Hp deskjet 5150 just replaced both inks...black fading out secound time i used for printing page.....? just took out and put back in again.... same deal....i did a test page and colors seem well but black is noty coming out only faded
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
The claim here that "most manufacturers build logic into their products...to precvent problems from contaminated inks, etc." is bogus. The manufacturers do everything in their power to make it difficult for the consumer to use refilled ink in order to force the consumer to have to buy only new, overpriced cartridges. Remember: printer manufacturers are in the ink business, not the printer business.
Stop being moronic. Mfgs. build code (logic) into the printer's driver (for ink printers to know how much ink is still in the reservoir of the printer. This logic also tracks the print pulses fr a cartridges which sets a counter which in turn tells the driver when the cartridge is empty. That sets a bit that tells the system the cartridge is empty.
When you refill the cartridge and don't reset that bit, all the printer knows is that the cartridges is empty.
By the way, it is actually quality control that drives supporting a companies own cartridges. Profit is taken to recoup some of the R
