Question about Sharp AR-160 Copier
Sharp Copier AR-C270 Code Problem
Anybody know what code HS=01 means? Please email adamerica@cox.net Thanks I am getting an H5-01 error code on my machine and I cannot figure it out I have checked for jammage and found none, Could someone please give me some direction?
    Problem Solver:
  • 18 Answers
Jam in the fuser unit, try simulation 14
and/ or possible bad sensor switch actuating as tho paper is stuck in the fuser. check that exit switch is not stuck open or bad. if jam elsewhere , fuser will not allow operation untill jam somwhere is removed.
Posted on Jan 31, 2008
AR M700N copier jams... trouble code H5-01
h5-01 error is five consecutive jams in the fusingg section. P*C* gets you into dervice mode thenn 14 for trouble reset. then execute and restart. check the fuser pawls for dull edges and breaks. also check roller tensioning system on fuser.
Oct 13, 2009 | Sharp AR-M700N Copier
Error code H5-01
HI.H5-01
it shows there is some problem in exit sensor .it is in fuser unit.may be its lever is broken .
sensor is dirty clean it
check lever home position and its movemment
check its cable
reset this code
press ,p,*,clear,*
screen will go dead press 14 ,start code will bi reset
never forget to rate the solution.MIAN AKHLAQ
May 07, 2009 | Sharp AR-M350U Copier
Error code h5-01
Hello sir; the paper exit sensor get stock, just put back in the track let it moved free.
Apr 14, 2009 | Sharp AR-M350U Copier
WHAT DOES THE CODE BELOW MEAN
H5-01 means the machine has had a jam in the same place 5 times in a row.
Mar 13, 2008 | Sharp AR-M350N Copier
Sharp AR 250 with error code H5-01
SHARP AR250 H5-01 Papersensordefective in the fusing unit
Normally you can clean the build up of toner off the sensor, and it'll sort itself out. It also could happen by having 5 paperjams in a row.
You might need to run a service mode to reset the machine:
P * C * 14 (start) then 1 for Yes and follow on screen directions, code should clear out.
Feb 25, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp AR-M350N/H5-01
Hi, to reset H5 follow this sequence: P, *, C, *, display should read 'enter simulation', enter 14, print, execute, yes. Should re-boot if not switch off then on.
Cheers
Andy
Jan 24, 2008 | Sharp AR-5320 Black and White Copier
Ar-c160
Make sure there is no paper jammed in machine, H5-01 means 5 jams same location. Use quality paper not recycled and make sure it is fresh not old stock
PROGRAM INTERUPT CLEAR INTERRUPT must be SUPER FAST then 14....WILL RESET CODE
Dec 16, 2007 | Sharp AR-C160 Color Copier
sir there is no code of HS may be it is other code H4 or H2 so please write correct code
Oct 06, 2007 | Sharp AR-C270 Color Copier
Sharp AR-160 Copier Logo
73 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
