Question about Panasonic PT-51G44 51" Rear Projection Television
I have a Pan. pt 51g30t shuts off immediately
As soon as you turn it on it shuts off.The only way to get it to restart is to unplug it.As soon as you turn on it goes right off again.Also the antenna in has been shot and for a while I had to use an accessory "audio 1 or 2 to get a pic.Now the thing immediately shuts down.
    President:
  • 4,402 Answers
The most likely part is a fault with the convergence board and the main power supply. In many sets like yours when an amp module on the convergence fails the picture will bend out of shape and cause the power supply to shut down
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Posted on Jan 30, 2008
6ya staff
SOURCE:
Driving check engine light flashed, car immediately shut down. What now?
Something major has malfunctioned. The shut-down is performed to prevent damage to the engine. Get it serviced.
Mar 07, 2016 | 2007 Chrysler PT Cruiser Touring Hatchback
My Panasonic PT-60LCX64 Television shuts off after 5 minutes then I turn in on and it stays on for however long I want
You might check your power supply for a bad capacitor. Look for a swollen top and replace if necessary.
Mar 15, 2013 | Panasonic PT-60LCX64 Television
My Panasonic Cinemavision HDTV keeps shutting off. I can turn on for about 5 seconds then it goes off. No blinking red lights, just power off. I can unplug the power supply and plug back in and get the...
It is the problem of your transformer. It might have got damaged in lightning or voltage fluctuation. Replace that small and cheap equipment to find your tv work again. When having a new one, go for the best thing available in market or else the new one too will go out soon.
Apr 18, 2010 | Panasonic PT-47WX49 47" Rear Projection...
2001 BMW 330i wont start. Immobolizer?
Sounds like a dead battery or a dead starter. Try using a jump box or jump start first.
Feb 27, 2010 | Anti-theft Alarm System 3 Series E90 E92...
My Panasonic PT - 47WX49 rear projection wont turn on - it would go on for a second and shut down - then 3 red blinks - so i changed out the IC's now it powers on but immediately shuts down and only 1...
Thats the 140 Volt error. Usually caused by the bridge connectors that connect the two circuit boards or the red HV cable from the flyback not being connected properly
Dec 29, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Why does my 2003 nissan sentra turn on and then immediately shut off?
a mass air flow sensor will do this. unplug and restart.
Dec 28, 2009 | 2003 Nissan Sentra
Receiver shuts off as soon as I turn it on
having the same problem. it doesn'T Shut off immediately. but after 30 seconds or if I turn the volume up, then it shuts off
Dec 05, 2009 | Denon Audio Players & Recorders
KSRS25ILSS02 The Freezer is
Select the "defrost" mode, if available. Otherwise, just shut it off for several hours and let the frost melt.
The frost is fooling the fridge into thinking it is still too warm inside the refridgerated comparments.
Aug 25, 2009 | Refrigerators
Panasonic PT-51G44 51" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
