Question about Siemens SpeedStream 5260 ADSL LAN Modem p/n 060-5260-003 (SPEEDSTREAM5260)
Speedstream 5260 (5262) //EnterNet300
Where can I find EnterNet 300 1.5c for changing the VPI/VCI in the Speedstream 5260?
Enternet 300 1.5c SP2 works with Windows XP and i can't seem to find that exact version anywhere so i can make it work on my ISP.
thanks
thaimzup2003@yahoo.com
  • thaimzup Oct 01, 2008
    thanks! i actually found it back in january when i posted, but here it is for anyone else who needs it. (i think this is where i got it!)
    http://xenomorph.net/files/enternet300v1...
    Scholar:
  • 86 Answers
Go to http://www.gmbargains.com/Download/Siemens%20Speedstream%20Modems/ and you'll find everything you need. Thank you.
Posted on Oct 16, 2014
    Scholar:
  • 158 Answers
I m sorry to say that enternet300 1.5c is not available these days in online.
instead of enternet , windows xp has a similar built in interface, its 99% similar to enternet
try configurin your isp using this simple procedure, configuring this interface is pretty easy compared to enternet.
so go ahead and give a try . i m sure u wont regret !
•Go to Start->Control Panel •Then Network & Internet Connections
•Then Network Connections
•Select Create a new Connection
•Click Next
•Select Connect to the Internet then click Next
•Select Set up my connection manually then click Next
•Select Connect using a broadband connection that requires a user name and password then click Next
•Type in your ISP's name then click Next (**See Note Below)
•Enter your user name as provided by your ISP.
for example: You might need to inlude your domain as part of your username. pacbelluser@pacbell.net
•Enter your password, then confirm it
•Select Use this account name
•Select Make this the default Internet connection then click Next
•Select Add a shortcut to this connection to your desktop then click Next
•Hit Connect
i guess this must resolve your issue :)
Posted on Oct 01, 2008
How to set the VPI and VCI values
The VPI and VCI settings are made in the DSL modem, NOT the Linksys router.
Aug 06, 2014 | Linksys WRT300N Wireless-N Broadband...
Where is the vpi & vci settings?
Your Provider modem provides this info.
Apr 09, 2014 | Zyxel NBG420N Router
D-Link modem is dead.
Try to configure the settings of the d-link modem. Make sure the atm circuit identifier goes along with the settings required by yopour isp. If not, try to check it with them. Normally, internet connections make use of vpi as 8 and vci at 35 for ciruit identifier. Try that. You can change the settings of the modem by pulling its interface.
Hope that helps.
Jun 24, 2009 | D-Link DSL-2320B
I installed a Dlink Telephone adaptor between my speedstream 5260 my PC. I think I need to change the MAC address on the speedstream. How do I do that?
Connect one of your computer to the LAN port of the speedstream, access the configuration page of the speedstream (example 192.168.1.254) then under advance tab there a MAC filter there that you change the MAC address.
Mar 15, 2009 | Siemens SpeedStream 5260 ADSL LAN Modem...
Modem
Technical Specifications AAL and ATM Support
VCI 0-65535 address range
VPI 0-255 address range
AAL5 support
Bridging
IEEE 802.1.d Transparent Learning Bridge (dynamic learning of up to 255 addresses)
Spanning Tree support
Certifications
FCC Part 15, Class B
CE certification
Connectors
DSL interface: RJ-11 or RJ-45 (Europe)
Ethernet interface: RJ-45
USB Type B interface (5200, 5500 series)
Diagnostic LEDs
Power, DSL, Activity, Ethernet status; USB status (5200, 5500 series)
Management
Intuitive, Web-based GUI management access
SNMP support
Comprehensive hardware diagnostics
Media Interface
RJ-11 or RJ-45 (European) DSL WAN connection
10/100Base-T RJ-45 Ethernet LAN connection
USB Type B LAN connection (5200, 5500 series)
Power
12V power supply included, 700ma max. 5400/5500 - 12 VDC, 1000ma max.
Routing
DHCP server/DHCP client
Network Address Port Translation (NAPT)
Network Address Translation (NAT)
Packet filtering
RFC 2364 Point-to-Point Protocol over ATM PVCs (PPPoA)
RFC 2516 Point-to-Point Protocol over Ethernet (PPPoE)
RFC 2684 (formerly 1483) Bridged Ethernet and routed encapsulation Routing
Standards Compliance
IEEE 802.3
USB 1.1 T1.413 issue 2 G.992.1 (G.DMT) G.992.2 (G.Lite)
Oct 15, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Trying to use SpeedStream 5100 with new DSL Provider
I have Centurytel myself, so maybe I can help:
A link to your Speedstream 5100 router:
http://www2.windstream.net/downloads/links/SpeedStream211.pdf
And the typical setup for the westell 6100 that centurytel uses:
Centurytel will provide you with your username and password.
PPPoE Configuration:
VPI 8
VCI 35
Protocol: PPPoE
Hope this helps.
Jun 12, 2008 | Efficient Networks SpeedStream 5100 Modem
Config
just reset ur router & reconfigr it
Feb 26, 2008 | Computers & Internet
Wont work
Does Big Pond and your new ISP dodo use the same values for VPI/VCI?
If not, you need the correct VPI/VCI for your new ISP.
Read the FAQ at DSL Reports on the 5260 and changing the VPI/VCI using EnterNet 300 1.5b or EnterNet 300 1.5c.
http://www.dslreports.com/faq/15476
Regards,
Doctor Olds
Oct 16, 2007 | Siemens SpeedStream 5260 ADSL LAN Modem...
Can't get modem to work
speedstream 5260 modems don't have a built-in pppoe in it, so with your win xp OS you just have to make a broadband connection using the new connection wizard by either going to control panel > network connection > new connection wizard or in internet explorer, click on tools menu > internet options > connection tab > click on setup button. follow the wizard and type your username & password on your registered internet account. also make sure you delete your previous broadband connections (if you have set up one before) to avoid conflict with the new connection.
the set up is different if you are using lower versions of windows OS, (like win2000, ME, 98 SE/ FE or 95? ) or Mac 9 you may need to install a pppoe software such as Enternet 300, WinPoet, etc.
Dec 18, 2006 | Siemens SpeedStream 5260 ADSL LAN Modem...
Computers & Internet Logo
733 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
