Cell Phones Logo
Posted on Dec 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Zire 72 resets on its own - Cell Phones
Anonymous
Level 3:
President:
  • Master 3,278 Answers
  • Posted on Dec 31, 2009
Anonymous
Master
Level 3:
President:
Answers
3278
Questions
0
Helped
784664
Points
9440
Hello.
First, if you have not done so, perform a soft reset then a hard reset, if still a problem.
If a problem after the resets, your battery is most likely the culprit. I'd suggest to remove / insert or totally replace the battery.
If you are comfortable disassembling the Zire 72, here are some instructions found online:
http://www.macslab.com/charlies/Zire72Batt.html
Hope this helps.
Palm zire 72 will not syn with pc running win 8.1
You find a fix to that problem, and the (Palm) world will beat a path to your door. HP, Palm's new owner, has attempted a fix for Win7, but Win8/8.1 may become the impossible hurdle.
How can i install my palm up to the computer without the software? where can i find it?
Hello, Rosilin.
No problem. Here's the link for your Zire 72. You just need to choose Windows or Mac and download and install the Hotsync Manager software.
http://kb.palm.com/wps/portal/kb/na/zire/72/unlocked/downloads/page_en.html
Hope this helps.
How to insert a sim card into my Palm Zire 72
No sim card in the Zire 72. On-board memory on the motherboard only to store records not directed to or on expansion memory card.
Zire 72 battery changeout not designed to be user serviceable. Undertake at your peril (unless you are very steady handed, patient, and very very careful). The 72 is probably the most difficult of the Palms to change batteries. Go to: http://forum.brighthand.com
Navigate to the Zire 72 section and read the posts. There are even detailed photos and uTube movies that deal with changing the battery. I have used their forum for years. Lots of help there.
3helpful
3answers
Ready to change battery in zire 72s
Here is a video I found on replacing the Zire 72 battery. I hope this
helps.
Zire 72
On your disk, go to the post install folder and run the outlookswitcher.exe, this will let you switch to the outlook conduit
Zire 72 Molex ribbon cable
TRY THE FOLLOWING WEB SITE
http:www.thepocketsolution.com/PSI-44850/Tungsten.html
AHHHH!!!!
Just had the same thing- I blew out the plug port and re-plugged it in, charged for an hour, and now it turns on.
Zire 72 does not recognize the SD card
Have you used this card long and what size is it?
Fatal exception error
hold down the up button and use a paper clip or tip of your stylis to reset, do both of these at the same time.
No mail app/client found on my Palm Zire 72 :(
Pop the CD in again and look under the CD Extras.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
