Question about HP LaserJet 3055 All-In-One Printer
Squakey noises while printing
My office laserjet 3055 makes some squakey noises right after is turned on and when is printing. We already tried different toner cartridges but we got the same results. Looks like the sounds come from the left hand side.
Any advice?
Thanks,
Miguel
Laredo, Tx
  • 28 Answers
Mainly it from Fuser Section ,Your Fuser Sleave has damaged replace it with new one it cost some thing around 5-10$
thank you
Posted on Feb 16, 2008
The HP 3055 network printer, connected to 3 dell inspiron laptops doesn't print...it says it's offline, even though the screen on the printer says "ready." I tried adding a printer profile and...
Check the IP of the printer, it should be manually assigned, if you are not confirmed,
  1. Press menu/enter .
  2. Use the or the > button to select Reports , and then press menu/enter .
  3. Use the or the > button to select Config report , and then pressmenu/enter .
  4. The printer exits the menu settings and prints the report.
Try re installing the printer software from the cd, or download the full version from the links below for your area
HP LaserJet 3050/3052/3055/3390/3392 Asia Pacific Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 Eastern Europe Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 North America/Western Europe Full Software Solution
(The full software solution provides print, fax and scan functionality. This software solution is the same solution as the Version 4.0 in-box CD that came with your HP LaserJet 3050/3052/3055/3390/3392.)
You can download Printer manual from the link below
Printer Manual
If you require more assistance in this regard feel free to reply to this post
Best regards-BA
Jan 20, 2011 | HP LaserJet 3055 All-In-One Printer
How to fix the hp laser jet 3055? Is not printing... looks and sounds like is not grabing the paper sounds like the turning wheels are turning but not grabing paper..help
Try gently scrubbing the rollers with a lint free damp cloth.
Make sure that the paper is good(not warped).
Make sure that the paper is pushed back far enough to meet the roller.
Dec 21, 2010 | HP LaserJet 3055 All-In-One Printer
How do I set up my hp laserjet 3055 scanner on PC
You are using the Windows XP version driver right? You can try to uninstall all the existing drivers of printers on your laptop except for those printing to document ones by using Control Panel->Printers. Then turn off your printer and restart your laptop. Then put in the CD and reinstall the driver. Follow the instruction to connect your printer to your computer with a USB cable and turn on your printer. Move the USB cable to another USB port if still no connection.
If the issue persists, you might like to use the HP troubleshooting utilities to search for it and see what the problem is related. You can download all the drivers and utilities from the following page too.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1140780&prodTypeId=18972&prodSeriesId=1161389&swLang=8&taskId=135&swEnvOID=228
There are some troubleshoot links on that page too. You can also try to update the firmware on the printer if the problem persists.
Other than that, you can run a Microsoft tool to make sure your computer is OK for printing devices and all the services are running well. It is on the following page.
http://support.microsoft.com/gp/printing_problems
Jul 23, 2010 | HP LaserJet 3055 All-In-One Printer
HP 3055 All In One laserjet prints all black pages
Odds are that you have a bad toner cartridge; especially common when using remanufactured cartridges. (Staples, Corporate Express, etc.) Replace your cartridge with an OEM HP cartridge and you should be OK.
Feb 22, 2010 | HP LaserJet 3055 All-In-One Printer
Fax issue with HP Laserjet 3055
Hi. The fax-module in lj 3055 needs a 100% analog dial tone. You might get it working on a internet-phone-line, but HP garantees nothing because there are so many internet-phone-providers, and all of them operates with different specs and line-quality. You might try to lower the baud rate, turn off JBIG compession and error-correction. If the problem still remains, you need to replace your phone-line to a 100% analog line. Not any internet or ISDN/adapter-stuff. You should test your fax on any analog line at a friends house, just to make sure the fax i working anway.
Jul 27, 2009 | HP LaserJet 3050 Printer
Unable to scan on HP Laserjet 3055 on Windows XP
Sounds like a software issue - U might try contacting HP but do not hold your breath. If machine is out of warranty they want nothing to do with you and will refer you to some forum or whatever. Or they might tell you to get a new scanner compatible with a newer OS.
Jul 02, 2017 | HP LaserJet 3050 Printer
White line
White lines are generally caused by clogged print nozzles. I assume that you have a printer with the print heads built into the cartridge. Are you using high quality cartridges or cheap refills? If cheap refills, try a better/different brand of cartridges and see if that helps. I would also check the printer manufacturers website and try their recommended printer nozzle cleaning procedure.
Jun 03, 2009 | HP LaserJet 3055 All-In-One Printer
Only prints black& white
The HP Laserjet 3055 is a mono only printer but can scan in B&W and colour.
Dec 19, 2007 | HP LaserJet 3055 All-In-One Printer
3055 scanner not working
My HP 3055 cannot scan but can print & fax.
Nov 02, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
136 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
