Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Xerox C2424 problem (11,009:46 and 13,008.47)
Hello..
I have the captioned problems with my C2424. The first code refers to the harness and the electronics module. I do not know what the second code refers to.
The manual states to run some tests on the system. However, it does not give what the proper results for these tests should be.
Does anyone have any experience with these problems?
Thank you
Kevin Lee
  • Anonymous Jan 25, 2009
    Can't get the C2424 to print on both sides
Hola tengo una xerox work centre c2424 y me marca un error: 07.007.4022081 sistema ,y ademas me tranca papel al salir de la bandeja numero 2 y se queda trancado antes de llegar al tambor....de ay no pasa el papel ,porfavor alludemen a saber que puedo acer.email.well242008@yahoo.es, andres
Posted on Jun 11, 2008
CODE 70.010.43.43
CODE 43.70.11
CODE 04.025.46.7011
CODE 07.008.41.7013
WHAT ARE THESE CODE.
Posted on Feb 22, 2008
    President:
  • 2,072 Answers
The second fault is a result of the faulty electronics module. It is a print head heat related issue.
Question is, is the print head also faulty.
That electronics module is very expensive.
But the 11,009 specifically is a failure of the electronics module.
Have had those codes a couple of times.
Most likely the 50 volt source has failed, that maintains the print head heat.
A Drum Assembly thermal error has occurred. The following troubleshooting procedures apply to these errors:
Xerox C2424 problem (11,009:46 and 13,008.47) - arrwup.gif 13,008.47 The Drum Heater is too hot
Posted on Jan 30, 2008
  • 1 more comment
  • Rick Kasper Jan 30, 2008
    The troubleshooting table lists parts and wiring referenced in the troubleshooting procedures.
    Table 1. 13,008.47 and 13,010.49 Troubleshooting Reference Table
    Applicable Parts
    Wiring and Plug/Jack References
    Drum Fan, PL 4.0
    Right Side Harness / I/O Control, Figure 8
    Drum Assembly
    Electronics Module Power, Figure 7
    Drum Temperature Sensor, PL 6.0
    I/O Board (2/2), Figure 10
    Electronics Module Fan
    Left Side Harness (2/2), Figure 5
    Table 2. 13,008.47 and 13,010.49 Troubleshooting Procedure
    Step
    Questions or Actions
    Yes
    No
    Verify that the ambient temperature is within environmental specifications.
    Is the room within operating parameters?
    Go to Step 2.
    Advise the customer of operational requirements.
    Check ground integrity for the printer.
    Does the error persist?
    Go to Step 2.
    Complete.
    Is the error code associated with an overheat condition?.
    Go to Step 4.
    Go to Step 6.
    Check airflow at the vents.
    Is there adequate clearance, and are the vents clean?
    Go to Step 5.
    Clean the vents.
    5
    Test the Drum Fan
    Run the Service Diagnostics Drum Fan Motor test.
    Does the fan operate correctly?
    Go to Step 6.
    Replace the Drum Fan ( REP 4.0.6).
    6
    Test the Electronics Module Fan.
    Does the Fan operate correctly?
    Go to Step 7.
    Replace the Electronics Module Fan ( REP 4.0.15).
    7
    Test the Drum Temperature Sensor.
    Run the Service Diagnostics Drum Temperature Sensor test.
    Does the sensor operate correctly?
    Go to Step 8.
    Replace the Drum Temperature Sensor. ( REP 6.0.4).
    8
    Test the Drum Heater.
    Run the Service Diagnostics Drum Heater test.
    Does the heater operate correctly?
    Replace the Drum Assembly ( REP 2.0.3).
    For errors 11,006.43 and 11,015.43
    Replace the Printhead ( REP 2.0.2).
    Complete.
    For error 11,009.46
    Replace the I/O Board ( REP 5.0.13).
    Replace the Electronics Module ( REP 5.0.5).
    Complete
Cant find closed captioning
No. There is no code for too turm closed captioning ON/OFF. If your remote control have a "CC" button, pressing it once must eliminate closed cption window. If there is no such button, you have to get into TVs menu option to turn it OFF.
For more details, refer to TVs' user manual.
May 23, 2012 | Orion STV2763 27" TV
How to turn off the close caption on tv
Hello
Not all TV programs and product
commercials are made with
Closed Caption (CC) information
included. Neither are all Closed
Caption modes (CC1, or CC2) necessarily
being used during the transmission
of a closed caption program.
Refer to your area's TV program listings
for the stations and times of
Closed Caption shows.
To close the close caption display from screen; press "CC" button on the remote control.
Jul 08, 2011 | Philips Magnavox 20MT133S 20" TV
Black box on screen
Hello
Closed caption setting is set to 'ON' on your TV. Enter the Menu; surf thorugh to the closed caption setting screen and set it to "OFF". Refer its user manual. OK.
Apr 21, 2011 | Olevia 332V LCD TV
How do I turn off closed caption?
Hello
From the main menu, surf though and enter the closed caption window. Here you can see options for Analogue closed caption, Digital; closed caption and Caption style to select. Here select "OFF" for both analogue closed caption and digital closed caption option.OK.
Refer to your TVs user manual. If you haven't its user manual, inform me though Fixya. Send your email ID too. OK.
Feb 14, 2011 | Hannspree XV32 32 in. LCD Television
System fault code 10-389 won't clear
Hello.
System Fault Code 10-389 refers to a Fuser Nip Contact Failure.
To service the Fuser Nip Failure problem, you'll need a specialized laptop called a PWS (Portable Work Station).
So, unfortunately, this problem needs to be handled by a professional service tech.
Hope this helps.
Hope this helps.
Customize: Reply 1: XEROX DOCUCOLOR 12 :: Xerox - Color :: The Copier Network"" src="/images/cust_r0.gif" border="0" height="13" width="15" />
Sep 15, 2010 | Xerox DocuColor 12 Printer
Xerox phaser 8560 error 04,018.48:26
Hello,this fault code indicates a problem with the process control system.The printhead temperature dropped below the head cleaning needed threshold and that's why stops warming up.The first you need to do is to verify the temperature of the room that the printer is,if its too cold,near from an open window...If was too cold and not in the room temperature then move the printer and your are done.If this doesn't solve your problem run the Monitor Heaters tests with all heaters ON.Are the heaters operating correctly?If yes replace the Electronics Module.If no you have to inspect the harness to the failed heater.Is the harness damaged?If yes you must replace the harness.If no replace the problem component.
Good luck:)
Feb 04, 2010 | Xerox Phaser 8560DN Printer
Xerox DC12 System Fault 6-355
06 codes refer to exposure lamp problems..(or scan) check lamp coming on, scan carriage position etc, don't have the code list, so carefully move the scan carriage up and down, make sure it moves OK
Jun 05, 2008 | Xerox DocuColor 12 Color Copier
Xerox WorkCentre M128 - 016 - 782
There is an error in the in the server password or a template setting.
Here is the documentation. Pretty straight forward
Login to the Server was not possible during Scan to Server file transfer.
arrwup.gifInitial Action Refer to BSD 16.1.
Power OFF/ON
arrwup.gif Procedure Set the login name and password in the destination server.
Set the attributes of the Job Template file correctly.
From a client PC, set the same account as the above as a resource using CW.
May 19, 2008 | Xerox WorkCentre M128 Copier
Error message
9,037.45 Yellow Ink Stick Count Fault
your 04,021.42 here are the possibilities.
arrwup.gifPrimary Causes The troubleshooting table lists parts and wiring referenced in the troubleshooting procedure.
Table 1. 4,0xx.4x Troubleshooting Reference Table Applicable Parts
Electronics Module, PL 5.0
Right Side Wire Routing (2/2), Figure 3
Printhead, PL 2.0
Electronics Module, Figure 6
Drum Assembly, PL 2.0
Drum Heater Relay Board, PL 5.0
Right Side Wire Routing (1/2), Figure 2
arrwup.gif Troubleshooting Procedure Table 2. Process Control Error Troubleshooting Procedure Step
Yes
No
Test the heaters.
Run the Service Diagnostics Monitor Heaters tests with all heaters On.
Do the heaters function properly?
Go to Step 3.
Check the harness to the failed heater.
Replace the harness.
Replace the failed component.
Jan 06, 2008 | Xerox Phaser 8500N Printer
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
653 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
