If not, then open a video file that is not something you recorded from TV, like a DVD or a video clip from the net. Did it freeze then?
3. When it freezes, does it freeze instantly? Or does it run for a little bit then freeze. If the latter is the case, what happens in the time between opening the file and the lock down?
Mar 06, 2014 | Acer Aspire All-in-One Desktop PC - Silver...
Mine records and then stops after about 2 minutes
I had to modify the resolution and framerate settings to a lower level to make mine work reliably using 4 cameras. Otherwise mine would do the same thing as you have described. Once I lowered these it has worked but still locks up recording on occasion. I check it as least once a week to make sure it's still recording. When it locks up, the video remains, but the time freezes and the recording stops even though the recording light remains on.
Aug 14, 2009 | Samsung 4 Channel Dvr
Wii Freeze Up
Sounds like you need a soft or hard reset.
try unplugging the console from the mains for 5-10 minutes, then try turning on re-booting. remove any memory cards et,c. when you startup.
Mike @ Compurepair.
May 30, 2009 | Nintendo Wii Console
DMR EZ47V freezes occasionally, will not play certain discs
i hope ,too.if its only months since you bought that ,avail of the warranty package that comes with it.
May 27, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
My PC auto matically restart when turning it on
The beep you hear is your BIOS trying to alert you to an error in the POST (power on self test) routine. Without knowing the manufacturer of your motherboard one can't be certain what the beeps indicate...see this link for more info: http://www.5starsupport.com/info/beep_codes.htm
It's possible you have some kind of infestation, and it's possible there's something more systemic, but without knowing the make and model of your system I couldn't say.
Sometimes three beeps indicates a keyboard error...you could try another keyboard or unplug yours and see if it will boot up "normally" without it.
Otherwise, report back with some more info and we'll take it from there.
Mar 28, 2009 | Microsoft Windows XP Home Edition
Dvb t vcr/dvd recorder drvt 43 freezes after being plugged in
I have the same problem. Telephoned Daewoo and they said that there was a download available that will fix it. Unfortunately, the contol keeps freezing so I can't do this. Therefore, I have contacted the retail supplier and they are sending a replacement and also letting me have relevant info to send the defect one back. Hope this helps.
Jan 25, 2009 | Daewoo DVRS04 DVD Recorder/VCR
Panasonic DMR-EZ28 and DMR EZ27 both freeze up every other day.
I have the panasonic DMR EZ 28 for 4 months. I have beendownloading home videos from my camcorder through the IN 2 port without difficulty until yesterday; Now, when I attach my camcorder through the IN 2 port, I can hear the video, BUT not see by video on the TV monitor; I reconnected the camcorder through the IN 1 port in the back of the DMR and it works, but it's a pain to be working in the back of the machine. Why aren't I seeing the video (but hearing it) when connecting to the IN2. Faulty connection??? Did I program something wrong???
Dec 13, 2008 | Panasonic DMR-EZ28K DVD Recorder
Edirol R-09 Recorder Controls Frozen
This is a PARTIAL solution...
I've found that if I partially remove the SD-Card, then push the power button, it then starts and continues (without freezing) to show the meters and shows "no-card", then I push the SD-Card fully and it then shows "Loading"...
From there, it can be operated. But if I try to power-up with the SD-Card installed, it freezes and ceases to obey any buttons; which requires to remove the batteries to turn it off.
Please be aware that removing OR installing the SD-Card with power-on is NOT recommended, BUT is THE ONLY way my R-09HR now can be operated. I'm contacting the factory to solve this, but in the mean time, I had to record a live concert that I had promised to get recorded, so I tryed everithing and discovered the reinstallation of the SD-Card as the only thing that allowed me to get that concert.
The SD-Card that I bought for my R09HR is a Kingston 16GB. good luck, give it a try.
Sincerely, amclaussen at amarquez@imp.mx
Sep 09, 2008 | Edirol R-09 Digital Voice Recorder
Toshiba RD-KX50 HDMI freezes the recorder.
Press the standby button for about 10 seconds and will reset the HDD you may lose what you have on the HDD but will fix it.
May 07, 2008 | Toshiba RD-KX50 DVD Recorder/HDD Recorder
VHS to DVD - D-VR4XSU
have u tried the seting on the vcr, you know how u can change the lenght of recording on the vhs
Mar 29, 2008 | Philips Magnavox DVD/VCR Dual Player
Toshiba DR4 DVD Recorder Logo
99 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
