Question about Protron PD-DVR100 DVD Recorder
Erases disks Why is this thing erasing the discs when they get almost full. When I set the timer to record, the disc gets almost full and it just erases the disc?????
Marke sure you don't have it set on continue or continous loop. That should fix it
Posted on Feb 27, 2008
My LiteOn LVW-1101 Erasing DVD's Hi, Hope you can help me with this problem as Im not techically minded? I own a LiteOn LVW-1105HC and after recording DVD's(even DVDR's) I put the disc back in to...
Your lite on has lost its mind and needs replacement.
Meanwhile a non rewritable disk cannot be erased. If not finalized it may not be read on another machine but the originating machine can read it.
May 08, 2017 | Lite On LVW-5115GHC+ DVD Recorder
Howe to erase adisc that I have just recorded?
format disk under windows..if that's what you have as an option..this will not provide the same density, however, as a manufactured disk
Apr 24, 2008 | Televison & Video
How do you delete thing from hard disk or erase very thing and start over to get more space on the c drive
You travel dangerous ground
The best answer to your end question is....get a full installation disc, not upgrade, and insert while the computer is on. Have a friend show you how to start from this disc. It can erase everything and give you a new computer.
Namaste
selk
Oct 12, 2010 | Everex StepNote VA4103M Notebook
My Panasonic E55 is having problems reading disks after I try to erase something on them. I erase without success and then it tells me the disk is unformatted. Also will not format disk after that. I...
Sorry this isn't a solution, but I just want to commiserate with you. I am having the same problem. I guess the problem started about three weeks ago. The recorder will not recognize any blank DVD-R discs and it only recognized 1 out of 4 new DVD-RAM discs. It would read most of my older DVD-RAM discs but would refuse to erase some of the old recorded programming. It also refused to recognize some of the older DVD-RAM discs, so in frustration I reformatted one. I was able to record and watch a couple of shows, but now it is saying "Unformat" for that disc.
About a year ago, the DVR gave ma some trouble and I was able to fix it myself. (I think it suddenly wouldn't power on, but I don't really remember if it was that or if it was a "SELFCHECK" error.) I had to open up the case and replace two capacitors. I bought the replacements at Radio Shack and my son helped me solder them on. My next step with this DVR will be to open up the case and look for any obvious problems. The worn-out capacitors looked oily and damaged, as I recall.
Sep 16, 2010 | Panasonic DMR-E55 DVD Recorder
How do i rewrite over a disc that is full
If you are using a DVD-RW or DVD+RW, you can format the disc by performing "Format". You can format DVD-RW for either video mode recording or VR mode recording. DVD+RW can be format in order to erase all content of the disc.
You may not be able to reformat a disc that is not previously formatted by your recorder an example would be a. DVD disc formatted by PC or another recorder.
Follow these steps to re-write:
Insert a recordable disc.
1 Press [SETUP].
2 Select "DVD Menu",
then press [ENTER].
3 Then select "Format", and
press [ENTER].
4 select "Start", then
press [ENTER].
5 Confirm by selecting "Yes", then press
[ENTER].
Formatting will start.
6 Formatting is completed.
When the disc is ready for you to rewrite to "100%" is indicated.
Formatting 100%
Mar 29, 2010 | Toshiba DR420 DVD Recorder
Disc will not finalize error comes up as e19 can not record to the disc. the show is actually recorded and will play back just not finalize. have tried -r/ +r and + rw and get the same message. unit being...
You don't need to delete timer rec programs to Finalize, Format or Erase discs!
Set the Mag 2160A (mfgd in 2009) to Source L3 (DV) using the Source button on the remote.
To Format a RW disc, set unit on L3 BEFORE inserting a new disc cuz the Formatting op is automatic and starts right away. It's also so short on a +RW (longer on a -RW) that you could think it had been Formatted.
Finalizing requires you to select it from the Disc Edit menu, so you can set the unit on L3 after inserting a disc for this op.
More into on all aspects of setup and op are here:
http://www.avsforum.com/avs-vb/showthread.php?t=940657
Apr 29, 2009 | Televison & Video
LG DR4810 DVD recorder says disk is full when it's not.
Have you tried a different disc? Some discs do go faulty. Is the disc compatiable with the machine? Try erasing the disc and starting again.
Feb 01, 2009 | LG DR-4810 DVD Recorder
E-4 54040990 Cannot record on this disc
I had this problem with my Toshiba DVR16 recorder; I was unable to format new DVD-RW discs even though old ones worked fine.
Initially I thought the laser lens was dirty, but no amount of lens cleaning helped. Then I thought the rated disk speed must be to blame, since it was some 4x disks that first presented the problem. But then I tried 2x disks and the problem persisted. So some aspect of the manufacture of these disks must have changed in recent months.
Anyway, the solution I discovered was to perform an 'erase' operation on each disk using a program on my PC called ImgBurn. This is a free program, which can be downloaded from imgburn.com. Just select Tools > Drive > Erase > Quick. Once that's done (it only takes seconds), take the disk out of your PC and pop it in your DVD writer, whereupon it should start its own format routine.
This has worked for me on 3 different brands of disk (Sony, Memorex, Datawrite). Which is just as well, as I was on the verge of throwing the DVD recorder out of the window. Hope it works for you.
<Neil G.>
Sep 29, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Presidian 3222
I don't know if this will help, but according to the operator's manual I have, on page 64, the only place it mentions "Full" or "Quick" Preparation, is when using a DVD-RW disc. Apparently, with this type of disc, you must use the Full or Quick preparation INSTEAD of Finalizing after you're thru recording onto the disc.
With the DVD-R and DVD+R, all you can do is "Finalize"; With the DVD+RW, if I'm reading this correctly, NIETHER Finalization OR Preparation is required.
But with the DVD-RW, apparently ALL you can do is a "FULL" or "QUICK Preparation.
If you're only getting "Erase or "Finalize" WITH the DVD-RW, then it appears there may be a problem with the machine.
Or, if you're attempting the "FULL or QUICK" Preparation with any disc OTHER than the DVD-RW, all you should get is "erase" or Finalize", since the QUICK or FULL Preparation is not done with discs other than DVD-RWs.
Hope this helps. I'm certainly not an expert on these things....I'm a "Vinyl" type guy.
Roy Davis
May 31, 2008 | Dual Presidian DVD Recorder
Playback of recorded programs
try formatting the disc. it will erase everything on the disc and you can start fresh. try this with all the discs.if the problem keeps happening, try new discs.
wg
Feb 03, 2008 | Panasonic DMR-ES20EG DVD Recorder
Protron PD-DVR100 DVD Recorder Logo
53 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
