Question about One For All URC-4330 Remote Control
Prog. indicator light
While trying to prog. my remote control, it indicates to press & release the key(TV) the indicator light should blink and then remains lit, it does not remain lit for me to enter my code.
  • 1 more comment
  • pjgranado Jan 31, 2008
    I have done every step per the instructions and this step does not work, could it be a malfunction on device?
  • pjgranado Feb 04, 2008
    Did all of the above as instructed but nothing works.
    Thank you for trying.
    pj
  • Patrick Stallings May 11, 2010
    Usually you have to press and hold the setup key first until the light comes on, and then press the device key you want to setup. Is taht how you're doing it?
  • 77 Answers
This is what one for all's web site says to do:
1. Turn on the device you want to set-up (ie: TV, DVD, etc).
2. On the remote control, press the device key for the device to be set-
up. For example, to set-up a TV, press the TV key; to set-up a DVD,
press the DVD key, etc.
3. Press the "SET" key and hold until the small light ("LED") on the
remote control blinks twice, then release.
4. Enter the Code for your device. If you've done it correctly, the "LED"
light will blink twice. (Note: 'Codes' are listed in the instruction booklet).
5. Press the "POWER" key and the device will turn off. It doesn't say the LED should stay lit after pressing TV here.
Try this and let me know at which step the remote programming breaks down.
Posted on Feb 01, 2008
How to program a rcr804bfdr to a sanyo tv
Programming the RCA RCR804BR or RCR804BFDR Series Remote Control
Programming with Direct Entry:
To program your remote to control up to four components, follow these steps:
  1. Manually turn on the component you wish to program the remote to operate.
  2. Find the four-digit code for your brand of TV, VCR, DVD, satellite receiver, cable box, or digital TV converter in the enclosed code lists.
  3. Press and hold the CODE SEARCH key until the indicator light turns on.
  4. Release the CODE SEARCH key.
  5. Press and release the TV, VCR or SAT·CBL·DTC key. The indicator light blinks and then remains lit. Note: DTC references digital TV converter. To program the DVD·AUX key: Press the DVD·AUX key. To control a DVD, press the VCR key. To control a TV, press the TV key. To control a satellite receiver, cable box, or digital TV converter, press the SAT·CBL·DTC key. The indicator light stops blinking and remains lit.
  6. Enter the four-digit code, using the numeric keypad. After the code is entered, the indicator light turns off. Note: If the indicator light blinks multiple times, you've entered an invalid code. Start from step 2 again.
  7. Aim the remote at the component and press the ON·OFF key. The component should turn off. Note: If your component does not respond, try all the codes for your brands. If the codes do not work or your brand is not listed, try the Code Search Method that follows.
Programming with Code Search:
If your TV, VCR, DVD, satellite receiver, cable box, or digital TV converter does not respond after you have tried all the codes for your brands, or if your brand is not listed, try searching for your code via the Code Search Entry Method. To program your remote via the Code Search Entry Method, follow these steps:
  2. Press and hold the CODE SEARCH key until the indicator light turns on.
  3. Release the CODE SEARCH key.
  4. Press and release the component key you wish the remote to control- TV, VCR or SAT·CBL·DTC key. The indicator light blinks once and remains lit. Important: Find the ENTER key on your remote (don't press it yet). You will need to press this key quickly in step 6 below. To program the DVD·AUX key: Press the DVD·AUX key, followed by the component key you wish the DVD·AUX key to control. For DVD, press the DVD·AUX key, followed by the VCR key. For an auxiliary component, press the DVD·AUX key, followed by the corresponding component key ( TV, VCR, SAT·CBL·DTC ).
  5. Press and release the ON·OFF key until the component turns off. Important: You may have to press the ON·OFF key up to 200 times.
  6. As soon as the component turns off, press the ENTER key within 4 sec- onds. The indicator light turns off. Note: If you wait longer than 4 seconds to press ENTER, the remote goes to the next code-you will need to start the code search from step 1 again.
Dec 24, 2014 | RCA Televison & Video
Need codes for philips universal remote to program to a deawoo tv
Hello
There is no set up code described in the manual of your remote control. But you can find out the code that stored in your device with this remote control handset. For that do the following.
The Code Identification Feature allows you to identify
the 4 digit library code stored under your device key. For
example, if you want to find out what 4 digit code is
stored under your TV device key, follow the six steps
below:
1. Press and hold the SETUP button until the red
indicator stays on. Release the SETUP button.
2. Press and release the desired mode button (TV,
VCR, etc.). The red indicator blinks, then stays lit.
3. Press and release the SETUP button. The red
indicator blinks off.
4. To find the first digit for the code stored under the
mode key pressed in step 2, press each numeric key
from 0-9 in turn. When the red indicator blinks off
the number you pressed is the first digit for the code
you are searching for.
5. To find the second digit, repeat step 4, this time
when the red indicator blinks off this is the second
digit.
6. Repeat step 4 to find the third and fourth digits.
Write these digits in order and you will get the code of your device.
Direct code entry mehod.
indicator stays on, then release the SETUP button.
3. Enter the 4 digit code from the code tables (on
separate sheet). Note: after a valid code entry, the
red indicator turns off. For an invalid code, the red
indicator flashes.
4. With your device on, press CHANNEL UP. If the
device responds, no further programming is required.
Note: If some buttons do not operate your equipment,
try one of the other codes for your brand.
OK.
Feb 19, 2011 | Philips SRU3003 Remote Control
Lost remote control. have universal RCA and
i found that your brand is not listed RCA code list,
your G&E remote is good one and easy to detect code for your tv.
solution
using your GE remote :
1. Turn on the device(TV) you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR LIGHT lights, then release.
3. Press and release the device(TV) button for the device you are programming . The INDICATOR LIGHT will
blink once then remain lit.
using your RCA controller:
1. Press and hold CODE SEARCH until the INDICATOR LIGHT lights, then release CODE
SEARCH.
2. Press and release the device button for the device’s code you are retrieving (TV,VCR or
DBS•CABLE). The INDICATOR
LIGHT will blink once then remain lit.
Note: For AUX, press DVD•AUX
then the device button for the
code you are retrieving.
3. Press and release CODE SEARCH. The INDICATOR LIGHT will turn off.
4. Starting with 0 on the keypad,
press the number buttons in
order (0-9) until the
INDICATOR LIGHT blinks.
5. The number which causes the INDICATOR LIGHT to blink is the first digit of your code.
6. Repeat step 4 until you have retrieved all three numbers in code
i hope this will solve your problem
regards,
cseian
Apr 22, 2010 | Durabrand DWT2704 TV
Need codes for rcr 460 remote
you want the remote to control
(TV, VCR, DVD, satellite receiver
or cable box).
Note: If you press an invalid key
during the Manual Code Search,
the remote does not respond and
the LED indicator light does not
blink. If you do not press a valid
Manual Code Search key (TV,
VCR, DVD, SAT·CBL, ON·OFF,
GO BACK), the search times out
after two minutes. When the
search times out, the LED
indicator light blinks four times
and turns off. The last
programmed code under that
component key is retained.
2. Press and hold the component key
(TV, VCR, DVD, SAT·CBL) you
wish to program. The LED indicator
light turns on and remains on.
3. While holding the component
key down, press and hold the
ON·OFF key. The LED indicator
light turns off.
4. After holding down both keys
for three seconds, the LED
indicator light turns back on.
5. Release both keys. The LED
indicator light remains on.
Throughout the
programming of each key, be sure
to keep the remote pointed at the
IR sensor of the component you
are currently programming the
remote to control.
6. Press and release the ON·OFF key
repeatedly until your component
turns off. Each time you press the
ON·OFF key, the LED indicator
light blinks, and the next code in
the list is sent. This process
continues until all of the codes in
the Code Lists have been searched.
If your component turns off, you
have found the correct code. (If it
cycles through and the LED
and turns off, all codes have been
searched. The Manual Code Search
method is exited.)
Press Stop when TV turns off.
Mar 06, 2010 | RCA Universal Remote Control
What is the code nomber for haier tv
You'll have to do a code search to program your RCA 3-in-1 RCU-703 Remote.
Turn on your Haier TV.
Press and release the TV key. The indicator light will blink once and remain lit.
Press and releae the OFF-ON key until the component turns off. (you may have to press the OFF-ON key up to 200 times)
When the TV turns off, press the ENTER key. The indicator light turns off.
Your should now be able to control your Haier TV.
Mar 01, 2010 | RCA Universal Remote Control 3-in-1...
I need a code for a rca and a coby remote controle
Sanyo. 1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180
1. Manually turn on the component you want the remote to control
(TV, VCR, DVD, satellite receiver or cable box).
2. Press and hold the component key (TV, VCR·DVD, SAT·CBL) you
wish to program. The LED indicator light turns on and remains on. If you release the component key any time during the Direct Code Entry
procedure, the LED indicator light blinks four times, and the process
is exited.
3. While holding down the component key, enter the four-digit code that corresponds to your component’s brand. While you are pressing the numbers, the LED indicator light turns off.
5. After the fourth number is entered, the LED indicator light turns on. At this time, release the component key.If the LED indicator light turns off, you have entered a valid code and have followed the correct procedure for Direct Code Entry. If you enter a code number that
is not in the Code Lists or you do not follow all of the steps for Direct Code Entry, the LED indicator light blinks four times when the component key is released. This is an indication that a programming error has occurred. In that case, repeat the Direct Code Entry process from step 2 and try the next code listed.
Dec 01, 2009 | RCA Universal Remote Control
Lost owners manual
I do not believe this is available on-line, but have some info that might help you use the remote.
To Search For A Code:
  1. Manually turn on device to be controlled.
  2. Press and hold the "Code Search" button until the red indicator light stays on, then release it.
  3. Press and quickly release the desired ode button (TV, VCR, etc.). The red indicator light should blink once.
  4. Press the "Channel Up" button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator light should blink off with each button press. If you accidentally overshoot the required code, press the "Channel Down" button to backtrack through the library until the device changes channel. Pressing "Channel Up" changes direction again.
  5. Press and release "Mute" button to install the code.
To Identify The Code That Was Found:
  1. Press and hold the "Code Search" button until the red indicator stays on. Release the "Code Search" button.
  2. Press and release the desired mode button (TV, VCR, etc.). The red indicator light blinks and then stays on.
  3. Press and release the "Code Search" button. The red indicator light goes off.
  4. To find the first digit for the code stored under the mode key pressed in "Step 2" press each numeric key from 1-9 in turn. When the red indicator light blinks off, the number you pressed is the first digit for the code you are searching for.
  5. To find the second digit, repeat "Step 4," this time when the red indicator light blinks off, this is the second digit in your number.
  6. Repeat again for the third digit in your code number.
I hope this helps out,
Chris
Dec 23, 2008 | Philips PH-DVD5 Remote Control
I'm missing the instruction manual for my RCA RCR460 remote control. I need the manual set-up instructions, and a list of all the potential codes to sync up to a Toshiba or Mitsubishi DVD player. Any help...
1. Manually turn on the component you want the remote to control (TV, VCR, DVD, satellite receiver or cable box). Note: If you press an invalid key during the Manual Code Search, the remote does not respond and the LED indicator light does not blink. If you do not press a valid Manual Code Search key (TV, VCR, DVD, SAT·CBL, ON·OFF, GO BACK), the search times out after two minutes. When the search times out, the LED indicator light blinks four times and turns off. The last programmed code under that component key is retained. 2. Press and hold the component key (TV, VCR, DVD, SAT·CBL) you wish to program. The LED indicator light turns on and remains on. 3. While holding the component key down, press and hold the ON·OFF key. The LED indicator light turns off. 4. After holding down both keys for three seconds, the LED indicator light turns back on. 5. Release both keys. The LED indicator light remains on. Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control. 6. Press and release the ON·OFF key repeatedly until your component turns off. Each time you press the ON·OFF key, the LED indicator light blinks, and the next code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code. (If it cycles through and the LED indicator light blinks four times and turns off, all codes have been searched. The Manual Code Search method is exited.) Press Stop when TV turns off.
Jul 06, 2008 | RCA RCR460 Remote Control
Philips pm 335 universal control
I found the manual for your remote control at:
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/philips/pm335-manual.zip&area=other
I looked for the code for a zenith tv and it looks like they're all 3 digit codes. It lists: 002, 008, 115, 215, 405, 407, 601, 701, 713, 903, and 916. If none of these work, I would suggest programming with the code search.
1. Press and hold "Code Search" button until the red indicator stays on. Release the "Code Search" button.
2. Press and release the desired mode button (TV, DVD, etc.) The red indicator will blink, then stay lit.
3. Press and release the "Code Search" button. The indicator light blinks off.
4. To find the first digit for the code stored under the mode key pressed in step 2, press each numeric key from 0-9 in turn. When the indicator light blinks off the number you pressed is the first digit for the code you are searching for.
5. To find the second digit, repeat step 4, this time when the indicator light blinks off this is the second digit.
6. Repeat step 4 again to find the third digit.
May 21, 2008 | Philips PM3S Remote Control
One For All URC-4330 Remote Control Logo
Top One For All Televison & Video Experts
S. Gontko
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
