Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Kp-fw51m31 service menu codes
I accidentally did an INITIAL instead of a WRITE and this caused a few issues, luckily had enough values written down/memorised to get the picture back, however some of the buttons on the front panel don't work as they are supposed to eg MENU pb is now QUICK FOCUS etc. The 51m31 is the Australian model, which "looks like" the 51ws510. I was wondering were I could get the adjustment manual or a list of the service menu codes with normal operation parameters.
thanks
joe
  • Sony Master
  • 8,617 Answers
You can get the service manual at the following link. t will ave the default values listed. They will email the manual to you if you request them to.
http://servicemanuals.vstore.ca/
Posted on Feb 03, 2008
6ya staff
SOURCE:
Initial value contains and invalid value & the standard value is set (Entry = Double side) (Code S310011)
Hello Peggy,
This error message is Twain Driver error. The cause is that a value outside the range or an invalid character was found among the items in the initial value data file. (Item XXXXX indicated by Entry=XXXXX)
If the file was intentionally changed, the value set for that item may be incorrect. If the file was not intentionally changed, the file may be corrupt. The value has been set to the standard value. The file must be written again, for assistance, please see "Initial Value File" in the "Operator's Guide".
A hard disk check (chkdsk or scandisk) and virus check must be performed regularly.
Hope this helps.
Thanks & regards,
ScanCare
Jan 22, 2014 | Fujitsu Fi-6140 High Performance Color...
Blue on the screen of the tv
Try to initialize it!
I had whole redish/pinkish screen on my 50v500 starting a few days ago, then I read through each of the threads on this site for the samilar problems on my model. I found TVtechmaniac's solution (pasted below) solved my problem. Thank you TVtechmaniac!
Enter the I2C Service Menu, be sure the power is OFF.
1. On the front control panel, press and hold the INPUT button.
2. Then press the POWER button for two seconds.
3. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
4. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight "MEMORY INTI", arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
6. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
7. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
8. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
9. Turn the set off-on and Confirm the picture remains in a good condition.
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS
Jun 23, 2012 | Hitachi 50V500 50 in. HD-Ready LCD...
Code d ereur 034310
HI, This will usually be the cause of a server issue that relates to the mtu values that are set in your device. Try changing your mtu value to 576 in the connection settings/advanced section. The initial setting of 1400 my be invalid at this time, thus, interrupting your update service download.
Simply navigate into System settings>internet>Connection settings>Connection x>Change settings, then press right arrow till u get to the MTU Value. The default is 1400 but you will need to change it to 576. This should open the gate and allow the system to update itself, properly.
Error Code: 034310
((Cannot connect to the system update server)).
Nov 28, 2010 | Nintendo DSi Black Console
Sony kp-61s70 hour glass shape on picture bows in
the sony service menu can be entered by pressing "display" "5" "vol+" also the diagnostic screen can be reached by vol- instead of + when you are in the service menu the number buttons navigate it its a little tricky at first but as long as you dont hit enter before you exit if you mess up it wont save just make sure if you fix it you save it by pressing enter
Jul 13, 2009 | Sony KP-61S70 61" Rear Projection...
I am having issues with my Sony KP-53s65 53in TV... You see double people and words. The color is off and the focus setting does not correct this issue. The RED and BLUE cross bars are lined up with the...
you need to get into the service menu on the tv and adjust some values you can find these values online but i would highly recomend that you get a service centre to look in to this ,
i've done mine my self but if you hit the wrong valuye you could mess the whole tv up there are about three pages full.
hope this helps
Jul 05, 2009 | Sony KP-53S65 53" Rear Projection...
Sony wega kp51 turns on for 3 secs than off w/ blinking red light
The flashes are fault codes. It means your system is faulty. If it is intermittent then it is more than likely a dust issue. Buy an air duster, spray out the back and restart. Should be fine
If it continues to play up then it will be a repair job
Dec 08, 2008 | Sony KP-51WS520 51" Rear Projection...
Tv discoloration
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
Aug 29, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Sony kp 51 ws 500
· 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
Hopefully, the descriptions of the blinking lights and the symptoms and problems will point you in the right direction to tell the problem with you Sony Projection Screen Television. If it is not enough, do not worry -- in the coming few posts I will talk about entering the Diagnosis and Service modes for your television set!
Feb 15, 2008 | Sony KP-51WS500 51" Rear Projection...
Service menu
Service menu for any sony will be by pressing and releasing the next keys: Display, 5, Vol+, them power on. The TV must be off while you do This, be carefull to change some values, I sugest that you take notes of what you change before you do. If you need to enter the self diagnostics will be the same but, volume -, instead of volume+. Hope this help you.
Jan 18, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-61XBR48 Service Menu Item Keeps Changing
the only thing to do is pick which video mode you want (tv, vid1,2,3,etc) and then turn off and then immediately on for an hour or two and then the picture will come on. I,ve heard it's an internal transformer problem.
Sep 26, 2007 | Sony KP-61XBR48 61" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
263 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
