Question about Tomtom GO 510 GPS Receiver
GPS Won't Turn On
Our TomTom has been working fine for the past four months. However, last week I arrived at a destination and when I was ready to return home, the GPS would not turn on. When I have it plugged into the car, the green light at the top next to the on/off button is illuminated, but there is nothing on the screen. I've tried the reset button, but that did not work. I'm hoping there's an easier solution than sending it in for repairs which could take weeks. Any ideas? Could it be the battery? Thanks! i went to switch my tom tom on and it would not work. i tried to reset and even tried to see if the chip was not in properly but it would not work. it is showing a orange screen with the tom tom picture. please what do i do as i rely on it to get me about Funmi TomTom One XL Purchased it new was able to set the unit up and go through the set up process. Turned the unit off for no more than a day. I have tried turning it back on, the green light comes on when plugged into charger, still have the same problem of not turning on when charging. Tried reseting the unit and still no success, Please help. Have the same problem. Just purchased Tomtom 520 on 19/1/08. Used a week ago and worked fine. Went to use today. Switched on unit, plugged in car charger and started car. Unit switched off then on when car started. Set directions and pulled away. Went a few yards when unit switched off then on again then died. Been dead ever since. Will not switch on. Have tried reset several times to no effect. Tried recharging via computer again no effect although green charging light glows.
  • 3 more comments
  • LauraRN Feb 05, 2008
    YEP.........same thing with my TomTOm 510.........green light on...nothing on screen..........reset, no luck. Guy at radioshack says its the lithium battery, which is inaccesible - just like an IPOD, only worse. Am waiting for TomTom to respond and will let ya'll know what I find
  • Anonymous Feb 10, 2008
    I have a tom tom one v2 . it will only switch on whem conected to a power supply, but will turn off by the on / off button
  • Anonymous Feb 11, 2008
    My Tom Tom battery was low in the car. The unit screen turned off although there was some battery life remaining. Then keeping it pluged into the car outlet the green light wouldn't even illuminate. Then I plugged it into the house wall outlet. The green light and screen illuminated. I left it on and also recharged it. Hours later the screen went blank and no green light. I couldn't turn it on. I hit the reset button. I plugged it into the wall outlet. The green light illuminated but the screen will not illuminate. What do I do?
  • Jean Ager
    Jean Ager Feb 28, 2008
    I have a similar problem with a TomTom Go-510. It is a refurbished unit. It worked the first day, Then, after it was turned off for a couple hours, I was unable to turn it back on. I recharged and re-set. It worked another day correctly. Then, after I plugged the unit into my computer and added a route, the unit stopped functioning again. It turns to the video which instructs not to remove the card, and this repeats again and again. I've tried re-setting and have had no luck.
  • Sneasy Mar 01, 2009
    I have the same problem. I guess Tom Toms sit in the stores to long. My battery lasted around 6 months. They do have a 2 year warranty, but i rather change it myself. Thanks to LauraRN for the help. I just order it, but i'm sure this will repair it. When i leave it on the home charger and will come on hours later. Then i notice the low battery warning on. Thanks again for FixYa
My 510 was doing the exact same thing.
I called customer support and they helped me get it working again.
866-486-6866 is the number but here is what they had me do.
I had to push down the reset button for 15 seconds (the reset is in a small cut out near where you plug in the charger on the bottom.you will need to use a pin and you will feel the pin push in the button if you have it in the right spot.)
Then release the reset and hold down the power button for 10-15 seconds. the screen should come right back on.
If you need more help I suggest calling the 866# they are very helpful.
Posted on Mar 13, 2008
Www.batteryship.com
look up tomtom 510 - or whatever model you have
Order the battery..........comes with manual and tools to fix it
only 20.95
it works
cheaper than sending it in!!!!!!
These are genuine replacement parts!!
Laura
Posted on Feb 05, 2008
My newly bought tomtom one 140s has given me inaccurate directions.the location was on the leftside of the street but the gps pointing the opposite ,and one time i arrived already to my destination but the...
This is a very common problem with ANY brand of GPS. Even if you have the most current and updated map, there are some mistakes in the GPS addresses. It should only happen occasionally, maybe once every couple of weeks. As I said before, it's not unheard of for TomTom, Garmin, Magellan or any bradn of GPS
Mar 20, 2010 | Tomtom ONE GPS Receiver
Big Red Blinking 'X', device stops working
Don't throw it away, what you need to do is go to the Tom Tom side and reload the software as it is corrupt, the X seems to be a common problem with some models
Feb 16, 2010 | Tomtom GO 910 GPS Receiver
Tomtom One not doesn't calculate arrival time correctly.
thats normal- estimate is always higher the units go by speed limits and you shave time off trip units adjust accordingly
May 18, 2017 | Tomtom One XL GPS Receiver
GPS Won't Turn On
dude check it the car charger really isnt a chargers. what! i kno i kno. the '' proper" way of chargin ur battery is thru the computer or u can purchase a a/c to usb adapter and charge it on the wall but the car charger is a trickle charge as long as the green light is coming on that means that there is power going to it and support is going to just tell ur charge the batter the right way over and over again try charging on the computer for about four hrs then see whats up if its still not working then call tech support and make sure u tell them that u tried charging it on the computer for four hrs
Jan 19, 2009 | Tomtom ONE GPS Receiver
In the last week I have bought 2 tomtom ones. one was a 125 the other a 130. Both have given me the same problem. On arrival of my destination it is taking me anywhere from 1/8 mile to 1/2 mile away from...
First thing to check is make sure your maps are up to date. Run your device through TomTom Home and make the proper updates. 1/2 a mile away seems too far of a distance to be off by. I've taken trips on my TomTom and even other brands for that matter, and it is not unusual to be slightly off or announce the arrival a few hundred feet too early. If it is navigating you to the wrong street, you need to update your maps. The maps are very reliable on my device so use that as a starting point.
Dec 06, 2008 | Tomtom ONE 130 GPS Receiver
I purchased my TomTom One XL.S4Aug08. I am finding that the unit will not hold a charge. I took a trip some 200 miles away gtom home and plugged the unit into the 12 volt and system. It work OK while...
I am sending the tomtom back to the manufacturer. I have only had it for two (2) months. I didn't feel that I should have to pay to have it fixed. thanks for your reply.
Bob
Sep 17, 2008 | Tomtom ONE GPS Receiver
GPS Won't Turn On
If its a battery problem the unit still works while charging!
If not it sounds like the OS or SD card has become corrupt.
you'll have to wipe both clean & start again...
tomtom will talk you through this either via an email or on the phone.
http://www.tomtom.com/support/support.php?ID=2
Dec 11, 2007 | Tomtom ONE GPS Receiver
GPS Won't Turn On
I suggest any unit under warranty to be returned to its supplier or if they will not help, contact tomtom directly!
http://www.tomtom.com/support/index.php?Lid=1
Download the latest updates from tomtom.
Dec 03, 2007 | Tomtom GO 300 GPS Receiver
Tomtom - time of arrival
It is possible that you have the TomTom set for "walking routes" or "bicycle routes" or "limited speed." (I have a TomTom One 3rd edition, so if you have a different model the menus/icons may be different, but it's worth a shot.)
Click on the main part of the screen, while on the main navigation screen. Then click on "Change preferences." Then click the blue arrow to scroll to the Preferences 3 of 5 page. Click on "Planning preferences." Choose the planning preferences that you want. Hope this helps...
Nov 11, 2007 | Tomtom ONE GPS Receiver
GPS Won't Turn On
Amazing what reading through the support page at TOMTOM reveals... I have the XL so no SD card to remove, but the support page explains that a hard reset by holding the power button takes 15 SECONDS. That's actually a really long time if you watch a clock. I pressed it and waited it out, and it worked. Powered right up. Not sure if I lost all my favorites and stuff but I have them backed up using TomTom Home anyway....
Dec 19, 2006 | Tomtom ONE GPS Receiver
GPS Logo
620 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
