Resolution 16-10 I have a mother ECS M925 . I put a new monitor Wide Screen LCD with a resolution 1680 by 1050 . I don't find this resolution .Can You help me Thanks
  • gavazzann Jan 30, 2008
    many thank . I will buy a aditional video card, because i will need 1680x1050 . At this moment i use 1400x1050 and the circle in auto cad is a elipse.
    Thank a lot
    President:
  • 2,351 Answers
Your resolution is based on your video cards capabilities. If your still using the original on-board, integrated video I doubt if you'll be able to reach such resolution. Open control panel, open Display. Click the Settings Tab. You will notice Screen resolution & there is a slide bar. Sliding the bar to More will increase the resolution. You'll see what the max is for your video card. As to your LCD monitor it's max resolution is capable of reaching 1680x1050. Keep in mind the word " capable ".
If you need that kind of resoluton you'll need to find a AGP video card that can go that high.
Please vote.....
Posted on Jan 30, 2008
Cannot get the picture wide
Firstly you have not mentionrd thr Make & Model of your monitor.
Assuming it's a LCD Monitor you could try the following:
Modern monitors have a 'native resolution'. While most LCD monitors can display a wide variety of screen resolutions, the native resolution will always look best, since this is the screen resolution that matches the number of pixels inside the display. Any other screen resolution may look blocky or distorted, since the number of pixels used in the picture will not match the actual number in the display.
You can adjust your computers display resolution easily. For best results with your monitor, you should use the latest display drivers and monitor drivers and run your monitor in its native resolution. For more information on updating your display drivers, see this link.
Also have a look at this video
May 20, 2012 | Computers & Internet
ASUS P4SP-MX detect the new LCD monitor VH197D as an CRT. picture is stretched; circle's becoming a ellipse. Can you help me!?
Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.
Feb 21, 2012 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
I have SAMSUNG LCD 943 MWX monitor which is 19"
This is not a monitor problem.This is a mother board problem, some mother boards are supporting this resolution.For this problem,you have to replace the mother board or put the graphics card on the same mother board.your problem will solve.
Feb 18, 2011 | Samsung 943NW Monitor
NOT SHOWS RESOLUTION 1360 by 768 IN 16" WIDE LG LCD MONITOR MY MOTHER BOARD IS GIGABYT INTEL CHIPSET 865, PLS GUIDE US
Hi!
Installing the video card driver can make use of its features of higher resolution support for your LCD monitor.
And also install the driver of your LCD monitor. This enable to use higher resolution that could provide with your computer video card as I have mentioned above.
Hope it helps..
Thank you for reaching Fixya.
Please leave comments for further assistance.
Apr 05, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I have changed to an Acer 19in wide screen monitor, my photo albums appear as wide screen pics
You need to set the PC video resolution to 1440 x900 @60Hz which is the native resolution of this monitor.
Mar 17, 2010 | Acer AL1916W 19" WideScreen LCD Monitor
I cant fit the whole image on the screen. The options to adjust only allow me to adjust the width...it wont let me show both the top of my windows open AND the start button.
Your resolution may be set to high on the computer. Or you have a standard screen resolution set and since the monitor is a wide screen, it is cutting it off.
Try a different resolution 1440x900 is what the va1930wm uses.
If using a laptop with a standard type screen on it, you may have to set the laptop to just light the monitor to allow this setting to take.
Since this monitor is a wide screen, it may have options in the menu to stretch or zoom on an image if the resolution is not set to a wide screen format.
Dec 03, 2009 | ViewSonic VA1930WM LCD Monitor
Monitor resolution
What do you mean that you were unable to get the native resolution of 1440x900? Are you saying that the resolution varries?
Since you mentioned that the mother board supports 1440x900, try to set the monitor resolution to that same resolution and then restart the computer.
If you will get the same problem, you have to make sure that the video card supports 1440x900 resolution.
Apr 15, 2009 | LG L194WT 19" LCD Monitor
Resolution problems
Colsult your user manual or online documents, this may be an incompatible resolution for your monitor, whatever it is.
Oct 03, 2007 | Gateway FPD2275W LCD Monitor
Acer AL1916W monitor
The AL1916W's native resolution is 1440 x 900. See if your display settings can produce that resolution.
Sep 22, 2006 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
689 people viewed this question
David Payne
David Payne
