Question about HP Compaq FP 7317 17" Flat Panel LCD Monitor
Gateway monitor I have a blue pinstripe coming down the screen, my 21inch lcd panel is a year and a half old
I had the same thing happen with a new monitor. It was there about 4 days when I discovered that a window had been shrunk down the height of the monitor leaving a blue line.
Posted on Sep 23, 2008
    Genius:
  • 1,554 Answers
Its a separation of the connections between the drivers and the lcd panel.
its a fancy glue that only techs know how to get.
and even that may not fix it.
it may be a failure of the driver itself.
A well placed bang may fix it temporally.
only way to tell is to get a replacement screen.
I would just sell it on ebay you might be surprise how much it fetches.
Posted on Feb 02, 2008
Gateway FPD 1730 (mfg June 2004) On start-up, monitor flashes bios screen for less than half a second, then flashes the Windows XP logo for less than half a second and then stays black, no image. No...
All support is finished for XP years ago. The system is 13 years old and well past it expected life. Average is 8 to 10 years on a shop bought unit like Gateway, 12 years on a custom build.
I am thinking you probably have a dry joint on the board behind the switch as holding the switch makes the monitor work.
My advice though is a new computer running Windows 10, technology moves on in hardware and software.
Mar 08, 2017 | Gateway FPD 1730 17" Flat Panel LCD...
Grainy colors
i have had the same problem with the Gateway LCD Monitor and have found a solution, First go to your control panel Secong there will be a program appearance and theme there you will find something that says screen resolution click it and adjust the color scheme to 1152 by 864 pxels.
May 17, 2010 | Gateway FPD2275W LCD Monitor
My 15 inch Dell LCD flat screen monitor has 4 blue (cyan) verticle pixel bands about half an inch wide on my screen. The monitor is about 3 or 4 years old. Can you help?
Sorry, but it's kaput. Broken. LCDs were pretty bad a few years ago. A new one will cost a lot less than that one did, and will work a lot longer.
Oct 01, 2009 | Dell 1505FP 15" LCD Monitor
My gateway fpd1975w tft lcd monitor does not work. the power button just flashes blue and nothing comes on. i put an old monitor to my computer and it worked fine, and i hooked my monitor up to an old...
Restart the PC and get into SAFE MODE. Hit and release F8 many times right after turning on PC. If it works, then go into your video setting and either change the settings or remove the video driver. Restart the PC and you'll get 800X600 screen, then reinstall the video drivers. IF it won't go above 800X600, screen internals are bad, LCD toasted. I've seen that happen with LCDs and older monitors.
Jul 05, 2009 | Gateway FPD1975W 19" LCD Monitor
LCD went dark
hook it up to another monitor then control panel then display see i8f something was changed in there
otherwise your screen may have gone but it's only two years old
what were you doing when you lost your screen
Jan 14, 2009 | Gateway MT6707 Notebook PC
Right half of screen blanks out
Hi...there,
Well... after 3yrs of used, it's time to retired. You've got a busted panel...
Dec 01, 2008 | Philips 230W5VS (Silver) 23" LCD Monitor
LG lcd computer monitor
try to connect your old monitor and adjust your screen properties down to 800x600 with medium color setting..or go to xp safe mode, adjust screen properties to the lowest setting, xp has not yet installed the monitor driver of your lg lcd monitor.
May 21, 2008 | Gateway FPD2275W LCD Monitor
Monitor will not stay on
Same boat 1.5 years old and the screeen will shut down in about 1-3 seconds as long as i turn it on.
Mar 31, 2008 | Gateway FPD1975W 19" LCD Monitor
Autiovox lcd Half the screen turns blue the other half has virtical lines in it.
Typical of the glue that holds the circuit to the screen coming loose.
it will take a very good repairman to fix this and he will have to know where to find the glue, its special with microbeads embedded.
Mar 03, 2008 | Televison & Video
One half of monitor goes out while viewing it
the best way is to disassemble the monitor, remove the lcd assembly and check the micro-ribbon to the lcd panel
Mar 09, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
HP Compaq FP 7317 17" Flat Panel LCD Monitor Logo
95 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
