Question about Tomtom GO 910 GPS Receiver
Not charging my tom tom 910 wont charge I'm hoping it's only the battery how do I replace it
  • ewood21 Jul 05, 2008
    My TomTom works fine when connected to AC or DC power but even though the battery then shows fully charged, it won't power on without the auxilary power (AC/DC).
    I have reset the unit several times, removed the application (suggested by TomTom support) and re-installed and have attempted multiple updates with absolutely no luck!
Actually the link provided below is not valid , i went to the web site and searched for tomtom 910 and here is what came up: http://www.megacapacity.com/23922.html
Posted on Jun 25, 2008
  • 3 Answers
The battery is replaceable. You can get one at http://www.megacapacity.com/752.html. It is even a higher capacity battery. It can be a pain though. You need a very small Allen wrench to make the repairs. The outside screws are located underneath the two rubber skids. You might have to peel the rubber up slightly at each end to get to them.
Posted on Feb 05, 2008
    President:
  • 4,402 Answers
It's not replaceable you have to send it in.
Posted on Jan 30, 2008
TOM TOM 910 TURNS ON BUT IMAGE OF TOM TOM STAYS ONSCREEN WILL NOT TURN OFF
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds .
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
Jan 27, 2011 | Tomtom GO 910 GPS Receiver
Tom Tom XL battery died and now placing onto computer to recharge and it doesn't seem to be responding - what should I do
Leave it on charge on the computer and if it does not still come on, then you try to fix it in another gps device and try to charge it on there, if it still does not hold a charge, then it means you will have to replace the battery, because the cells are weak and cannot hold a charge.
Jan 02, 2011 | Tomtom GO 910 GPS Receiver
Battery not holding charge
hi dave_hanc93
you say its not holding a charge, but is it charging?
plug the charger in and make sure the light is on on the charger, then on the map screen, tap the screen where the satellites are. on that screen on the top right is the charge indicator. is it green and moving from left to right? if not, then its not charging.
try hooking it up to the home dock to your computer and check and see if its charging on the home dock.
let me know how you make out.
bill
Oct 08, 2009 | Tomtom GO 910 GPS Receiver
Tom tom wont turn on.
turn device over and look for tiny reset button near to power connect strip. then use a blunt safety pin to reset,this should allow you to then turn it on,this works on 500 ,700 ,900 , 510 , 710 , 910 , hope this helps .
Jun 06, 2009 | GPS
TOM TOM 910 won't charge/turn on
there is a little push button on the back. use a niddle and push that down at the same time hold the power button. you will hear the unit turning on itself and then it should work fine
Aug 10, 2008 | Tomtom GO 910 GPS Receiver
My tomtom 910 will not charge
Might be the contact of the charger. That's my fault after years of usage
Jul 27, 2008 | Tomtom GO 910 GPS Receiver
Tom tom 910
Same happened with me. It's the battery that needs replacing
Mar 10, 2008 | Tomtom GO 910 GPS Receiver
Tom tom 910
Try pressing the reset button, check your documentation for the location...but it's at the connection interface.
May 21, 2007 | Tomtom Go 910 (Europe, USA and Canada...
Tomtom GO 910 GPS Receiver Logo
166 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
