Question about Brother HL 5250DN Laser Printer
I am trying to print double-sided copy on card stock
Side one prints, then retracts into the printer and jams. Regular paper works fine. It also prints single sided copy on card stock just fine. Is there a trick or should I give up and go to Staples?
  • Anonymous Mar 24, 2014
    a few days ago, our savin c2828 printer started defaulting to double sided copies. after i switch it back to single sided copies, it only works for the next print
  • 417 Answers
HI there sounds like there is a blockage in the duplex area that is not holding any sensors down. Check the duplex area for torn paper, failing this it maybe a sensor problem which will then need a engineer.
Hope this helps
Thanks J
Posted on Jan 30, 2008
Duplex printing with card stock paper jams in back on Brother MFC-9840CDW
I would try manually inserting the paper for the back side. Most of the time it's best to wait a few minutes before trying the back side to give it time to cool so it will lie flat.
Sep 08, 2017 | Brother MFC-9840CDW Laser Printer
We are trying to print on a card stock ,110 lb. , 8.5x11 Paper keeps jamming. Will this printer work with card stock?
It will only work if the printer supports feed through from the back. If the paper has to go in the same side of the printer that it comes out it will jam.
Mar 20, 2011 | HP Officejet J5780 All-In-One InkJet...
I have an HP Photosmart A646 printer that I bought in the hopes of printing to 5x7 card stock. We have pre-printed card stock that we use for gift certificates and we need to be able to feed the card stock...
Thanks for visiting FixYa!
Depending on the program you are using to print your gift certificates, try this-
1) Open the program and open the file you use for your gift certificate.
2) Click on 'Layout' then 'Page Set Up' (probably found in the top menu bar by the right side of, FILE.)
3) Select 'Landscape' and then select, 'Custom'.
4) Enter 5x7 for height and width.
5) Enter the information you need in the data field, (ie, name address, etc.)
6) Select, Print.
7) When the 'Print Manager' box opens, click on, 'Properties'.
8) Click on, 'Type' and choose, "Envelope'.
9) Click on, 'Size' and choose 5x7. - and click, OK.
Your printer should have a slide where the paper is inserted. Place one of the 5x7 cards in the slot just as you would an envelope and slide the slider until it is 'close' to the card but not directly against the card.
Click, 'Print'. The printer should recognize the card (due to its thickness) as an envelope and print it.
Mar 19, 2011 | Office Equipment & Supplies
Regular paper keeps jamming, but card stock will print fine
The card stock prints ok but not regular paper because your pickup roller and separation pad are worn down and need to be replaced. The card stock still picks up because it is much thicker than the paper so the roller can grab it better. You need to get a roller kit part # RK-1320. We carry them at: http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_42&products_id=71 if you need to order the kit. We also offer full tech support after the sale.
I hope this helps, if so please rate our solution.
BuddyMc
Corporate Computer
www.ccl-la.com
Nov 16, 2010 | HP LaserJet 1320 Printer
Paper jamming only takes card stock however does not print anythi
I would replace the printer if it was giving me that much trouble.
May 11, 2017 | HP LaserJet IIIp Printer
Jammed card stock
This machine has auto paper type sensor- may be at fault
May 01, 2009 | Dell Photo 964 All-In-One InkJet Printer
Same problem : Paper Jam when is no paper... What to do, I need FAX !!!
Take a piece of stock card (I cut a piece of a manila folder to size) and put it in the feeder. Copy or print something and when the printer grabs the card stock, help it along by pushing it gently. You'll see that it prints. After that it will print on regular paper. Don't ask me why...
Mar 03, 2009 | Canon MX300 Office All-In-One Printer
I am working on a IBM infoprint 1222 it runs single sided copies fine but it jams on the 2nd to 5th page of duplex copies. Replaced the rear exit door and duplex unit but the problem remains. Any help...
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 19, 2009 | IBM Infoprint 1222 Laser Printer
HP C4280 incorrect paper feed
Check your printer's capability.
Buy the card stock they recommend.
If all else fails, print on plain and take card stock to a copy shop and have them do it for you.
Walking there beats going nuts over stupid software or hardware problems
Dec 16, 2008 | HP PhotoSmart C4280 Laser Printer
Paper keeps jamimg
u break it and put it in the dustbin
Dec 13, 2007 | Lexmark X7170 All-In-One InkJet Printer
Brother HL 5250DN Laser Printer Logo
415 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
