Question about HP Color LaserJet 2600n Printer
Problem with photo paper
When I use photo paper for a LaserJet I get a light, gray waves all over the areas that were not filled in with color. How can I fix this problem?
Check that the thickness (gm) of the photo paper you are using is one recommened by your printer specs. Too thick and the "grey" hazing occurs.
Posted on Feb 10, 2008
Hp Color Laserjet 1600 says Jam in tray 2 bt there is not paper jams
Open the paper feed area and the printer, examine the paper feed path and make sure there isn't a page or piece of paper jammed in the path somewhere.
Aug 21, 2014 | HP Color LaserJet 1600
Why won't the HP Color LaserJet 3500 print photos even with the correct paper
After pressing print you will get a pop-up with a printing preferences button on it click the button and select the correct paper and print quality.
Dec 21, 2009 | HP Color LaserJet 3500 Printer
There is no Gray, it is Green gray. Photos are not what is seen on screen, Need calibration or something.
The colors on your computer monitor might differ from the device output. Select Screen Match in the Color tab of the printer driver.
For most users, the best method for matching colors on your screen to your printer is to print sRGB colors. The printer uses sRGB and automatically optimizes color output.
Dec 05, 2009 | HP Color LaserJet 2600n Printer
Paper gets stuck
Remove toner from printer and check in side area one gray color roller will be there with blue lock remove roller
clean the gray pickup roller and check if its get smooth its need to be replaced
place 5-10 paper and check for prints if it’s picked properly
Nov 08, 2009 | HP LaserJet 1100 Printer
Unwanted gray stripes on paper
Printer needs a good clean and service.
Toner particles have probably split onto the fuser drum or has been contaminated by previously printed paper losing some toner.
As the particles get re-heated, they become waxy and smear around the drums and rollers.
For stripping and cleaning procedure, check the FIXYA manuals and tips, searching for your model, or similar one, or try a manuals download website and enter your make & model.
HP may also have the info.
You'll probably need a service manual rather than the user manual.
Nov 20, 2017 | HP LaserJet 5si mopier Printer
Want a B&W copy from colored sheet of paper w/o dark background.
It's never going to be perfect (unless the background is quite light in colour), because the copier basically "sees" the coloured background as "gray", and the darker the background the more "gray" it looks. Try setting the original type to "photo" mode, and then adjusting the exposure a little lighter/darker....that's all you can basically do.
Mar 25, 2009 | Canon imageRUNNER C5180 Color Copier
Jam in top cover area
Replace your paper pickups and set your paper tray setting correct, both in the tray and the settings menu. That should help you out. The part# for paper-pickups is RF5-3739.
Mar 17, 2009 | HP LaserJet 4600dn Color Printer
My HP 2900n is turning the white paper gray on everything. How do you clean the roller?
Check the Density settings first and might as well check Brightness and Contrast.
Oct 13, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
91 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
