Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
PT-53wx53 replacement bulb
Where can I find the replacement bulb for this model. And do you have an exact part # for this bulb?
thanks
  • Panasonic Master
  • 8,617 Answers
Your model doesnt have a bulb. The PT 53WX53 is a progressive scan CRT projection TV. You have 3 CRT Tubes, Red, Green And Blue. Hope this helps. If you need more info let me know.
Posted on Feb 01, 2008
Pt-53wx53 Panasonic Projection TV Turns off
OK< likely one of the new chips are bad or when soldered in you shorted pins at that time----3 blinks is short protection and you are going to find ONE of the light blue 2.2 ohm resistors is open (usually discolored in middle).
Having changed hundreds of chips in this model once in a while you get a new one that is bad---replace both again.
How did you get at them----remove the board or pull the light box?
Oct 26, 2012 | Panasonic PT-53WX53 53" Rear Projection...
Looking for the steps to connect panasonic tv
if PT-53wx53 just Google the model number with manual after it and you will find an owners manual for free---save to your computer and read it--if questions let me know.
Mar 11, 2012 | Panasonic PT-53WX53 53" Rear Projection...
I think a bulb is out how would you know?
Look into lamp, you'll see a glass cylinder with a bulb at the bottom. White or black buildup inside means bad bulb. Also the spherical bulb can deform by heat - bad bulb as well.
When you replace a Panasonic bulb you must reset the lamp timer.
Jan 17, 2011 | Panasonic PT-53WX53 53" Rear Projection...
What is the make and model# for a replacement lamp on this Panasonic PT-53WX53 53 in. Rear Projection HDTV
MODEL NUMBER INDICATED DOES NOT USE A LAMP! IT HAS THREE PICTURE TUBES; IF CORRECT MODEL NUMBER WHAT IS WRONG WITH THE SET====WHAT IS IT DOING OR NOT DOING?
IF THIS INFORMATION WAS HELPFUL RATE this solution as very helpful as I do this here for free.
Comment here if you have questions or need help--I am here to help.
SD TECH
Aug 21, 2010 | Panasonic PT-53WX53 53" Rear Projection...
I got the 1080i panasonic hdtv which lamp indicator light flashes 4 times and wont turn on.what could be the problem.
I would check the lamp first. These are the most common failures and can be replaced by the consumer with step by step directions in the user's manual. Check the lamp by removing the lamp door and checking the bulb. If you see either a shattered or cloudy bulb, then you need to get a new lamp.
Oct 13, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53wx53 rear projection tv does not turn on, blinking
Thats the error code for the convergence. You can get the PT53WX53 Convergence repair kit at the following link. www.tvrepairworld.com
the kit contains the parts and CD with instructions
Aug 14, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic pt-53wx53g vertical output ic
IC451 (Vertical Output) LA78045 part number is C1AA00000521
Available in Part Store.
Above info are taken from related service manual and an image of s.manual is given below...
Jun 19, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Red light blinks 5 times!!
C509 .47uF Mylar 250Volt. Replace this cap, this should restore power.
Jun 04, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Need to replace power cord and projection tube
What CRT do you need? Each one has a different part number. Realize that each CRT will cost about $200.
Dan
Apr 23, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
349 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
