Related Tags:
This problem should be removed because:
Problem with Jacuzzi BK37959 White Era?? Two-Piece Elongated Toilet BK37
What is the proper way to stack wax rings? I hear
What is the proper way to stack wax rings on a toilet ? I hear that you should place the wax ring with the plastic sleave on top and some say to place it on the bottom. I just wish that the oversized ring would have worked. Do they make a supersized wax ring???
Solutions (1)
Best Solution
You place the plastic sleeve down toward the drain. If that does not seal due to the floor being higher than the drain mount simply add another wax ring minus the plastic sleeve. You can buy wax rings that do not have the plastic sleeve. In lots of cases you have to use 2 wax rings to get a good seal. Make sure you securely tighten the toilet down.
Testimonial: "Thank you for the advice."
no toilet flange
I thought I would install a new elongated toilet after remodeling the bathroom. old toilet did not leak but was small and outdated. To my...
Toilet on uneven floor
I installed a new toilet on our newly tiled floor in the basement. It started to leak after 3 months. Ther is a 4" pvc drain that lays...
tiled bathroom floor. Went to install toilet
tiled bathroom floor. Went to install toilet (new)..wax ring didn't compress like I thought it should, actually didn't feel like...
Leaks at the closet flange
Leaks at the closet flange and we tried many different wax rings.
Add Your Solution
toilet tank fills slowly
tank fills completely but takes too long. it filled much quicker for a long time after installation.
instillation booklet on jacuzzi toilet. toilet did
instillation booklet on jacuzzi toilet. toilet did not come with instilation booklet or hardwear. where can I find this
I need a flapper for a Jacuzzi Era toilet, where
I need a flapper for a Jacuzzi Era toilet, where can I get one?
our toilet does not fill all the way up in the
our toilet does not fill all the way up in the bowl anymore, it barely fills the hole what can i do to fix this?
I would like to replace
I would like to replace the valve and flapper on my Jacuzzi BK37959 ERA toilet. Have been unable to find parts. Any...
See all Jacuzzi BK37959 White Era?? Two-Piece Elongated Problems
Fix-O-Meter
293
293 people viewed this problem
- 2 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Jacuzzi Toilet Hardware Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
