Question about Daewoo KOC-925T Microwave Oven
Failure in micro.
The oven work but the magnitron very hot after 1 time working the sconde timeof working it make of and does not continue
note:the fuse 700ma was burn 1st time of the problem
pls, advice
with best regard
Microwave is not heating is there any solution
Posted on Feb 28, 2009
  • Daewoo Master
  • 9,086 Answers
It's very important that the cooling fan is operating.
If it is, then you have a defective magnetron.
You can contact Magic Chef for parts here: http://www.mcappliance.com/contactus/contactus.asp
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 04, 2008
Microwave not getting hot at all everything else working
call a service man probably the magnitron tubes have failed
Feb 26, 2015 | Microwave Ovens
Kenmore 1000w Not Heating Food Items
If it sounds like it is running and it lights up it is not the fuse. In my 24 years of service work I've found that the problem you are describing is cause by the failure of the magnitron ( The device that emits the microwave radiation). As your unit is a built in expensive unit I would look into replacing the magnitron. In cheap microwaves I just suggest replacement. If you need further assistance locating a replacement magnitron feel free to cotact me. It is a relatively easy part to replace. You just open the case and unplug it, unscrew it from the unit, and replace it with the new one. In most cases all you need is a philips head screwdriver and some patience. Anyway, I hope this helps you out in your decicion.
George
Jul 19, 2008 | Kenmore 62642 / 62644 / 62649 Microwave...
Microwave wont heat?
door interlocks micro switches
a duff relay on the control board
bad magnitron heaters {connections inside come adrift }
bad EHT to the magnitron
Aug 12, 2014 | Microwave Ovens
Magnitron does not go on unless i run the vent fan
HELLO.
The solution is to test the magnetron as explain below.
* 1 Fill a mug with room temperature water from your kitchen sink.
* 2 Place the mug of water on the glass cooking plate inside the microwave.
* 3 Set the microwave on "High" for one minute and press "Start." You should hear the magnetron hum while it is working.
* 4 Remove the mug carefully from the oven by its handle. The magnetron is working properly if the water is hot or warm. Contact the manufacturer for repair or a replacement oven if the water is still cold.
Thanks
Sep 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave will light up, the buttons work, but no heat to cook food
Your magnitron tube is out (it makes the micro waves) If you are handy you can switch it out for around 100-150, go to marcone.co to get the new mag tube
Nov 11, 2009 | Frigidaire FMV156DC Microwave Oven
Microwave will count down the time but will not heat up
Only one thing heats in micro wave. If every thing works but heat, sounds like you have a bad mag tube. (Magnitron)
Sep 02, 2009 | Kenmore 62622 Microwave Oven
My jvm1540 microwave runs fine but just stopped heating. Only 1 year old. Help.
If your micro looks like it is running and you get no heat than it is your magnitron tube. This is the most expensive part of the micro, if it is in warranty GE will fix it, if not it will be cheaper to replace it.
Jul 08, 2009 | GE JVM1650 1000 Watts Microwave Oven
KitchenAid KHHS179lss, fried magnitron?
If your magnetron was shorted, the unit would not heat at all.
The sound of a shorted magnetron is usually a loud hum-- but no or very little smell and no smoke.
Components in the High Voltage section -capacitor, diode- give problems if they short out.
Feb 17, 2009 | KitchenAid KHHS179LSS Convection /...
Everything works except it doesn't heat anything
no, just 1 main fuse for everything. there are temp safety devices though, and door closed safety switches. Most likely failure though is the magnatron.
Dec 30, 2007 | Kenmore 64002 Microwave Oven
Daewoo KOC-925T Microwave Oven Logo
70 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
