Question about Brother IntelliFax-2820 Laser Fax
Brother MFC 4450
Can only receive faxes - Cannot send faxes
error reads:
scanner error
online
    Scholar:
  • 78 Answers
The majority of Brother machines will usually not recieve when they have a scanner error. So your lucky.
Under the top cover where the original goes you will see a glass strip (this scans your original). It should light up when the machine is powered on. If not this item has most likely failed. I have seen it before where rust around the contacts have caused it to not work and after cleaned the contacts it did work but usually it just fails.
Another way to checkif the machine will let you is to do a copy. If it comes out black it means the scanner has failed. It should be a relatively cheap repair if it has.
Posted on Jan 30, 2008
6ya staff
SOURCE:
Scanning and copying are slow and have a dark background
you probably have a bad power supply weak capacitors do this
35 years experience here
Apr 11, 2014 | Brother IntelliFAX Office Equipment &...
Unable to send, copy or send fax
Sounds like the scanner bulb is burnt out or it's not able to move the scanner sled.
It should be saying "scanner error" as well. (and I think you meant unable to scan, copy or send fax)
No fix unfortunately other than getting a replacement unit (which I believe now is the 8500 premiere)
If you need a replacement, your timing is good, they are $200 off right now, and selling for $299.
Your unit as it stands still makes a good printer and will receive faxes, and you CAN send a fax as long as you do it from the computer.
Feb 28, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Although I read the manual, I cannot figure out where or how to clean the scanner which I assume is where my problem is. I only get vertical lines when copying. Faxing is fine. Can you help?
Faxing is fine , when sending or receiving ?
any way I do not think you need to clean the scanner . if you can send a fax and other party can get the fax your scanner is ok . If not you need to replace the scanners light which is a glass looking bar close to your document feeder
Oct 25, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Fax sent is blacck
your CIS or scanner is faulty
this unit is the one that reads your original document that you are sending.
It will probably need to be replaced
Aug 08, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
C6180 FAX UNABLE TO SEND OR RECEIVE
check the the phone line, The fax sinal need good clear. Surely,plug the phone-line is rigth line socket. If you do that all, the broblem is still happenning,need to change "relay" on moderm fax board.
Jul 27, 2009 | HP Photosmart C6180 All-In-One InkJet...
Can't send faxes. Dials Ok but no connection to send fax
If you are unable to send the faxes, please try decreasing the modem speed and disabling the "Error Correction Mode." To decrease the modem speed, please follow the steps given below:
1. Press the "Fax" button.
2. Press the "Options" button 15 times till it reads "Advanced Fax" on the display.
3. Press the "Select" button.
4. Then press the "Options" button 10 times till it reads "Max Send Speed."
5. Now press the "Right Arrow" button and choose "9600 bps."
6. Press the "Select" button.
To disable "Error Correction," please follow the steps given below:
1. Please press the "Fax" button.
4. Then press the "Options" button 11 times till it reads "Error Correction."
5. Now press the "Right Arrow" button and choose "NO."
May 19, 2009 | Lexmark X4270 All-in-One Multifunction...
Can send faxes but cannot receive - shuts off after 2 rings
Apr 19, 2009 | Lexmark X4270 All-In-One InkJet Printer
Brother mfc 8220 gives error message check original but no paper jam exists.
I assume you're getting this error when sending a fax?
Check original is not a paper jam error. This can happen in the winter due to bad noise on the phone lines. When you send a fax, you can get this result from the receiving machine due to noise. The receiving unit will transmit the error back to the sending unit.
The unit is basically asking you to check the quality of the original document. 90% of the time, there is no problem and the receiving unit actually got a good copy. However, sometimes due to noise on the line the receiving unit will get a poor copy of the fax. In this case the fax should be resent. Of course, since there is no way for you to determine how good the copy is at the receiving unit, in most instances you will have to resend the fax to make sure it goes though.
If, however, you are getting this message while copying (very unlikely) you can do a simple test of the document scanner that should reassure you that there is no serious fault, or pinpoint the actual fault.
Press the following key sequence within 2 seconds: MENU, *, 2, 8, 6, 4. If your unit has a FUNCTION key, use it in place of the MENU key. This should take you to maintenance mode. The display should say MAINTENANCE and all the lights should be flashing. If not, try unplugging the unit, press and hold either the MENU key or the FUNCTION key (depending on which your unit has) and plug the machine back in. This will also take you to maintenance mode.
Now, just press 5 5. This is the scanner area setting command, and if there is any problem with your scanner it will show up here as an error. If there is no fault with the scanner, the unit should return to maintenance mode in a moment. Once done, press 9 9 to exit maintemance mode.
If you are constantly having this error, get a phone repairman in to test your fax line.
Feb 06, 2009 | Brother MFC-8220 Fax
Black page when copying and sending faxes.
You most likely have a bad SCANNER BLOCK. Not good!
Dec 23, 2008 | Brother IntelliFAX 4100 Laser Fax
Sending a legible fax
THE CIS SCANNER /REFERENCE WHITE NEEDS CLEANING AND THE CIS TRAINING NEEDS TO BE DONE.
IF ABOVE DOES NOT HELP U NEED TO REPLACE CIS .
HAPPY FAXING
OMNIPRESENT
Oct 16, 2007 | Office Equipment & Supplies
Brother IntelliFax-2820 Laser Fax Logo
82 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
