Question about Frigidaire GLTF1670A Front Load Washer
Brown streaks on clothes
After a wash some clothes will have a brown streak on them, this same streak will wash out the next time in the wash. There are no other obvious signs of trouble with the washing machine.
  • 2 more comments
  • terra22 Feb 02, 2008
    I am having the exact same problem.
  • beloquent Feb 07, 2009
    I have the same problem... goes in white comes out with brown streaks..tey wash out the next time ifI treatthe spot.
  • tootsa May 12, 2009
    brown streaks on clothing after washing in frigidaire front load machine.
    really shows on whites. I always use HE detergent. Why am I having this problem??????????????????
  • leo2 May 11, 2010
    Hi , how many years the machine works.
Are the streaks on smaller pieces of clothing (socks, etc.)? If so, the clothing item might be getting caught inside the rubber gasket around the door, and getting the streak from there. Try cleaning inside the fold of the rubber gasket very well, and often and see if it keeps happening.
-Ellie
Posted on Feb 12, 2009
    Sergeant:
    Novelist:
  • 176 Answers
The bearings on the back of the outer shell, the ones that spin the was drum, are finished. There is also a seal on the inside of the shell that keeps water from leaking and it is leaking also. As a result the brown grease from the bearings is seeping past the seal and contaminating your wash. You need to replace the bearings and seal to fix the problem. You can go to your local appliance store and order the rear half of the outer shell for about $230.00 and have the same problem in 4 years. Or you can buy the bearings and seal at a bearing supply store for about $80.00.
The part numbers neede are:
Seal #408010 DAE (vulcanised double lip seal)
Rear bearing 6308 (sealed bearing)
Front bearing 6307 (sealed bearing)
The bearings to buy are made in Japan. If you buy cheep China bearings then you are asking for trouble because that is what was in your machine to start with. Timkin and *** are 2 of the best made bearings.
To remove the bearings you can use a hammer and a metal punch. To install them use a hammer and a 2X4 on end and be careful not to damage the bearing. This is easy to do.
An appliance repair shop will charge you the price of a new washer to do this repair. The choice is yours.
Posted on Feb 08, 2009
    President:
  • 1,294 Answers
Click on "tags" above on this page, "brown streaks on clothes" you will see a lot of solutions. The bearing problem it is.
Posted on Mar 14, 2008
Brown streaks on white cloths?
Hi Ralph,
It may be important to have an idea as to what caused the stain/discoloration. Carbona (http://www.carbona.com/home.php) has different products specific to the various reasons for the problem. You may be able to use bleach, depending on the fabric affected. Some white material turn yellow with bleach
Hope this helps ~ Good luck!
Alexander
Mar 02, 2015 | Kenmore 45081 Front Load Washer / Dryer
Brown streaks on my clothes after washing them
O.K. Here it is, I solved it. After calling whirlpool who was of no help at all, reading all links about the Duet washer and/or the Duet dryer, I finally solved the problem myself. I too, thought it was the washer but, upon close inspection, found the felt on the dryer had worn out in one spot. The thin brown lines always showed up on whites and more so on anything very thin. I took the dryer apart and found a small burn line on the drum (brown and thin). I replaced the felt ($60) and used Simple Green to clean off the brown. Works perfect, no more thin brown lines. If you can't take the dryer apart, I called for repair and found the price with parts to average $250.
I was ready to sell the darn thing after it ruined about $300 worth of clothes. All in all, it's been three weeks and still working fine.
May 19, 2010 | Washing Machines
Same thing
Liquid fabric softners usually cause spots and/or marks on light colored clothing . If you rewash the clothing and the marks dissapear , then try using dryer sheets instead . However , if you have an older dryer , then clothing could be getting rubbed between the rear drum seal and panel , but that would cause streaks but no spotting .
Jul 26, 2009 | Washing Machines
Whirlpool Duet Washer/Dryer get brown streaks on clothing
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
do you have the matching dryer on the earlier models they didn't use a seal on the drum and once the paint rubbed off they left brown rusty looking marks on the clothes
Jun 29, 2009 | Frigidaire ATF6000ES Front Load Washer
Brown streaks on white clothing in front loading washing machine
more than likly it is coming from the dryer. get a paper towel or a towel and run it between the inside of the drum and the front where they come together. stick it through the slot and run around the drum. do the front then do the back see if you see the same streaks. and let me know thanks
Jun 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stains on clothes after washing
This sounds like the infamous "Frigidaire Flaw" (they make some of GE's washers). The likely culprit is that the bearings on the drum's spindle are leaking.
To diagnose, call a repair man, or pull it out and remove the back cover. If you see brown streaks from the center spindle - that's it.
Repair is cheap if you can do the work yourself (inner and outer bearings), but $300+ for a technician
Feb 09, 2009 | GE WPXH214A Front Load Washer
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
Check an earlier post of mine. This problem was killing me and Whirlpool was of no help at all. They claimed to never have heard of these thin brown streaks. Well, it was the dryer and as proof, I found where the thin brown lines were coming from. The felt had worn out in one spot allowing thin, whites and other thin items to slide in between the drum and the backing, resulting in the transfer of a thin brown line randomly on my clothes. Replace the felt (rollers and bearings if necessary) and with the drum apart, clean off the burnt brown streak of the backing with Simple Green. No more problems.
Aug 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
927 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
