Question about Dell Latitude C600 Notebook
S-video not working with TV
Everything is hooked up alright. The image only appears for a few seconds while booting up then the image disappears. Is there a configuration problem or is the image signal not compatible with the tv input circuit... how can I solve any of these problems?
THX....
Omar
I was having the same problem as you before. Follow this and you'll be set. First go to http://drivers.softpedia.com/get/GRAPHICS-BOARD/OTHERS/Dell-Latitude-C600-ATI-Mobility-Graphics-Driver-A03.shtml
download the driver and install it. You will be prompted to reboot. After restarting right click desktop, click properties, select settings, then advanced, then turn on the TV option. Good luck, this work miracles for me.
Posted on Oct 16, 2008
  • 4 Answers
If its a dell laptop ,press the Fn key and then press the F8 key twice to get the screen on TV or else i recomend u to get a VGA cable instead of s-video cable .
Posted on Apr 03, 2008
I know this is a old thread but i was having this problem. Set display to a 800x600, turned overlays off. Used the fn keys, none of it worked for me. laptop had 7 pin s video, tv had 4 pin. what did work was turning hardware acceleration off and restart the computer.
Posted on Mar 30, 2008
Go to control panel click add remove program, delete the previouse program for the camera then restart. To install the new driver right click the my computer click properties, hardware,device manager after that try to find the accessories for the camera then you notice the driver have question mark. double click, then install the driver.
Posted on Feb 06, 2008
  • 589 Answers
Look at your Function keys. It will be either F3, or F5 depending on model. Just look for the key with the picture of a little monitor on it. Some models use 2 different keys to go back and forth between outputs. These keys toggle the video between the laptops LCD and an external monitor.
Hold down the "FN" key (located on the lower left of the keyboard), while tapping the above mentioned Function key.
Posted on Jan 30, 2008
My Samsung tv has sound but no picture what needs to be replaced?
Hi Shawn,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Apr 27, 2015 | Samsung Televison & Video
No image and audio for a few seconds
Your TV has symptoms of power supply trouble.
Nov 21, 2013 | Sony KDF-E55A20 55 in. LCD Television
While streaming Netflix from my laptop (via S cable) to my RCA TV, the image on the TV is black & white. Whether streaming or not, when I hook up my laptop to the TV, the desktop image on my laptop...
If the cable is damaged then one of the pins can be bent inside or if it unscrews a solder connection may be undone. see the photo showing color on the left and bw on the right. Also plug everything in turn off everything then turn on the computer and then turn on tv. also try just opposite turn on tv and reboot computer.
Go to Bing homepage Video Wikipedia SVIDEO TV BLACK AND WHITE SCREEN Graphics Cards
Nov 12, 2017 | RCA F32649 32" TV
My LN-S4095D (3 years old), only works for about 30 to 60 min, and then the picture disappears and the sound stays. If I turn it off for several hours or till the next day, it turns on back with picture,...
Hello Dsidneysis,
It appears that this failure could be in the power supply due to swelling/ bulging capacitors in the power supply.
Check the link below to find parts to fix your TV.
May 25, 2017 | Samsung LN-S4095D 40 in. LCD HDTV
Caution screen image may appear reversed
hello, when i turn on the cd.player, in just few seconds this text comes: caution screen image may appear reversed(and the screen is black)....when i touch the screen with my finger, it disapperes for a few sec. what is this??
Sep 27, 2009 | Pioneer AVH-P5000DVD Car DVD Player
I am trying to connect a Sony Trinitron TV and HP Pavillon laptop through the S-video cable. I press FCN F4 and the image appears in the TV, but it only lasts for 1 second, then it disappears..As if the Tv...
yes lower the resolution. it would also depend on the age of the TV and whst vresolution it can handle Some of the newer ntv's can be varied to accept sevral resolutions so as to be able to play games etc.
Jul 27, 2009 | Computers & Internet
A blank black box appears midscreen
need to turn off close captson off hope i speled that right.
Feb 28, 2009 | Toshiba 36A50 36" TV
Wii image gone
try connecting to a tv that supports 60hz. But you should read up on this stuff before you do anything like that again. Understand , understand? alright! but do not do anything like that again!
Dec 27, 2007 | Nintendo Wii Console
Black square covering up most of the screen
Try goeing into your Menu and see if you have the closed Caption on that will produce a black box on the screen if you have the owners manual look in there,if you don't have it you can go on line and download it from the manufactures website under Downloads Good luck Walter Grzybowski
Sep 17, 2006 | Philips 60PP9202 60" Rear Projection...
Dell Latitude C600 Notebook Logo
260 people viewed this question
Alun Cox
