Double channels coolsat 5000
I sjust downloaded fix 163 for sat 119 and 110 For some reason I now have many channel numbers doubled. One with the program and other unknown but borh having the same idnetical show.
How can I get back to one channel per station?
Delete channels and rescan it worked for me
Posted on Feb 14, 2008
When i push the channel 3or any other button then it appears this 3- or 5- or 1- and then if i push an other button it tune in channel 33 or 35 and not in channel 3 or 5 or 7
Many sets for single digit channels you only have to press the number or press a zero and the number--if double digit channels work correctly try on single digit ones zero and the number.
Dec 17, 2012 | Samsung Televison & Video
Double channels coolstat 5000
Maybe the system has reached the maximum channel capacity and it repeats some channel to have all the incoming signals... Have you tried re-channeling the system.. this will arrange and sort out the numbers...
Good luck... Fixya.
Feb 02, 2008 | Audio Players & Recorders
I cannot install a double sided 512mb ram
some motherboards do not support a mixture of single-sided and a double-sided ram modules in its ram channels. please check with your motherboard manual
Nov 05, 2009 | Asrock 775i65GV Motherboard
Enter channel number of double digits?
Are you being serious? Are there numbers on the remote? press 02 for channel two press 08 for channel eight press 10 for channel ten all the way up to 99 then back again.
May 30, 2009 | Hitachi CLU-5713TSI Remote Control
Coolsat 5000 platinum remote codes
Press ok and device and then enter code to do manual search push ok device at the same time light will blink twice then keep pushing up on the channel button until tv shuts off then push ok then you are done i hope this helps.
Feb 27, 2009 | Jensen 143307 Remote Control
Akai LCT2662N Channel Changing Problem
there is a button that controls how many digits you can enter. it is located betwwn the 0 and source or below the 8 buttons
Sep 02, 2008 | Akai LCT2662 Television
TV Color
You need to replace both convergence ICs they are both STK392-120 and you will also need four 6.8 ohm 1 watt metal film resistors. You can get the ICs and resistors at the following link and they will provide free instalation instructions with pictures so you can do the repair yourself. Here is the link.
http://servicemanuals.vstore.ca/
Jul 04, 2008 | Philips 60PP9202 60" Rear Projection...
Ram can works dual channel
you need to make sure your ram is identical.....for example if you have one single/sided and one double sided but are both equal in capacity still may not work.......also you could be using wrong memory slots double check your motherboard manual and ensure you are using correct memory slots for dual channel operation...however memory pair mismatch is most likely your culprit
Dec 12, 2007 | Intel D865GBF Motherboard
Coolsat 7000 pvr
You could check for further info for this model through the following site:
http://forums.f2atv.com/
Oct 27, 2007 | Computers & Internet
71 people viewed this question
 Grubhead
Grubhead
