Amp cuts out
When i turn the volume up on my technics su-ch700 it cuts out. This happens without any speakers connected
  • 6 more comments
  • gratinman Feb 02, 2008
    By cuts out i mean it switches off and goes into standbye
  • Anonymous May 19, 2008
    when i turn the volume up on my technics su-ch700 it turn of and display an "E". This happens without any speakers connected
  • Anonymous Jun 10, 2008
    please help. I have same Problem
    Please Help. I Have same Problem
  • Anonymous Jun 30, 2008
    Same issue CH 700 amp. The systems shuts down with E 11111 message on the screen. Damn annoying as its a nice old system
  • Anonymous Jul 03, 2008
    Mine has exactly the same problem. Will try the fixes and see what happens. Must be lots of us out there!
  • alejandra5 Nov 22, 2008
    I have the same type or model and it shuts off once I rise the volume
  • Anand Srinivasan
    Anand Srinivasan May 11, 2010
    what do you mean by saying that it cuts out...
The fan is ageing and putting noise on the protect line. Replace it or put a 100 uf cap across the fan at the plug. Beware polarity is marked wrong on p.c.b.
Posted on Feb 23, 2008
  • 152 Answers
Most of these type systems have feedback path which shuts down the system once there is excess heating in the regulating transistor... i think there must be something getting shorted when u turn the volume up.....
Posted on Feb 04, 2008
Technics su-g75 amp goes to loud static after a few minutes
Hi Aawpharmd,
system control error.
please go for repair shop.
regards,
nuwan
Jan 13, 2014 | Technics SU-G75 Amplifier
Technics su a900
I have the same TECHNICS SU A900 MKII as you are talking about and it always runs warm I think using 4R speakers instead of 8R speakers should solve the problem and actually I am thinking of switching to 4R as well.
Oct 13, 2013 | Audio Players & Recorders
Why does stereo amp cut out at higher volume
You seem to have the answers to your question. I would just resolder the connections anyway without checking. If it solves the problem you have saved yourself a lot of money. If it doesn't follow the other steps in order of cheapness!
May 03, 2013 | Audio Players & Recorders
Hello I have a Technics SU-V45A amp, it's about 18
See there is a problem with the volume conroller as it is 18 years old the controller has worn out replace the volume controller with a new one and you will be able to enjoy great sound again
Dec 05, 2010 | Technics SUV500 2-Channel Amplifier
I have a problem with a tecnichs sc-ch700 when i up the volume the amp off in any moment
Hi....
Are all the speakers connected and connect Right at both ends?
Thanks
Aug 09, 2010 | Technics Audio Players & Recorders
Su-v55a technics amp cuts off when volume up to 2
usually meens it is protecting itself from destruction
check your wires and speakers for problems
Feb 09, 2010 | Technics SUV500 2-Channel Amplifier
Same problem, amp cuts out if volume too high
Use a multi meter,set it to 12v,turn system on use some bass.while music is playiing hold pos of multi meter to poss- neg to neg- on amp see what voltage is running at at what its dropping to it sounds more like a voltage drop problem.if you hooked it up back words u could fry unit..Have you done the big 3.what size is your alt,and what is your amps draw..
Aug 26, 2009 | Audio Players & Recorders
Technics su z2 amp shuts off sound
hello. we cant help if we dont know what music source you are using.
Apr 13, 2009 | Technics SA-AX530 Receiver
Amp cutting out
You have one of two solutions.
One: you have the speaker ohm load lower or higher than the amplifier will support. You should check the ohms rating on your speakers vs. the amplifier. Make sure you match up the rates for proper operation. You can also try out a different set of speakers and see if they work properly.
Two: You have an electronics failure within the amplifier. You need to obtain the electronic knowledge and schematics for servicing your unit or bring it to a repair facility in your area.
Just as an FYI.... double check your speaker cables and make sure that neither the left or right is shorting together. Make sure the bare conductors are not touching anywhere. A pinched or damaged speakers wire can also cause the symptoms you are talking about.
Jan 20, 2009 | Audio Players & Recorders
945 people viewed this question
 Grubhead
Grubhead
