Question about GN Netcom GN 9120 Professional Headset
GN Netcom GN 9120 - can't hear
Hi, my headset rings when there is an incoming call, but once I pick up, I can't hear the other person. However, the other person can hear me perfectly fine. I can actually hear myself through the headset, but I just can't seem to hear the other person. Is there a solution to this? Thanks!
  • 1 more comment
  • Anonymous Jun 09, 2008
    hi,
    When I use the headset, there's a slight echo and the person on the other end can barely hear me. How do I fix this?
    thanks.
  • gn9120 help Jun 09, 2008
    hi,
    There's a slight echo when I use my headset and the other party can barely hear me. How do I fix this?
    thanks!
  • Anonymous Oct 13, 2008
    We have a GN9120 doing the same thing
Hi There, I had the same problem with a headset one of our call centre reps were using. It's usually due to some one fiddling with the button. I got it working by removing the battery from the headset then resinked the headset to the base unit. Hope it works for you
Posted on May 19, 2008
  • Ohitworked Jun 15, 2011
    I had the same problem, everything was working but no sound. Called the help desk, after about 10 minutes of do this do that, his solution was to upgrade to a newer model $$$$, Then I went online and found your advice. I removed the battery and...It worked. Yippee! Thanks
Is a replacement battery available for 9120 I've used for a number of years?
GN Netcom probably would know. If you can identify the battery type, you can try obtaining a replacement from some other source.
Jul 07, 2014 | GN Netcom GN 9120 Professional Headset
I have a gn9120 headset that i love. suddenly, callers are complaining that they can't hear me. Is there volume adjustment or is there a defect?
Volume adjustment is made by depressing the two + and - together until beep is heard
once beep is heard press the + button several times until louder bleep is heard this will increase transmission from headset and cure the problem
Steve
Jul 15, 2009 | GN Netcom GN 9120 Professional Headset
No sink?
Yap i did solve the issue, thanks
May 27, 2009 | GN Netcom GN 9120 Professional Headset
GN 1000 lifter/GN9350 headset with Nortel NTDU92 phone
I was wondering if you had installed the external ring sensor, this sensor most be over the telephones speaker, if the speaker isn't under the handset. hope this can help.
Feb 19, 2009 | GN Netcom GN 9120 Professional Headset
Battery Light Won't Go Solid. Lot's of clicking sounds and lights flashing (GN Netcom 9120).
It sounds like it may be a defective unit in that the charging points on the base and the earpiece are making intermittant contact, hence the clicking noise you get when the unit goes into headset mode and the fact that the battery never reaches a fully charged status.
A couple of things to try:
  • Check the charging points/contacts on the base and the earpiece for damage.
  • If they look ok, gently clean them with some spirits and try again.
Nov 07, 2008 | GN Netcom GN 9120 Professional Headset
GN Netcom 9120 unexplained beeping
Actually what she was hearing was the ring tone in her headset when a incoming call comes in. The sensitivity on the handset lifter that picks up the ringing on a incoming call was set all the way up and was picking up interferance from the headset base as they have the tendency to buzz when placed right next to the phone. I just turned down the ringer sensitivity with the adjustment on the handset lifter and that took care of the problem. Thanks for your time.
Nov 06, 2008 | GN Netcom (9120-48) Wireless Headset
Incoming alert
Generally you will get a ring in the headset when a call is detected by the lifter that you use or if you don't have a lifter then you would have to use the little microphone that comes with the unit and affix that to the speaker on your phone so that your GN 9120 knows when to alert you of a call.
Aug 31, 2007 | GN Netcom GN 9120 Professional Headset
GN Netcom GN 9120 Professional Headset Logo
1,312 people viewed this question
Top GN Netcom Radio Communications Experts
TO Lady
bigdawg7299
Tom Chichester
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
