Question about Sony UP DR100 Thermal Photo Printer
UP-DR100 Error 0008 problem
When I power on the printer, it sounds like the cutter gears are grinding, then it reports "mechanical trouble error 0008". Assuming the problem is with the cutter, is it a user serviceable part, or is thier an adjustment I can make?
Thank you in advance for your help.
  • billycd1 Mar 17, 2008
Problem: The Printer does not detect the Reverse position of the cutter during initialization.
Either there is a scrap piece of paper obstructing the path of the carriage that houses the cutter blade or more than likely impact on the lower left side of the printer causing a bend in the metal that holds the Reverse switch.
This switch will trigger a sensor telling the printer that the cutter has reached the Reverse position(left side)
The grinding noise is caused by the cutter carriage rubbing on the inner side of the door panel. The door panel shifted inward and is obstructing the path of the cutter blade.
Solution:Replace the door panel and check for damage on the left side of the cutter blade path and bend the metal piece to realign the switch so that the plastic carriage makes contact when reaching the left side. Or replace the whole cutter blade assembly.
Any replacement parts can be ordered from imagingspectrum.com.
Posted on Apr 02, 2008
C350 grinding noise does not power up
Open the right door and remove the fusing unit and turn ON the copier.If the copier turn ON and the error code displayed the problem in the fuser drive transmission mechanism(gears),if not working remove the rear cover and verify the main suplly unit and the main motor.
Mar 20, 2013 | Konica Minolta bizhub Office Equipment &...
Mecha trouble problem cutter pos
- in my case I received the error "mecha trouble cutter pos"
I removed both side panels and the panel directly in front of the cutter
this gave me access to the cutter assembly where I found that the cable that runs the cutter had fallen off of the pulleys.
I was able to get the cable back onto the pulleys and now the printer works perfectly
Feb 20, 2012 | Sony UPDR150 Thermal Photo Printer
I'm getting a "Mecha Trouble
checking the gear by taking off both side panels and the panel directly in front of the cutter helped me - in my case I received the error "mecha trouble cutter pos"
problem was, the cable that runs the cutter had fallen off of the pulleys and after a bit of fussing, I was able to get the cable back in place and a working printer.
Sep 15, 2011 | Sony UPDR150 Thermal Photo Printer
Scanner error - I've plugged in, reset partial, reset semi, disassembled and cleaned bulbs (both working) and optics, moved to different outlet, checked power supply, put unit in warm room, but still get...
On the top of the scanner mechanism, there is a black tab that gets caught on the underside of the scanner surface, just beyond the glass, towards you. You will hear a gear grinding sound, that"s the tab getting caught. either bend the tab down, or remove it. Its on the black cover that"s on top of the scanner mechanism. Also remove any tape that is on the bottom of the trailing cable under the scanner that prevents it from moving all the way to the left.
Feb 05, 2010 | HP OfficeJet D135 All-In-One InkJet...
Grinding after cutter autcuts. Single error light flash.
The cutter mehanism needs to be cleaned out. Take the priner for a service at your local service agent.
Aug 13, 2009 | Epson TM T88 Thermal Printer
Mecha Error 0005
oooohhhh k
1) when you turn the printer on does the printer make a lot a noise and then display "ready"
-If not there may be mechanical issues with your printer
Nov 13, 2008 | Sony UP DR100 Thermal Photo Printer
Error #80
I sounds like the cutter is jammed. This most likely was caused by a some tape getting caught in the cutter mechanism or by a build-up of adhesive on the cutter blades. The noise is most likely the cutter trying to actuate and not being able to. The solution is to clean the cutter to remove any debris and adhesive. This is normally done by a service technician and thus requires sending the printer to Brady. You can get faster service that costs less by having the printer cleaned by Graphic Products. They provide a full cleaning and diagnostic service, and can repair many problems. You can contact Graphic Products at 1-888-326-9244. They are also very nice about answering any questions you may have about the GlobalMark.
Oct 28, 2008 | Brady Globalmark MonoColor Label Printer
Sony up-dr 100 error 0007
This may well be a failure of the cutter switch sensor to reset. This worked for me.
Turn Off the Printer.
Remove both side panels and the plastic panel on the INSIDE of the DOOR on the right hand side. Then close the door and remove the plastic panel UNDER the door. This is held in place by two screws.
You will see a white gear on the bottom right hand side of the door. It is on the underside of the door. Turn this gear untill you can see the cutter move smoothly across the bottm of the door and return to the right side of the door. Listen for a click. This is the switch resetting. Close the door and power up the printer if you still get an error code 0008 or 0007 repeat the resetting process by turning the gear. BE SURE TO TURN OFF THE PRINTER!!
Dec 11, 2007 | Sony UP DR100 Thermal Photo Printer
Error message
Problem: The Printer does not detect the home position of the cutter during initialization.
Either there is a scrap piece of paper obstructing the path of the carriage that houses the cutter blade or there has been an impact on the lower side of the printer causing a bend in the metal that holds the home switch. This switch will trigger a sensor telling the printer that the cutter has reached the home position(right side)
Solution:Remove the paper scrap or Remove the door panel and check for damage on the right side of the cutter blade path and bend the metal piece to realign the switch so that the plastic carriage makes contact when reaching the right side.
Nov 30, 2007 | Sony UP DR100 Thermal Photo Printer
PRINTER ERROR
There is a tiny little magnet that falls off and/or has reportedly been put on backwards (fell off is what happened to me) on the auger assembly. It's near the black auger chute on the end of a shaft. It's tiny--a little bigger than a grain of rice. I had to replace the auger shaft assembly but if you can find the magnet, you can super glue it back on.
Apr 03, 2007 | Xerox Phaser 7400/DXF Laser Printer
Sony UP DR100 Thermal Photo Printer Logo
187 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
