Toshiba 37hl17 Hello I have a toshiba 37hl17 that was working fine a few days ago and now when I turn it on all I see is vetical lines different colors black gray white about 2 inches wide.Could someone please help if possible,the tv just went out of warrenty.Thanks Scott
  • Anonymous Feb 11, 2008
    Panasonic TH-42PWD7U 42 in. EDTV-Ready Plasma Television
  • I have a 17" Philips LCD TV. One day I went to turn it on and all I got was the same picture as above. I can switch channels and the lines move according to the show on TV. Philips said that it is not repairable and want to sell me a replacement at a reduced price. ????????
What the hell ?!
Posted on May 18, 2008
    Sergeant:
  • 261 Answers
Is this a Plasma? TV? Sounds like to me that a video processing board or connector is bad. Maybe a cable possibly. Does this happen always or when set is cold / or hot? Also call company who makes this set and see if they might extend warranty, seeings how it is so close to being under warranty. If they are wanting a repeat customer, they may consider it. Good luck and let me know if i helped you at all with your situation. Thank you Jay
Posted on Jan 31, 2008
How to diagnose my led tv issues
You most likely had a capacitor let go, they make a pop when the go out, inspect the PCB for a burned mark.
Oct 12, 2016 | Toshiba Televison & Video
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Dell Inspiron E1505 shows green pixels instead of black
the color pixels are different sections in the screen and the green section might be cracked
Apr 24, 2009 | Dell Inspiron E1505 Notebook
Crazy color???
It sounds like you both have problems with the video card. If your 360s are some of the earlier ones then that is more that likely the problem (it happened to a friend of mine). 18004MYXBOX is the Xbox support number and will try to fix it over the phone of have you ship it out to them (they send you a box and its all paid for).
Oct 19, 2008 | Microsoft Xbox 360 Console
APPROXIMATELY 3" GRAY LINE ACROSS THE TOP OF MY TV
Do you happen to have a cable box? (reset cable box also by unpluging it). is that line also showing on dvd player on different input?
Jul 01, 2008 | Toshiba 50HM67 50" HDTV
Change name on LCD display
The Toshiba phone you have can work on a few different Toshiba phone systems that program differently. Before I can look up the correct information to help you I will need to know which Toshiba phone system you have. Someone at the office should know but you can also track down the phone system and get a part number or other identifiable markings from it. Older Toshiba systems were typically a light gray color and the more phones you have the bigger it will be. The newer systems are usually dark gray (almost black) there will be a lot of wires going in and out of it and most likely a punch down block or two right next to it (white, about 12" tall, 3" wide, with hundreds of small metal pins to connect wires to.)
Oct 31, 2007 | Toshiba DKT-2020 Corded Phone
Toshiba 65hx81 65" Rear Projection tv. black & white color/green
Yep, your problem is a relatively easy one to repair if you know how to solder. You better repair it before it blows the fuse though. There are two capacitors in the main power supply that are coming loose and need to be re soldered. There is a Toshiba service bulletin about it. They are marked C809 and C810 on the main power supply board. Good Luck
Sep 05, 2007 | Toshiba 65HX81 65" Rear Projection...
Gray lines on clips while previewing
Hello Nick, please purchase special mini DV tape for head cleaning. After a treatment with this tape you can check if there is an improvement with other tapes. If you need more info please advice. Arpi
Aug 12, 2007 | Sony DCR-PC55 Mini DV Digital Camcorder
Toshiba 42H82 RPTV: Sound but no picture
It sounds like the 200v supply to the crt's is missing. this is the source for driving the tubes, other than the high voltage generated by the flyback transformer. If the set got really bright gray with wome white lines that are kinda on a diagonal, this is generally the cause. the source for this voltage is a diode on the secondary of the flyback transformer.
Jul 11, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 32AF42 Poor picture quality
TRY ADJUSTING THE SCREEN CONTROL ADJUSTMENT AT THE BOTTOM OF THE FLYBACK TRANSFORMER.THIS SHOULD REMOVE THE RETRACE LINES AND ANJUST THE HASY LOOK TO THE PICTURE IF NOT YOU HAVE A BAD CAP IN THE SCREEN CIRCUIT .LOOK FOR A 10MFD/250V CAP IF FEEDS THE NECK BOARD ATTACHED TO THE PICTURE TUBE 200V DC.
Jun 22, 2007 | Toshiba 32AF42 32" TV
Televison & Video Logo
186 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
