Question about Acer Aspire 5100 Notebook
Sound problem with using aim vid
The sound crackles like fireworks, and then robotic sounds like an untuned radio.. sometimes gets feedback where can hear ourselves
laptop is... aspire 5315 -2077
  • threemontys Jan 30, 2008
    the problem is there with the mic off and we have tried everything concerning volume changes
  • 145 Answers
Does adjusting your volume help at all? I find if your microphone is up too high it can have undesirable effects. Also you may want to try to see if the problem is there with the microphone off. Also you should check for any driver updates for your soundcard. You can do this thru device manager in most circumstances. Let us know how it goes.
Posted on Jan 30, 2008
  • Patrick  Haines
    Patrick Haines Jan 30, 2008
    What soundcard do you have? If its built on then what motherboard
2013 c max crackling sound than radio shuts down turn engine off for awhile and radio sometimes goes back on crackling noise sometimes with radio off
I suggest you get one of those manuals people get nowadays to do it yourself.. My nephew use it to repair my car and it's totally repaired now. Here's the website www.reliable-store.com
May 31, 2018 | Cars & Trucks
The sound on my Dell W4200 is crackling some times even when the sound is on mute. Sometimes the sound is fine, other times no sound and other times the crackling noise. Any idea what problem may be?
Hi There,
Crackling sound is often an indication of bad connections to the speakers. Are you listening with the built-in speakers or through an external amplifier?
If you are listening through an external amplifier or speakers, check all of the connections to make sure the cables are properly inserted, and wiggle the cables from each end and the middle to see if that reproduces the symptoms. Sometimes a cable can become damaged from being squashed or bent, and it may be as simple as replacing the faulty cable with a new one.
If you are listening with the built-in speakers the situation might be harder to identify and correct. Sometimes it is as simple as nearby wireless devices or radio towers causing interference with the speaker. You can try repositioning wireless devices such as computer routers, cordless landline phones or radios to see if that helps.
However, over time the solder used to connect the internal components can wear and sometimes break the connection. For this type of situation repair is usually the only option. If the warranty of your TV has expired you may have to take it to a local TV service center. Typically a loose solder joint is easy to identify and fix, so the repair bill should not be high.
Please post back with your results.
May 26, 2011 | Dell W4200 42 in. HD-Ready Plasma...
Bose radio comes on but no sound in my 2004 chevy avalanche.Sometimes even with radio off you hear a popping sound come from speakers. thanks
First Visually check all your fuses. Does rig have amp for stereo by any chance? It sounds like amp is bad and/or fuse is blown. Amp is wired between radio and speakers, and a shorted amp would make crackling in speakers when radio is OFF
Feb 26, 2011 | 2004 Chevrolet Avalanche
The speakers in my 2003 Honda Accord do not always work. They tend to work better when it is cool and/or damp. Sometimes I will hear a loud crackle and then they shut off...if I turn the on/off button off...
You need a new Radio,these year's all go out in time,no sound,can't be fixed,must replace like the Honda Dealer says and no radio shops do repair's these days,they just want to sell you a new one,don't buy a used one,best to go to a radio shop and have them install a new Kenwwod,buying one from the dealer is wasting your money cause it will go bad again.
May 04, 2017 | Car Audio & Video
Cd player works but not radio
No, it uses the same source.
Have you checked which band you are selecting? It has 3 FM bands, LW and MW, right?
It may not be a relay, but an untuned station.
Aug 19, 2009 | Sony CDX-GT210 CD Player
Ipod Classic 120GB video problem
where did you get the vids from. it sounds like the codec used for the vid is not ipod compatable. you may be able to convert them using free software like anyvideo converter or ipod robot. i tunes can play them because it has a greater library of video codecs (anything installed on the system... almost)
Aug 14, 2009 | Apple iPod MA446LL/A MP3 Player
Crackling Noise
I can't take credit for this because on found on a review on Amazon.Com, but I tried it and it works!
"Another update, for everyone who is having the common crackling problem, if you open the clock radio there is a black disk on the bottom with a red and black wire coming out of it. This black disk is a component called a piezo disk. They are commonly used to make noise for buzzers in electronic devices, but appear to have no use whatsoever in this clock radio. If you cut the wires going to this disk, the crackling noise goes away. You can still use both buzzer and radio alarms. There doesn't appear to be any functionality lost other than the annoying crackling sound. Obviously cutting wires would probably void your warranty, but do you really want to try your luck with another RCA clock radio? Chances are the crackling will happen again with the replacement or it will be DOA."
If you can handle a screwdriver and a pair of scissors, you can easily tackle this project, don't be worried about it being too complex. 5 screws, a snip, and you are all set. Make sure the radio is unplugged of course.
Sep 17, 2008 | RCA RP5430 Clock Radio
Soundstick problem
POSSIBLY YOU PLUGGED YOUR SPEAKER ON A WRONG HOLE, PLEASE RECHECK.. GIVE ME FEEDBACK IF THIS HELPED.
Sep 05, 2008 | Harman Kardon SoundSticks Computer...
Acer Aspire 5100 Notebook Logo
196 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
