Question about Kenmore 24 in. 16152 Built-in Dishwasher
No power, now works, but "Washing" light not correct
Four days ago the dishwasher (Kenmore 587.16152) did not show any lights when the dial was turned. Tested outlet and power connection to the dishwasher, both checked OK.
Took the panel off and tested the latch switch by manually switching as if door was closed. This worked to get the dishwasher to do something when the dial was turned but the dial would get "stuck" when switching from heavy to normal wash and from normal to light. This might indicate a timer issue. However when setting the dial to "delay wash" the timer advanced and the cycle started.
Did not have time to look any further until last night. Now the dial turns and advances and the dishwasher completes a full cycle. However the "Washing" light goes off when the unit is filling and emptying. The light comes back on when the motor is moving water to wash the dishes, when it is actually washing. Previously, and according to the manual, this light is on during the entire cycle. This might indicate some type of problem with the circuit board, the timer, or whatever the washing light is hooked up to when not washing.
I have looked at the schematic and cannot figure out where the Washing light is connected. It is working (for now) but I am afraid that this magical "fix" will not last.
Any ideas are appreciated.
  • 9 Answers
SOURCE: Kenmore dishwasher 58715142400 fills but doesn't wash
All kinds of qwerks with newer Kenmore units. When did u buy it?
Posted on Jan 26, 2008
SOURCE: Dishwasher was making whirliing noise during wash, now no wash, only fill and drain
there is a #10 torx screw holding that cover down.do not drill it out. after you take it off you can tell if the chopper is broken.be careful for broken glass.
Posted on Oct 31, 2008
  • 338 Answers
SOURCE: Kenmore Dishwasher 5871525 stops running after a few minutes
sounds like a stuck key pad since you said the normal wash button flashed.. the other thing is try holding the door shut while you run it.. to see of it is maybe not latching properly..
Posted on Apr 10, 2009
pride applia
  • 232 Answers
SOURCE: I have an 8 year-old Kenmore 665.16912 dishwasher.
if all are really good then the only thing it con be is the display (8269205) $25.00 part, if it's bad dishwasher wont run
Posted on Dec 25, 2009
kdrake84
  • 262 Answers
SOURCE: Kenmore 58715142402 Dishwasher. I noticed dishes
1.) Check the float switch for continuity
2.) check for a service tech sheet either inside of the toe panel (lower front panel)
or somewhere inside of the bottom or on the side of the unit.
3.)Trace the valve power back to the timer/control
4.) Check for power from control to water valve.
I bet it is the float switch
here is a video for the water valve and float switch click on the link http://www.youtube.com/watch?v=zv22rpcthy4
Please post results for float switch and if you found the service tech sheet.
I will continue to look for service manaul and or wiring diagram.
Keith
Posted on Mar 26, 2011
Dishwasher won't start
its the timer in the dial replace it and it will work fine yes its worth fixing
Dec 03, 2012 | Kenmore Dishwashers
Kenmore dishwasher wont turn on seems to have no power.
Check the breaker in your breaker box, it may have tripped. Reset it and run the dishwasher. If it trips again, have the dishwasher looked at by a professional service person.
Feb 13, 2012 | Kenmore Dishwashers
Refresh control panel
Instructions
    • 1
      Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
    • 2
      Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
    • 3
      Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
    • 4
      Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
      Hope this will be of help to you
      Have an awesome day
Feb 08, 2012 | Kenmore Dishwashers
Four hour delay light flashing
I have a kenmore elite dishwasher and the 6hour delay light is flashing and no other buttons work when I push them.. whats wrong?
Apr 11, 2009 | Kenmore Dishwashers
Kenmore Model 587 -- Will not run - Power lights come on/wontrun
Hello I am V- Mari and i own a Kenmore dishwasher model Number 587.1574590 and it doesn't work at all. The power light comes on and it seems to make noise, but it does nothing. Is there a recall for these models or free fix help please respond to miss_vmari@netzero.net. I would like to solve my dishwasher problems as soon as possible. Thank you!
Dec 12, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher's "Pot-n-Pans" light flashing
ga, behind the toe panel on the bottom there should be a tech sheet explaining how to put the dishwasher in the test mode. See if you can enter the test mode. If you can't, you probably have a stuck or shorted keypad. Catriver...post back
Mar 03, 2007 | Kenmore 24 in. 16009 Built-in Dishwasher
Flashing green light and not starting
dott, Im looking at the tech sheet for your model and it gives no information on the flashing light. It has been my experience that this usually indicates a bad touchpad. Since this is under warranty, it will be covered 100%. A couple of things you can try, first kill the power to the unit for 1 minute and see if it comes back the same way. If that doesn't work try to press the heated dry and start/cancel pads together for 3 seconds with the dial set to rinse only. This would put the unit into a test cycle. If both of these fail, you probably have a bad touch-pad. Call for service...Catriver...post back.
Nov 13, 2006 | Kenmore 24 in. 16193 Stainless Steel...
Kenmore 24 in. 16152 Built-in Dishwasher Logo
79 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
