Question about Tomtom ONE GPS Receiver
Attaching the device
The rake of the windscreen on my vehicle is such that I caanot use the attachment device provided.
Is there an accessory which would allow me to fix it to the ventilation grille?
    Novelist:
  • 158 Answers
YES , try EBAY , search for tomtom vent mount. You can also buy special rubber disks that have a sticky back. The disk can be attached to the dashboard or some other plastic area. These allow the normal tomtom windscreen mount to fix to the disk.
Posted on Feb 05, 2008
Citroen relay 2011 i have no wipers windows or mirrors and the battery drains in about 4 days ??? otherwise faultless , any ideas , many thanks
Windscreen wipers not working after jump starting vehicle.
Affected vehicles
  • All models.
Problem
Cause
  • Windscreen wiper motor and engine wiring harness damage caused by jump starting vehicle using incorrect earth point.
Remedy
Parts Earth point warning label
  • Carry out electrical, mechanical and component tests (as applicable) to eliminate any other possible cause(s).
  • If no fault(s) found: Replace windscreen wiper motor and engine wiring harness.
  • Attach earth point warning label Fig.126139.1.
Nov 30, 2016 | Citroen Cars & Trucks
What is the correct way to remove the device from the car if I leave the suction pad in place?
Leave the suction pad with the holder on the windscreen.
Remove only the GPS device from the holder if you have to.
Apr 12, 2016 | Garmin nuvi 55LM 5" GPS with Lifetime Map...
Battery wires have been cut at the post, how do you tell what wires go where?
On most vehicles, you can usually follow the ground wire (- post) to where it's attached to the vehicle frame or it will be bolted to a heavier metal point on the engine. The large positive (+ post) wire will run to the starter and another will go into the wiring harness to provide power for the fuse box, and all the accessories. Any other wires you might find with an inline fuse on them should normally be attached to the + side of the battery.
May 27, 2013 | 1986 Chevrolet S-10 Blazer
Wii wont power on
Wii Console Won't Turn On, and Has No Power Light
Situation:
The Wii console won't power on, and the Power LED is unlit
The console powers on, but shuts off after a few seconds/minutes
Attaching an accessory to the console turns the power off
Information:
This issue can be caused by an accessory or power surge tripping the circuit breaker on the AC Adapter.
What To Do:
Check any accessories attached directly to the console to make sure that it is licensed and undamaged. Unlicensed or damaged accessories shouldn't be used with the console.
Try using a different wall outlet, or plug a different device into the outlet to make sure the outlet is providing power.
Oct 29, 2012 | Nintendo Wii Console
The mounting bracket does not adhere to the slightly pebbled vinyl surface of my dashboard. Does the clear plastic cover, with the tab, come off or stay on? Also, there is a round black disk that...
The mounting bracket is meant for mounting on the windscreen. It won't stick to the pebbled vinyl surface of the dashboard as the surface allows air in. You take off the thin clear plastic cover. The black disk that came with the satnav can be stuck to your dashboard if you want to mount the satnav there. Clean the dashboard and peel off the plastic cover off the disk to stick it to the dashboard. Be sure not to put it where there's an airbag. You can then attach the satnav to the other side of the disk the same as to the windscreen.
To attach the satnav to the windscreen press the suction mount against the screen and press the lever towards the screen. To remove it pull back the lever and lift the tab on the suction pad.
Jun 25, 2011 | GPS
I got the standard mount with TomTom GO 730 and it just does not seem to work. The first time I had placed it on my windshield which I was later told was the wrong place to put it (the included maual in...
This is a fairly common issue especially with aftermarket tinted car windscreen 'film'.
You can try prolong the suction by wetting the suction cup with water of very slightly soapy water before applying it to your 'clean' windscreen area.
As for the dashboard, for some models, TomTom provide a plastic circle to which the suction cup attach to. The plastic circle is first 'permanently' attached to your dashboard with double-sided adhesive tapes.
Hope it helps: let me know how you go.
Jan 08, 2010 | Tomtom GO 730 Car GPS Receiver
How can I remove the (hood mounted )windscreen washer nozzle?
  1. Open the hood of the vehicle for clipped nozzles or nozzles with retaining screws that are attached to the hood. Locate the nozzles and hoses attached to the hood. Some vehicles may require removing an insulated panel that is retained by plastic clips. Pry the clips out and remove the panel (if applicable).
  2. Note the way the nozzle is attached to the underside of the hood. Clip-on nozzles will either be attached by a single clip on one side of the nozzle and a retaining anchor on the other end. Other clip-on nozzles may have two retaining clips that need to be squeezed together (with needle-nose pliers, if necessary). Press the clip or clips inward towards the nozzle and it will pop out of the hole in the hood. If the nozzle is retained by screws, simply unscrew them with the screwdriver. If there are hose clips holding the hose to the hood, unfasten the clips (by hand) to allow more movement in the hose-to-clip assembly.
Nov 13, 2009 | 2002 Toyota Highlander
Broke screen while trying to fix to windscreen
Are you talking about the easyport mount on the XL 330S model? If so it applies fairly easily in a secure snap. When I tested out the new mount, it was fairly easy to snap on without any added pressure. TomTom has great customer service and I'm sure they'll help out to the best of their ability and if it was in fact defective, you're bound to get a replacement. TomTom doesn't want any unhappy consumers. It's a shame it broke, because it is actually a great device.
Nov 07, 2008 | Tomtom One XL GPS Receiver
Attaching to windscreen
I have a spare window mounting bracket as new , but I need SmartST 2006 SE CD Rom. If you want to do a swap , that is you send me a copy of SmartST 2006 SE and I send you bracket email me at
fuddlebarklard45@hotmail.com
Aug 29, 2008 | Navman NavPix N40i GPS Receiver
Moving a Tomtom GPs
Clean surfaces... press rather firmly...
Jul 14, 2008 | Tomtom ONE GPS Receiver
Tomtom ONE GPS Receiver Logo
75 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
