Question about Haier HPAC99ER Air Conditioner
Not cooling We have a haier hpac99er portable a/c. The unit has bee working fine and did very well over the summer. However, it is not bringing the temperature down now. The air is cool that is blowing out but the room temp is remaining 78-79 although we have it set on 70. The filter is not dirty.Ideas?
  • 86 Answers
1. check doors,windows,of room
2.if there is leakage freash air came in.so temparature can not maintend
Posted on Mar 17, 2008
1 month old Haier 12000BTU Portable Unit LEAKS like mad!
If it has an evaporation pan to "Cook Off" the moisture, it would be putting it back into the air, where it just removed it from. This will, in time cool the room but the humidity is being returned. It is possible however, that drain from the condensor to the collector is clogged, causing it to overflow. If you still have it, install the window exhaust kit that came with the unit. This will help eliminate the humidity from the room and the moisture from the unit.
As for the mols problem, Use a sprayer of choice, depending on how much area you need to spray. Mix unscented CHLORINE bleach with water, 1/2 cup bleach to 1qt water. Spray until surface is wet but it doesn't have to run down the walls, unless you need to treat them too. The chlorine bleach will kill any mold & fungus spores that it contacts. Unscented is a lot easier to live with. The regular smells like a swimming pool for a few days.
Aug 28, 2009 | Haier HPAC99ER Air Conditioner
I have HAIER HPAC 99ER Portable air conditioner and just quit working. There is a red flashing light blinking.
Make sure your filter & the coils (area under the filter) are clean or that the evaporated water is not overfilled by draining it manually by pulling the plug on the lower rear of the unit (into a bucket of course.) I'm hoping you had gotten an answer sooner...
Jul 19, 2009 | Haier HPAC99ER Air Conditioner
Lost manual
Hello, I found two user's manuals available from Haier. Neither is specifically for the HPAC90ER, but in my experience sometimes there is one manual for several different products so it's worth checking out. I hope this helps you!
- CBR2009 Here's the link to the PDF user's manual for the HPAC90E
http://www.haieramerica.com/en/asset/archived/HPAC90E.pdf
Here's the link to the PDF user's manual for the HPAC99ER
http://www.haieramerica.com/en/asset/archived/HPAC99ER.pdf
Jun 23, 2009 | Haier HPAC90ER Air Conditioner
Room temperature reads 95-99 degrees F, not cooling the room
one hose is the heated condensing air and one hose is the intake air. if this unit is not working correctly and u just purchased it take it back. if the landlord will replace it tell them. do not call a service tech to check this unit out if u know 4 sure the temp is set right and it continues to blow hot and the exhaust hose blows outside and the unit is set to cool you are money ahead to replace it. hopefully a landlord or recent purchase can bail you, you can find these units at home depot lowes and get them 4 about 400 dollars. hopefully it's covered somehow by warranty or landlord but the cost for checkout and service will exceed the cost for replacement. have you tried to unplug the unit leave it unplugged and try again. have u cleaned the filter. have you noticed ice anywhere. maybe a light that tells you the drain is plugged i don't wan't to get you're hopes down when you are burning up but check these things and let me know if u see any abnormalities. do you leave the unit running in hopes that you will come home and it works? check for ice is there air blowing constantly? if u dont get air flow you could have a fan thats out or its iced up. let me know.
May 25, 2009 | Haier HPAC99ER Air Conditioner
Haier HPRD12xc5 triangle with ! light is on and it keeps shutting off
I think this a fault with the cooling compressor.
When it cuts out aggain, turn off and unplug. See if the compressor is hot to the touch. If it is, I think it's tripping the overload protector. This is usually due to a faulty capacitor.
If you are unable to check the unit, take it to a service centre, or call an engineer to check and replace the defective components.
Hope this enables you to resolve the problem. If it does, please rate this as Fixya, or contact me again for further help.
Would you like the number of a local engineer? If so please supply your Zip code and I will contact one for you.
Jun 08, 2008 | Haier HPAC99ER Air Conditioner
9000btu Haier portable air conditioner HPAC99ER doesnt blow cold air. What do I need to do?
I own the Haier 9,000-BTU Portable Air Conditioner - White. This is the second day that my unit has blow out air that smells really bad. I went to check my unit to find that there was a leak of some sort of chemical that smells like what is blowing from my unit. What should I do?
Jun 06, 2008 | Haier Heating & Cooling
Remote is not working anymore...how to control temp??
I bought the 9,000 btu and the remote stopped working the second time I used it. I returned it and bought the 7,000 btu and the exact same thing happened; it died the second time I used it. The only thing I noticed, not sure why, but if I take the batteries out of the remote for a while and put them back in, it works. Not being able to control it without the remote is definitely a design flaw.
May 14, 2008 | Haier HPAC99ER Air Conditioner
Haier HPAC99ER Air Conditioner Logo
307 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Michelle Balcom
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
