Question about KitchenAid KERA205P Electric Kitchen Range
Convection Oven Fan Failure
My 2 year old convection oven fan has failed. It always rattled about when it was first started for a moment or two then ran fine. About a week ago I did my first self cleaning, did a good job. A day or so latter I tried to use the convection oven feature, the fan started, made a bit more noise than before and the stopped. I tried turning the fan with a kitchen knife, it was relatively free to rotate but would not start again.
Any help??? Whirlpool will replace it for free after a $119.00 visit to determine what is wrong.
Thanks
Mike
  • icanswim Mar 01, 2009
    KitchenAid Superba, 8 years old, got whiny fan, then really noisy and then stopped today. How to replace easily? motor?
    President:
  • 1,314 Answers
If the fan is cheaper you can replace it your self if it was making a noise id say thats where the trouble was
Posted on Jan 30, 2008
How do I fix the Convection Fan not running/working
Make sure that the fan motor is being energized. If so, and it does not run then the fan needs to be replaced.
Apr 20, 2016 | Breville The Smart Oven Convection Toaster...
Convection fan runs from start up , but when temp ia achieved , fan stops working and shows con on the display
Search Results
    Frustrated with new Samsung stove! - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWe purchased a smooth top, convection Samsung range , with delivery on ... I seem to have the same problem with my new samsung range FER700WX. ... That ovenwould not reach temperature and if it did, it would not keep the temperature. ..... 3) as the oven restart the convection fan or fans blow such hot air the food in ...
    Convection 101: A Guide to Cooking With Fans - Oven ...
    ovens.reviewed.com/.../convection-cooking-101-a-guide-to-cooking-ba...
    Apr 4, 2015 - Problem is, it uses a ton of water. 6.2 ..... Convection ovens use a fanand an extra heating element to correct ... it's best to reduce oven temperature first, before adjusting cook time. ... range or wall oven, there's simply no reason not to ponyup. ... From futuristic to freaky, these fixtures run the entire spectrum.
    New Bosch range convection fan not moving? - Home Forums
    ths.gardenweb.com > Home Forums > Appliances
    Oct 8, 2007 - On my range (the slide-in version) the cooling fan runs even when in ... I was the one with the Bosch fan problem and if there is a problem with ... Mine does stop turning when I open the door and starts again when I ... convection roast feature, and once the oven reached temperature, ... Sign Up to Comment.
    Troubleshooting Gas Range and Oven Problems ' Back ...
    blog.etundra.com > Tundra's Tech Talk
Jan 17, 2016 | Kitchen Ranges
Convection oven making rattling sound.
It is most likeky that the fan bearing is worn and thus causing the rattling sound. You will probably need to replace the fan. Check first that there is no obstacle in the way of the fan rotating.
Replacement of the fan will require the back of the oven to be removed giving access to the fan unit, which will need to have the wires disconnected and the fan assembly unbolted. Fitting is the reverse.
Always remember to switch off the power before working on electrical equipment.
Jan 07, 2010 | GE Ovens
GE Profile Performance Convection/Microwave Problem Heating
Either magnetron, capacitor, diode pack or transformer has failed causing a fuse to blow.
Jul 13, 2017 | General Electric Microwave Oven
Ge profile oven/convection oven humming when on convection settin
ensure that your convection fan is turning
a hum on this model usualy means that the convection motor can seize up a bit
sometimes all you need to do is redjust the fan blade
Oct 13, 2009 | Ovens
Convection oven blowing cold air
If your fan is blowing cold air, it's the air inside the oven that circulates. It has nothing to do with the fan. Convection circulates the existing air in the oven. Sounds like you might deselect the convection setting if this continues to happen. We have parts, so please let us know if we can help any further. :>)
Aug 24, 2009 | Ovens
Kitchenaid convection oven fan rattles/noisey
Sometimes the fan blade mounting nut gets loose. Remove the cover from the fan and see if the blade wobbles. If so,tighten the nut on the fan motor.
Jul 27, 2009 | Moffat Half Size Electric Convection Oven...
Oven issues
replace the oven ignighter
Feb 26, 2008 | Kitchen Ranges
Fan for convection oven not working
Maybe you could throw out the oven and buy a new fridge
Feb 02, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Convection fan not working
Check for a bad fan motor or a jammed blade.
Jan 01, 2007 | GE Profile JK915 Electric Single Oven
KitchenAid KERA205P Electric Kitchen Range Logo
694 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
