Usb ports not picking up memory stick
Sent my computer in for work it came back with defective usb ports according to the emachines tech support
  • 1 more comment
  • Anonymous Feb 10, 2008
    When installing a USB flash stick into either the front or back ports then a new USB device is recognised but not as a flash drive. Instead of then using standard XP drives which are use with this device on other XP machines, it tries to install ned drivers, but fails to find any suitable. This is the same on all ports and also any USB flash device.
  • lladanrc28 Mar 18, 2008
    • I know that they use to work! Now they don't ! How do I reset them on my system!
  • Anonymous Apr 09, 2009
    I have the same problem and it would seem that the updated BIOS, A03, do not address the front USB ports. The old one did, it's in the manual for this unit in the BIOS section. One would think that going back to A02 would solve this?
  • 43 Answers
Is it just Memory Stick, or everything that you plug into USB?
Try following:
  1. plug in other USB device into ports
  2. if it does not detect any USB device on any port on your computer
  3. if both front and back USB do not work it may be taht USB is turned off in BIOS, or USB driver is corupted
  4. If you have front USBs and they just do not work there is wire connecting them to the motherboard since it may be loose, if connection is OK than they are dead.
  5. If just back USB do not work than they are dead>
Posted on Jan 30, 2008
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • 24 Answers
Follow the steps in our tutorial to resolve your issues with the detection of your usb flash drive.
Posted on Oct 24, 2014
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
EMachines 270 rebooting whenever new USB inserted
sounds like you have a short circuit try a diffferant usb port or a usb extension
Feb 11, 2012 | eMachines Computers & Internet
I have an emachine T5026. Emachine tech swears this machine only supports pc2700 ram but the stickers on the factory installed ram says pc3200 256mb x 2 so i bought 2 memory masters pc3200 1gb x 2 sticks....
PC3200 is backwards compatible with PC2700. Meaning you can install PC3200 into your motherboard but it won't run any faster than would PC2700, however it will not cause any harm and should work fine.
Emachine's would say you need PC2700 most likely because they're trying to sell you some.
One of your new memory modules or the memory slots on your computer may be defective. I recommend installing a single stick of memory and booting your system. If it is successful then shut it down, disconnect the power and install another stick. Boot again and keep doing so and by process of elimination identify the bad memory stick or the bad memory slot.
This is the "likely" cause and isn't too uncommon.
Good luck.
Sep 07, 2010 | E-Machines eMachines Desktop PC
I recently had my windowsxp, up dated. my computer is an emachine my external floppy drive is know not recognized by computer now i have tried finding a driver but i am having no luck. I think my driver is...
Try connecting the external device to another computer, to see if can be detected on that computer. If not, then the device itself has a problem.
Otherwise, try connecting your device to a different USB port on your computer.
Also, try some other USB device (camera, memory-stick) in each of your computer's USB ports, to confirm that the USB ports themselves are working.
Aug 22, 2010 | Dynex DX-EF101 (DXEF101) External Floppy...
No telephone service
Hi, I checked the specs for this pc and it only has a Ethernet port. See specs below.
Specifications CPU1 : AMD Athlon™ II X2 dual-core processor 235e
(2.7GHz, 2MB L2 cache) Operating System2 : Genuine Windows® 7 Home Premium 64-bit Chipset : NVIDIA® GeForce® 6150 SE Memory3 : 6144MB DDR2 dual-channel (2 × 1024MB + 2 × 2048MB)
Expandable to 8GB
4 DDR2 slots (total), 0 DDR2 slot (available) Hard Drive4 : 750GB 7200rpm SATA Optical Drive : 16x DVD±R/RW Supermulti drive
Write max: 16x DVD±R, 6x DVD-RW, 8x DVD+RW, 8x DVD±R DL, 5x DVD-RAM, 48x CD-R, 32x CD-RW
Read max: 16x DVD-ROM, 40x CD-ROM Media Reader5 : Multi-in-one digital media card reader
CompactFlash® I & II, CF+ Microdrive, Secure Digital™ (SD) Card, miniSD™ Card, MultiMediaCard™ (MMC), MMCmobile™, MMCmicro™, Reduced-Size MultiMediaCard™ (RS-MMC), xD-Picture Card™, Memory Stick®, Memory Stick PRO™, Memory Stick Duo™, Memory Stick PRO Duo™, Memory Stick Micro™ Video : Integrated NVIDIA® GeForce® 6150 SE graphics Audio : 8-channel (7.1) high-definition audio
USB Speakers Communications : 10/100 Ethernet LAN (RJ-45 port) Peripherals : eMachines® PS/2 keyboard and optical mouse Ports/Other : 6 - USB 2.0 (2 front, 4 rear)
2 - PS/2 (keyboard and mouse)
1 - VGA
6 - Audio jacks
1 - Headphone jack
1 - Microphone jack
1 - RJ-45 Ethernet Dimensions : 14.2" H x 7.1" W x 16.2" D Weight : 18 lbs. (system unit only) Warranty6 : 1-year parts and labor limited warranty with toll-free tech support Software :
  • Genuine Windows® 7 Home Premium 64-bit
  • Adobe® Flash® Player
  • Adobe® Reader®
  • eMachines® Recovery Management
  • Google Toolbar™
  • Microsoft Office Home and Student 2007 (60-day complimentary trial period)7
  • Microsoft Works® 9.0
  • Nero® 9 Essentials
  • Norton Internet Security™ 20098
  • WildTangent® demo games
http://www.emachines.com/products/products.html?prod=ET1331G-03w
Here's a quick and easy solution to their problem buy a usb external 56k dial up modem.
721f40f.jpgHere's the link to buy it.
http://www.google.com/products/catalog?sourceid=navclient&rlz=1T4ADFA_enUS363US363&q=external+modem+for+dial+up&um=1&ie=UTF-8&cid=5167627218834893159&ei=RPRnS8-JFIrEsQOC8OT3BA&sa=X&oi=product_catalog_result&ct=result&resnum=3&ved=0CCYQ8wIwAg#ps-sellers
Let me know how it went.
WBTech
Feb 02, 2010 | Computers & Internet
What are the slots on the front panel used for?
Those are card reader slots.
Various types of memory cards can be used.
A memory card, (Or can be stated as Flash Memory Card), takes the place of the old Floppy Disks, for one.
It is digital. There is no disk inside, just hardware electronic components.
Due to the size of trying to explain every type of memory card that is available, and the memory card itself, I would like to give you this link,
http://en.wikipedia.org/wiki/Memory_card
Here it explains the basic format of a memory card.
You can click on the titles of the memory card/s, (in blue), to get a deeper explanation, of that particular memory card.
The specifications for your eMachines ET1810 Desktop PC, state that you have the following card reader slots for,
1.Compact Flash (Type I and II)
2.CF Microdrive
3.MultiMedia Card (MMC)
4.MMCmobile
5.MMCmicro
6.Reduced-Size MultiMedia Card (RS-MMC)
7.Secure Digital Card (SD)
8.miniSD Card
9.xD-Picture Card
10.Memory Stick
11.Memory Stick PRO
12.Memory Stick PRO Duo
13.Memory Stick Micro (M2)
Look above each slot for an abbreviation.
For example on my computer,
I have one card reader slot that is approximately 1 inch wide.
It looks like a T that is stretched out.
It has SD/MMC/SM/MS/MS-PRO, above it.
This means that the card reader slot will support, (Use),
[In order as printed above],
1.SD Card - Secure Digital Card
2.MultiMedia Card.
3.Smart Media card
4.Memory Stick
5.Memory Stick Pro
I have one more card reader slot. It has CF-Microdrive above it. A wider slot than the above, and looks like a upside down stretched out T.
This means of course that it uses, (Supports), a Compact Flash Microdrive card
I've tried to explain the various card reader slots, on your computer's front panel, without being too technical, or being offensive in nature.
If you want, I can explain as technical as you wish, or simplify my solution more.
This is the Specifications page for your eMachines ET1810,
http://support.gateway.com/emachines/desktop/2009/emachines/et/et1810/ET1810sp2.shtml
Scroll down, and look to the right of the heading - Card Reader.
These are the cards your computer supports, (Uses)
Looking at the main support page for your eMachines, it looks as though you have four card reader slots.
Three grouped together on the left side, and two in the middle.
The two slots to the far right are USB ports, with probably a headphone jack port, and a microphone port to the right of them.
This page gives a little more detail, as to what your card reader slots support,
http://support.gateway.com/emachines/desktop/2009/emachines/et/et1810/ET1810fv.shtml
Dec 24, 2009 | eMachines ET1810-01 PC Desktop
Does my w3507 have an agp port
No it does not have an agp port. IT has a PCI Express Port for video cards. Its much better and faster.
Details on your machine and what it has can be found at this link. Hope it helps.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2912877&CatId=2643
Nov 10, 2009 | eMachines W3507 PC Desktop
Card reader not working
Try putting your memory stick on a usb port on the back of the cpu. It may work. Usb ports on the front of the cpu and card reader may not work with all memory sticks
Dec 17, 2008 | E-Machines eMachines Desktop PC
PSP
as long as you have connected the usb lead and tried in different ports, make sure you are selecting USB Connection in the settings menu on the psp, it should then connect, but some older pc's may not have enough voltage sent to the usb ports to read the psp, if this is so you will need to buy a powered usb hub.
Aug 07, 2007 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
1,961 people viewed this question
David Payne
David Payne
