Question about Hitachi 61UWX10B 61" Rear Projection Television
Hitachi 61UWX10B 61 in | TV will not turn on after reset | any reset button inside the TV ?
Not seeing any change after unplugging the cord.Still hearing the clicking noise No picture and no sound. My LED is not coming on or flashing.My screen is still black.Please guide if there is a reset button inside the TV ?
  • dhanney Jan 31, 2008
    I left the power cord unplugged for nearly 30 mins. Also removed the fuse
    and reinserted it back. I was able to get my picture .My TV is up and
    running now. Appreciated your assistance and many thanks for your
    support.
    Problem Solver:
  • 5 Answers
My Hitachi was doing the same thing. The culprit is a bad or intermittent 5V relay on the power supply board.
Posted on Feb 05, 2008
The convergence is off on my Hitachi 61UWX10B rear projection TV. I was unabel to fix it using the remote
The chips and 12 resistors need to be replaced, below is a link where you can find them. I've done business with them. They're very reasonable and give you step by step instructions to fix it yourself.
http://www.tvrepairkits.com/xcart/product.php?productid=20080&cat=1647&page=1
Dec 28, 2010 | Hitachi 61UWX10B 61" Rear Projection...
Hitachi 61uwx10b needs more convergance work than magic focus can apply. Options for savvy DIY'er ?
Know basic soldering?That all require changing convergence ICS all it resistors.Tries Tv repair World.com,Tvrepairkits.com for the convergence kit.
Oct 02, 2009 | Hitachi 61UWX10B 61" Rear Projection...
My color doesn't line up on my hitachi 61UWX10B somebody said color mod is bad
Replace the convergence ICs you need two STK392-110 convergence ICs You can get replacement ICs at the folowing link with free isntallation instructions.
http://servicemanuals.vstore.ca/
Mar 06, 2009 | Hitachi 61UWX10B 61" Rear Projection...
Black Lines
Just to reset first before proceed another procedure;
Resetting the TV
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet for 4 - 6 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards,
VOTIT
Oct 07, 2008 | Hitachi 61SWX10B 61" Rear Projection...
Hitachi 61UDX10B
I would check for burnt resistors as the 150s are interchangeable with the 110s however in alot of hitachis I have seen resistors blow after upgradeing to the higher wattage ICs. I Usually switch out the convergence resistors whenever I go to a higher wattage IC just to be sure. If you need more help let me know.
May 18, 2008 | Hitachi 61UWX10B 61" Rear Projection...
If your set all of a sudden won't come on, e.g., the screen is blank, but the LED on the under the screen next to the on/off switch keeps flashing, then there may be an internal fault on the set that needs to be reset.
To force the reset, try this:
  • Unplug the set and wait a few seconds
  • Replug and see if the video returns
Whenever the set senses an internal fault through its monitoring circuitry, it essentially shuts down the set. The flashing LED provides the indication that a fault has been detected. Removing power to the set resets the monitoring circuitry. When plugged back in, the circuitry again does a check of the system1.gif. If it finds that there truly is a problem, then the set is shut down and the LED will again flash.
Jan 30, 2008 | Hitachi 61UWX10B 61" Rear Projection...
Hitachi 61UDX10B
[BRAND SPECIFIC][TOSHIBA][QUICK FIXES]
Flashing LED
<< Back to Quick Fixes Page
Whenever the set senses an internal fault through its monitoring circuitry, it essentially shuts down the set. The flashing LED provides the indication that a fault has been detected. Removing power to the set resets the monitoring circuitry. When plugged back in, the circuitry again does a check of the system. If it finds that there truly is a problem, then the set is shut down and the LED will again flash.
Jan 22, 2008 | Hitachi 61UWX10B 61" Rear Projection...
Hitachi rear projection "61UWX10B
I was told may be problem with high voltage capacitor. not true. 1 your problem in power supply. 2 if it is ok it is due to horl.section.
Sep 14, 2007 | Hitachi 61UWX10B 61" Rear Projection...
Hitachi 61UWX10B 61" Rear Projection Television Logo
321 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
