Question about Intel Frontier Design Dakota 24-Bit PCI Soundcard Sound Card
Dell OptiPlex?? GX520 GX620 Internal Speaker code? Small speaker/amp, approx. 1 1/8 " dia. by 3/4" deep. Red, Blk, Grn, & Wht wires out of speakere housing. Built in amp on housing. Robert bob@trebor.net
  • bob7 Jan 31, 2008
    I purchased from Dell two speakers that they use in their OptiPlex computers. There are four wires coming from the housing Red, Black, Green, and White. I thought I was purchasing just a speaker but after receiving them I see that there is an ampllifier circuit built on to the housing. I thought there may be a standard color code for the four wires so that I could take advantage of the attached amplifier. The whole unit is very compact and tracing the circuit is not possible. Dell did not publish any information that would help. The PCB did indicate it needed 5V power. On the controller board that these speakers would provide audio there is available 5v regulated supply and an audio out connection. Using the speaker preamp would save me much needed space on the controller board of my project.
  • Brian March May 11, 2010
    Speaker code? Please be more specific with your question.
  • 979 Answers
My experience has been for this configuration, is that the red wire is your +5 volts, the green is right, the white is left, and the black is the ground for the supply and both speaker grounds. Hope this helps...accordianman
Posted on Feb 08, 2008
Speaker not working
1.check the speakers.
2.check the cabels to the speakers.
3.back on the I/O-shield the lightgreen contact is audio out put.
4.go to services and RESTART windows audio.
Aug 13, 2013 | Dell OptiPlex GX520 PC Desktop
Dell optiplex GX620 doesnt start
1-3-1 through 2-4-4
Memory not being properly identified or used
http://support.dell.com/support/edocs/systems/opgx620/en/ug/tools00.htm#wp1120374
Feb 12, 2013 | Dell OptiPlex GX620 PC Desktop
No sound from speakers
Hey i have just 1 solution for your problem change your speaker. And buy new. Don't mind it please.
Oct 03, 2011 | Dell OptiPlex GX620 PC Desktop
Dell Optiplex GX620 Desktop PC's south bridge IC heats up abnormally...
Check the capacitors on the motherboard, Dell had a BIG problem with faulty capacitors on the GX270, GX520, GX620, GX745 and GX755 units. The parts would cause the unit to either not boot at all or lockup booting or running programs. I would bet you have some that are just beginning to fail and the motherboard power is not stable which would mean the chips are not getting enough power. Here is a link to an article about the issue and what to look for on your board.
http://www.ccl-la.com/blog/index.php/dell-optiplex-gx620-motherboard-repair/
I hope this helps you out, if so please rate my solution.
BuddyMc
Jun 30, 2011 | Dell OptiPlex GX620 PC Desktop
My dell optiplex gx520,s front audio two pin's is not work please help me
Try to renew your drivers for the audio card from here:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&os=WLH&osl=en&SystemID=PLX_GX520&catid=-1&impid=-1
Here you can also find a manual.
Did you use the right outlet ???
There is a microphone outlet and a speaker outlet.
Hope this was helpfull.
Mar 13, 2011 | Dell OptiPlex GX520 PC Desktop
I can listen to sound using my earphones on my Dell Optiplex GX520 but cannot hear anything through the internal speakers otherwise. How do I turn them on?
the internal speaker is only for beeps. These beeps are constant or short and only happen when the computer is trying to tell you how its about to die lol.
Buy some speakers. I would highly recommend a 2.1 system from logitech.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010370060%2050001080%201090608149&bop=And&ShowDeactivatedMark=False&Order=PRICE
Apr 06, 2010 | Dell OptiPlex GX520 PC Desktop
No sound opliplex GX620
Check the speaker cable connections.
Ensure that the subwoofer and the speakers are turned on
Adjust the Windows volume control
Disconnect headphones from the headphone connector
Test the electrical outlet
Enable digital mode
Eliminate possible interference
Run the speaker diagnostics
Reinstall Audio Driver
Check the device option setting
Run DELL 32 bit DIAGS
Mar 03, 2010 | Dell OptiPlex GX620 PC Desktop
Dell optiplex gx620 is not switching on
Hi
Thank you for your query
The fault you are descrbing, sounds like a power fault please can you try thr following steps in order to resolve
1) Ensure that the fuse has not blown in the plug
2) Remove the 3 pin plug from the back of the PC, press and hold the power button in for approx 20 seconds (i know there is no power going to the PC), this is done to destat the PC
3)If the above fails then you most likely have blown the PSU on the PC
This will need to be repaired at a reputable PC Shop for replacement
Please leave positive feedback/vote if this has been useful
Feb 12, 2010 | Dell OptiPlex GX620 PC Desktop
Intel Frontier Design Dakota 24-Bit PCI Soundcard Sound Card Logo
1,100 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
