Question about Sony XR-C6100 CD Changer
My benz in trunk cd changer skips....
Iy skips only when i drive when i am parked it is fine but when i drive it skips sounds like my cd's have hiccups..lol ....help !!!
    Master:
  • 619 Answers
Hi if you have cd lense cleaner try run it twice so that the small particles stick it lense will be remove .
also put some rubberized foam cushion around the cd if buit in.
Posted on Feb 02, 2008
Why won't it go back into reverse or park sometimes?
My car won't go into reverse or park... Sometimes, happens ...
repairpal.com > ... > 2011 Mercedes-Benz C300 4MATIC
Jun 5, 2015 - And I know that there is no transmission problems just in my gear shifter. I can't figure it out. ... 2011 Mercedes-Benz C300 4MATIC Questions ...
Mercedes Benz automatic transmission shifter shaft bushing ...
? 6:07
www.youtube.com/watch?v=vQ-yupz08Tw
May 25, 2012 - Uploaded by fupabox
I have a 1997 c280 without the key being in the ignition and foot on the brake I'm ..... get the shifter to engage in reverse or park, it will only go into neutral and drive. ... I have a 2009 c300 and it has problems going into gear. .if I wiggle it .... Mercedes Benz 722.6 transmission..stuck Shifter mechanism repair .
Oct 22, 2015 | Mercedes-Benz 2009 C300 4Matic Sedan
Kenwood 6 disc cd changer
screw needs to be replaced and making sure the bracket it not bent... thus , not allowing the cartridge to come out,,,
May 12, 2014 | Kenwood KDC-C465 6-Disc CD Changer
I have a 1993 Mercedes 300 SE and after I got the radio unlock code from mercedes the radio worked all day just fine. I started the car the next day and the radio had a E 3 message on the display when I...
I dont remember if that year had a theft lock system or not, but I am looking into it. disconnect the negative battery cable for ten minutes and that should get you back to where you can enter the unlock code again and use the radio.
Nov 01, 2013 | 2004 Mercedes-Benz Mercedes Benz S Class
WHAT IS THE PROBLEM 2007 CLK 350 RADIO AND CD NO SOUND ?
Mind does the same thing every few months since new. It just did it today and I pulled (out/in) the CD changer fuse (#20 in the trunk fuse box) and it started working again.
Sep 02, 2012 | 2007 Mercedes-Benz C-Class
I drive a 1993 Mercedes Benz 300D and the radio recently stopped working. If you turn it on, 5 clicks sound through the speakers and then the messege "E2" comes over the screen and the radio shuts off.
Here are some causes for this failure: "E2"or "E3" (Without CD Changer)
1 Input Power to the RECEIVER UNIT (Trunk mounted) is missing, Check with volt meter to test for 12 volts
2 Fuse of the RECEIVER UNIT (Trunk mounted) is open, Replace it with 7.5 amp fuse.
3 The BUS CABLE (gray colored) that connects to HEAD UNIT(dash mounted) to the RECEIVER UNIT(trunk mounted) is not connected or is defective.
4 RECEIVER UNIT(trunk mounted) is defective. Go through these and try your radio. Hope this works out for you.
Nov 23, 2009 | 1993 Mercedes-Benz E-Class
No CD Changer display
This system is very complicated and unfortunatly you need a scan tool and a d2b ring tester unless you are very familiar with the fibre optic ring set up for this vehicle. most likley your c.d. player is defective-is their also a phone and do you have sound from the speakers when operating normal radio function
May 25, 2009 | 2004 Mercedes-Benz C-Class
Cd changer
check the trunk, the glove box, under the back seat, and the center console
Apr 18, 2009 | 2001 Mercedes-Benz C-Class
Not getting sound from my cd changer with FM modulator
make sure you have the 2 audio cords running from the changer into the FM module
Mar 28, 2009 | Sony CDX-540RF 10-Disc CD Changer
Nakamichi MF-51 5-Disc CD Changer
I suggest you should give your audio player for general service..!!
Jun 08, 2008 | Nakamichi MF-51 5-Disc CD Changer
My 02 Maxima's CD player freezes and skips.
my cd changer skips alot i dunno wht to do i cleaned it it woorks fine while sitting still but as soon as i drive it skips:(
Nov 21, 2007 | Car Audio & Video
Car Audio & Video Logo
147 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
