Question about HP Vs17 17" LCD Flat Panel Monitor
No Dial Tone on phones or modem
Phones work until computer is plugged into jack. then there is no dial tone wither on phone or modem. cannot connect. called tech support for internet, they said problem is with line. called tech support for phone line, they said problem is with internet. changed jacks, changed phone lines, only one place to plug it in in back of computer so have not made classic error. modem tests okay, computer says modem is in disconnected state when not attempting to connect. Any ideas?
    Scholar:
  • 84 Answers
If you have a dial tone when your computer is not plugged in, then the problem ls with your computer[ a possible short in the computer] the phone cord to the jack, or anything in between such as a dsl modem.if you have dsl, be sure your ethernet cord [ that's the wider plug cord] is in the wider jack in back of the computer. it wont fit in the regular phone jack.if you have dial up, be sure the phone cord is in the regular jack not the ethernet port.[if you have one]
good luck
wg
Posted on Jan 31, 2008
No dial tone
  • First, try to check every telephone line is properly plugged into its phone jack. If you have a problem with just one phone, plug a different phone into that jack. If the second phone works, the problem lies in the first phone.
  • Then unplug each phone and answering machine in your house, one at a time. Wait 30 seconds after unplugging the first device. Pick up another phone to see if there's a dial tone -- if there is, then the first phone may be faulty. If not, continue unplugging phones in the same way and check for dial tone. If you find a phone that doesn't work, plug all your other phones back in and see if they work properly. The faulty phone should be replaced.
  • or disconnect the plug from the test jack inside the exterior box. This disconnects your inside wiring from phone company's line. If you have more than one line, select the test jack for the line that is causing the problem. Plug your phone into the jack; this plugs you directly into the phone company's line. If you have a cable modem, plug the phone directly into the jack on the modem.
  • Then pick up the phone receiver to see if there's a dial tone. If there's no dial tone, the problem is with your outside wiring. If there is a dial tone, the trouble is caused by your inside wiring, equipment or jacks.
  • Hope it will help you. Thanks for using FixYa.
  • Oct 19, 2011 | Lands Phones
    Tip
    Troubleshooting for modem.
    Problem:-
    User's modem does not dial or does not connect.
    Tip:-
    Prove that computer is connected with phone line and check that phone line contains dial tone.Therefor check that connection is connect or not.
    • Connection may not be less than six feet (1.8 meter).
    • Check dial tone by plug in the phone in phone jack.
    • If user has many more services (such as call waiting,call messaging OR voice mail) then check that these all are cleared or not and check call waiting is disabled while using modem.
    • Disconnect any answering machine,fax machine or printer which are on line with modem.
    • Check that are you not using digital,rollover or PBX line?These type of lines not works with modem.
    • Try with another phone line. (For this, you have another phone number or another phone line).If user connected with another line then you need to complain in phone company.
    • Try to connect modem with low connection speed.
    on Apr 13, 2010 | Computers & Internet
    Cannot connect to isp using modem (dialup) get error code 680. using vista home premium.
    error code 680 means there is no dial tone.
    manually attach a phone to the phone jack you are connecting to and check if there is a dial tone. if there is no dial tone on that jack try a diff phone jack. if still fails call your telco.
    if there is dial tone to other jacks it means the previous jack is faulty or damage.
    Oct 17, 2009 | Computers & Internet
    No Dial tone using Symantec Winfax Pro 10 on Windows 98
    Check the physical connection of the phone line to the computer make sure that it is connected to phone line symbol of the Ethernet adapter. Then make sure that the driver of the adapter is installed properly on the computer or you can try to scan the hardware first before the re-installation of the driver using the adapter.
    May 26, 2009 | Conexant chipset 56K V.92 PCI Data/Fax...
    I am trying to use the fax facility on my epson600fw.my isp is aol .Problem no dial tone. What connections are necessary............via printer,modem & computer ?
    Typically, a fax machine is connected directly to a telephone wall jack with a known working connection. Try plugging the fax machine directly into a wall jack first and pick up the handset on the fax machine if it has one. You should get a dial tone. Then try to fax something to someone you know.
    The machine can also usually be routed through the modem in a computer by connecting the "line" cord on the modem to the wall jack and plugging the fax machine into the the "phone" jack on the modem. You may need to install the software that came with the fax machine to get this to work.
    If you have no dial tone, check the wall jack with a known to be working single line phone. If there is a dial tone, it's something to do with fax machine, the computer modem or the connections.
    Some fax machines can take advantage of internet faxing through a cable modem or DSL connection. Check your manual for the options available.
    Apr 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
    VoIP not working after modem replaced
    It is possible they have your modem in an internet only class- I would call them and verify the modem is in a class avaiable for phone.
    Apr 05, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
    Bell phone
    is your computer hooked up dsl or dial up? unplug all the phones and computer from the phone jacks.plug a corded phone into the jack and check for dial. if you don't have dial tone, call your phone company. if you do have dial tone, plug everything in one at a time and see if the phone line goes dead.if it does, the last thing you plugged in is the problem.
    wg
    Feb 10, 2008 | Lands Phones
    possible its in your telephone wires, try check it with a liscensed technician of your telephone company.Maybe the wire threads are broken or even worn out.
    Jan 30, 2008 | HP Compaq Presario Media Center SR1750NX...
    Medicom phone No dial tone
    1podinker, you have a phone off the hook or a bad phone line. Plug a phone into the back of the modem and see if it works.
    Bamachicky, need more info on what your modem lights are doing.
    Dec 18, 2007 | Arris Touchstone 450a (CM450) Modem
    HP Vs17 17" LCD Flat Panel Monitor Logo
    173 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
