Question about LG WM1814CW Front Load Washer
Do I need sensor assembly (#6501KW2002A) on WM1814CW?
Yes, I am having the dreaded LE problem with my 2 year old WM1814CW and I read most of the solutions and I am ready to fix it myself.
The problem is I don't know the exact part to order.
On the service manual of WM1814CW, sensor assembly is 6501FA2462C.
But most of you guys are talking about 6501KW2002A.
And I learned that in fact those two are not the same thing.
Which sensor assembly do I order for WM1814CW?
  • 1 more comment
  • popyu Feb 12, 2008
    Corrected the rating. Sorry about the mistake.
    By the way, 6501KW2001A & 6501KW2002A, they both work.
  • Anonymous Mar 18, 2008
    the le light comes on. it looks liked the washer machine will not rotate. you can hear some type of motor or sensor but it will not rotate after trying about 2 min and then the le light comes on
  • Jonathan Frnazel
    Jonathan Frnazel Dec 23, 2013
    xxx2001A has smaller connecting pins and will not clip onto the stator if xxx2002A is needed.
    New Friend:
  • 60 Answers
The part number you came up with is for the out of balance sensor not the hal sensor. The correct part (if your model number is WM1814CW is 6501KW2001A. It's located behind the rotor on the back side of the stator.
Posted on Feb 05, 2008
I was wondering if anyone knows the "HAL Sensor" Part Number for LG Model No: WM2432HW
Thanks
Posted on Mar 05, 2008
  • 298 Answers
Here is a few links where you can purchase these parts.
LG 6501KW2002A Hall Sensor
LG 6501KW2001A Sensor (In Stator) Assembly
Posted on Sep 08, 2010
I use a 24" flat bladed screw driver with a square shank. Jamb driver into vent slot next to wider blade on rotor and hold screw driver as tight to plane of rotor as possible; use socket on a breaker bar on bolt. Those bolts have lock-tight on them so use a big driver that fills the vent slot. Should loosen up. Or, use electric or air powered impact wench.
Posted on Feb 21, 2010
Hi, i took my LG WM2677HSM apart and removed a part with # 6501KW2002A out, is this the famous hall sensor? Would like to know before ordering a new one. Appreciate any help.
Thank you.
Posted on Nov 19, 2009
  • kotky
    kotky Mar 29, 2014
    yes it is
How do you remove the bolt to get at the rotor/stator?
Posted on Jun 04, 2008
Have a top loading Kenmore elite high efficiency washer model 796.2927, 2 years old this thanksgiving is showing erroe code LE? what do i do to fix?
On most Kenmore front load washers the LE error indicates a LOCKED MOTOR ERROR. This can be caused by:
  1. Loose motor harness connection.
  2. Failed HALL SENSOR.
  3. Failed STATOR.
  4. Failed ROTOR (cracked magnet).
Nov 06, 2012 | Washing Machines
We have an LG WM1814CW washer. For some reason after approx. 10 or 15 min. it will just shut off. Water and soap is still in the drum. The door will unlock and there is no error code. It just quits. We...
Hi tdld6365,
Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 11, 2011 | LG WM1814CW Front Load Washer
Need service manual for LG Washer wm1814cw looking to fix LE code
you can go to appliancerepairplanet.vstore.ca to get a sevice manual
Dec 13, 2010 | LG WM1814CW Front Load Washer
Our Washer is about 2-3 years old Model number is WM1814CW it has been giving us an LE error and not finishing cycles. It leaves clothes in a full tank Soaked and does not spin them out. Today it is making...
the Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Mar 18, 2009 | LG WM1814CW Front Load Washer
LE error on LG wm1814CW
My wife and I had the same LE error on our LG washer intermittently in the past. We have already been down the road to replacing the Hall Sensor only to find the washer not spinning and displaying the LE error again. Here is what we have found to be the remedy: Being that the Hall Sensor is a "Position" Sensor, we made a conscientious effort after unloading the washer to place the drum in the same position as when it finished its spin cycle. It has now been about 3-4 months with NO "LE" ERROR on the washer!!! One other thing - if you currently have the error displaying, you will have to unplug the washer for at least 2 hours to erase the memory of the drum position. This way you start fresh with a good position. Just leave it unplugged overnight. Hope this helps out!
Mar 14, 2009 | LG WM1814CW Front Load Washer
LG WM1814CW Error Code "LE"
LE codes are extensively covered in past Fix-Ya solutions, but are generally caused by only a handful of things. 1. the " Load Error " can be a very off balanced load. 2. excessive use of soap leads to too much suds, and thus drag on the inner tub. (use 1 tablespoon of HE soap max. per load) or 3. the Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
Dec 31, 2008 | LG Washing Machines
LG WM1814CW
If you go to the LG website clik on support put in your WM1814CW model number it tells you that your motor is on warranty for 7 years so you should be able to get it replaced.
Oct 21, 2008 | LG WM1814CW Front Load Washer
Another LE error question
Had same problem last yr. about 2 yrs. old. Just happened again today. When i called LG last yr. they said unplug unit for 1/2 hr plug back in. I did this and has run fine until today I'm trying this process again and it worked.
Apr 02, 2008 | LG WM1814CW Front Load Washer
LG TROMM WM 2077CW LE Error
An LE error is a locked rotor. The hall sensor on the stator part of the motor is not sensing the rotor part of the motor is turning. So the short version is you need a new stator(which has the sensor on it or just the sensor) replaced which should have a 5 year warranty on it so call LG for your nearest authorized service center
Nov 17, 2007 | LG WM1814CW Front Load Washer
LE error
In case you are sure that the washer is not full of suds or overloaded a breakdown in the signal between the microprocessor and the motor may cause the error code. This can occur if there is a loose wire, dislodged ball sensor. Try first to reset the control unit by unplugging washer power cable for few minutes. Good Luck !
Aug 04, 2007 | LG WM1814CW Front Load Washer
LG WM1814CW Front Load Washer Logo
3,264 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
