Question about PfaFF Creative 7570
Threading a pfaff creative 7570
How do i thread a pfaff creative 7570
  • Anonymous Mar 14, 2014
    Describe how do I move needle position on Pfaff 1475 Creative CD?
  • 8 Answers
Always thread the machine with the presser foot up. This keeps the tension disks open while you are threading. Open the lid on top. Put thread on spool holder. Go directly to your left and down the path on the farthest left. Go all the way to the bottom and bring the thread up on the path closer to the spool. Hook the thread through the metal piece that moves up and down while sewing. It should be in the highest position when threading. Run the thread down and clip into the small metal holder above the needle. Pull down needle threader, draw thread across front of it from left to right and pull through needle.
Posted on Feb 14, 2008
Blinking Red led on Pfaff 7570
Make sure the bobbin has thread. The manual should provide information in the troubleshooting section.
PFAFF creative 7570 Instruction Book
Nov 13, 2016 | PfaFF Creative 7570
What does the red light blinking on the front of the machine mean/
That probably means the bobbin thread supply is running low. See page 217 in your Instructions Manual.
Manual pdf at link below:
Mar 09, 2015 | PfaFF Creative 7570
Would like to know how to thread a twin needle on a Pfaff 7570
put the twin needles in the needle holder and then thread the first
needle like you normally would then add a second spool or cone
of thread then thread the machine the same way you did with the first
needle and then thread the second needle
Jan 27, 2013 | PfaFF Creative 7570
How to thread the machine. pfaff creative 7570
I just went across to FAcebook and found Pfaff there and from there a link to manuals online, yahoo. Thankyou Pfaff.
Here is link for the manuals page
http://s2.vsmgroup.com/VSM/Pfaff/pfaffmanual.nsf
Its a bit tricky, click on the blue arrow beside your model, then click again on the blue arrow beside "English", then click on the blue underlined text "owners manual" to see the PDF file download.
Oct 17, 2011 | PfaFF Creative 7570
On what number should I put 7570 tention when
Refer to the manual. If you do not have a manual, start at 4 and work your way through the numbers, bit by bit until you get good results.
The bobbin thread should pull the top thread slightly under and to the back.
Machine embroidery bobbin thread is heavier than the standard size machine embroidery top thread and this also helps to pull the top thread to the back.
Mar 07, 2010 | PfaFF Creative 7570
I cant set the tension on my PFAFF 7570 the thread keeps
First make sure your needle is in correctly. Then make sure you are threading the machine correctly especially make sure you thread the take-up lever. Make sure your tension dial is at a 4 to 5. if this does not work, let me know
Oct 19, 2009 | PfaFF Creative 7570
Jamed Pfaff CD 7570:
Your machine probably has a thread lock which is a piece of thread caught in the hook. If this is the problem then here is the solution.
Grasp the hand wheel and turn it back and forth,increasing the amount of force used each time. It should break free after about 4-6 tries
sewman7
May 08, 2009 | PfaFF Creative 7570
Bobbin tension
Check also this links, hope they can help you:
Pfaff 1475 7570 7560 FAQ
threading a pfaff creative 7570
Aug 10, 2008 | PfaFF Creative 7570
Sewing Machines Logo
411 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
