Question about Magellan Maestro 4040 GPS Receiver
Maestro 3100 has wrong strating point
Often when I turn on my unit, it thinks I am at the last location it took me to, which could be several days ago. I type in a new destination, but it is starting me from a weird location, not where I really am. Turning it off and then on doesn't seem to work, and I usually have strong satellite signal and power. Sometimes if I drive for a while it will regain its correct location and recalc the route.
    New Friend:
  • 24 Answers
I can understand the problem in the unit so to over come this problem you have to reset the unit .When you reset the unit surely the unit will show your current location address and also it will not recalc the route.
Follow the steps to reset the unit :
On the left hand side at the lower bottom coner you can see a small pin hole there named as reset .Just insert a paper clip in to the hole when the unit is on.this is the way to reset the unit......
Posted on Feb 03, 2008
Hi My Magellan Maestro powers up with the Magellan screen and the bar scrolls but thats all it does? Carl Lucas Aberdeen MD
i just replied to a fellow with the same problem and since your problem is same, ill post what i wrote him/her but try a hard reset 1st..turn the gps on then locate the little pin hole on the side, using a paper clip, push reset....if that fails, try the 2.18 update if you havent already.
updates for any magellan can be found HERE
but read below first before getting the update
i cant stress enough that patients is a must here. this update is huge 1.75GB
follow the instructions below whether you have updated your gps already or not!
There are few ways to solve this problem. i assume you installed the 2.18 update for the 3100 and assuming you tried the reset already, try and run the update again and follow the directions to the letter..make sure the battery is fully charged (i also keep mine plugged in if the update doesnt say not to) and do not try and run the update across a network. this update is huge 1.75GB and can take an hour or so depending on the computer..do not interrupt the update process. if you do not have the 2.18 update read me file, i can try and post it here, but its in PDF and dont think i can post that
if all else fails, magellan will fix or replace for free any of there gps that were rendered inoperable due to one of there updates.
either solution will work but magellans going to tell you to run the update again anyway before sending it back.
i gave you the 2 easyest ways to fix it,but
there are other ways to get it running again, but if your not comfortable copying and moving files...youll make it even worst then it is.
hope this helps.
bill
Comments: Jul 19, 2009 - here are a few key points, but read the full update guide before trying the update again.
hope this helps
NOTE: This update is COMPATIBLE ONLY with Windows® XP.
Before Beginning:
Check to make sure you have everything required for updating your unit:
• Magellan Maestro 3100 GPS
• PC running Windows XP
• A Blank SD memory card (16 MB to 2GB)
• USB cable
• Paper clip or similar object (for resetting your unit)
EACH OF THE FOLLOWING POINTS IS CRITICAL TO THE UPDATE PROCESS
1) The battery of your Maestro 3100 must be fully charged before beginning the update.
NOTE: It takes between 3 and 4 hours to fully charge the battery with your vehicle power adapter. Check System Settings to ensure the battery is fully charged.
2) Your Address Book will be erased during the process. Please back up your data to an SD memory card.
a. Insert a blank SD memory card
b. Select User Options
c. Select Backup and Restore
d. Select Yes to confirm
3) Do not connect your Maestro 3100 to your PC until instructed to do so by the Update Wizard.
4) Close all other applications while performing the update.
5) Disconnect all Pocket PC devices from the USB ports on your PC.
6) Insert a blank SD card (16 MB to 2GB) into your Maestro 3100.
7) Perform a hard reset on your Maestro 3100 by pressing a paper clip or similar object into the hole marked reset.
Update Process:
1) Launch the Magellan_Maestro_3100_2_18.exe file.
2) Select Next on the Welcome screen.
3) Turn on your Magellan Maestro and connect the USB cable.
Aug 03, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Mine isnt telling me where to turn at all
make sure the gps in not muted. check the mute on and the sound turned up on the map screen and also check the sound in the options/system/ sound, if they are both ok and the try a hard reset 1st..turn the gps on then locate the little pin hole on the side, using a paper clip, push reset....if that fails, try the 2.18 update if you havent already. READ UPDATE INFO BEFORE UPDATING,VERY IMPORTANT
i cant stress enough that patients is a must here. this update is huge 1.75GB takes atleast 30 - 60 minutes depending on your system.
hope this helps.
bill
hope this helps
Before Beginning:
• USB cable
Update Process:
Jul 30, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 frozen on blue screen tried power on and off and reset button still frozen black bar at bottom of scren stays on blue screen
hope this helps.
bill
hope this helps
Before Beginning:
• USB cable
Update Process:
Jul 14, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
My magellan 3100 won't charge
you cant charge a 3100 with the USB connection. most likely the power port is damaged and needs replaced. i repair those magellan gps if you need help. if i cant fix it there is no charge. wmetz@comcast.net
Mar 26, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Touch Screen
You probably just need to reset it.
Magellan Maestro models- the location of reset button is on the left, right, or bottom side inside a small hole. Use an object to apply pressure to depress the reset button. Also try holding the power button down for up to 10 seconds to power the unit off and again holding the power button down for up to 10 seconds to power the unit on.
You may need to update your firmware. Go to this site
http://www.magellangps.com/support/
select your product family, model, and then press the submit button. Firmware updates are located in the updates/upgrade section.
This should solve the problem. Good luck. If this helps, plz rate it fixa. Thank you kindly.
Feb 07, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 turns itself off
Try using the RESET button . Make sure the battery is holding its charge
Jan 20, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 failed update
go to Tech support at www.magellamgps.com tell them what has transpired and ask for 2.18 Update Recovery Files. This fixed my problem. Took a few email exchanges but I thought the responses were very quick.
Oct 04, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Stuck on wrong current location
hi,
No need to worry about that this problem arise when the unit is not piciking up the signal.In that situation what you can do is ,you can do a small reset to your unit . In the left hand side bottom corner you can see a small pin hole named as reset
.What you have to do is turn on the unit and insert a paper clip in the reset hole and gently push it inside.So the unit will be reseted surely 100% it will show your location.....
Feb 07, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan Maestro 3100 locks
You can try a hard reset. Hold in the reset button (left side of unit, use a pin or toothpick), while turning on the unit. If you don't get the blue Magellan screen, you'll have to try again. If you get a screen with a blue background and a menu, turn it off and try again.
So far, this has fixed:
1. unit won't go on
2. unit reboots when routing
3. unit turns off after a few seconds
At least, it's fixed it for me. No idea why this happens, but it's pretty damn annoying. Give it a try.
Dec 26, 2007 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan Maestro 4040 GPS Receiver Logo
82 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
