Question about Canon PC-860 Black and White Copier
Canon PC-860 Black & White
My Canon PC-860 Black & White Photocopier won't print properly after a paper jam.....the copies are almost invisible. This has happened before and each time was rectified by gently brushing the roller. I've tried this this time but to no avail. ....And why does this happen every time paper gets jammed ?...It's infuriating ! Help, please ! Thanks
  • judy2shoes Feb 02, 2008
    Hi rrralf
    My temperamental machine has fixed itself ! I believe it may have been a static problem. We kept brushing the roller and testing copy after copy, and then just suddenly the print returned to normal. Thank you for your input.
Posted on Aug 21, 2008
    Problem Solver:
  • 18 Answers
Maybe your transfer roller is shorting, not allowing image transfer from drum to paper. when you run a copier and stop it during process, is there a good , strong image on the drum. If so, either remove transfer roller, and blow it off good with a compressor air (STRONG PRESSURE) or blow it off in the copier. This may work. let me know. Sounds as tho electrical grid or image transfer problem.
Posted on Jan 31, 2008
  • rrralf Feb 03, 2008
    sounds similar to what i said,if theres a short in transfer, it will cause what you said. by the way, i,m 25 years my own business, not a rookie.
I want to ask if there is way to print someting on greeting card, wiyh the canon PC860?
there is no way to print on greeting card.
use century paper to print then make greeting card.
Nov 04, 2011 | Canon PC-860 Black and White Copier
Won't photocopy / warning light flashing /
The paper feed system is worn (rollers, and separation pad). What is happening, is extra sheets are being fed into the machine primarily because the separation unit is not doing it's job properly. So rather than just one page at a time being fed, it is allowing an extra sheet to "creep" in intermittently, causing the jam. And the indicator you are seeing is the "jam" indicator.
Jul 16, 2009 | Canon PC170 Copier
Canon FC 120 Photocopier. Red Paper jam light keeps flashing
hi,clean any sensor & clear any hide misfeed sheet.send me result.
thank you.
May 31, 2009 | Canon PC-160 Black and White Copier
My copy machine will just print a totally black sheet of paper.
Pull out your toner cartridge, push back the drum shutter and see if the drum is coated in toner. If so, it is defective. Replace it and it will be fine.
*please rate me ;)
Mar 21, 2009 | Canon PC-860 Black and White Copier
Jammed Paper - Canon PC860
You are almont there .There is also 2 clips that release the presure on the sides of the fuser to release the presure on the roller and remove the paper.
Jan 23, 2009 | Canon PC-860 Black and White Copier
Error message
You may check wether one of the sensors from the paper path is not blocked or broken! if everything looks fine and there is no paper inside it might be a more seroius problem! no reset button for this kind of proiblem!
Nov 16, 2008 | Canon PC-860 Black and White Copier
Canon PC860 - Paper Jam resulted in black horizontal lines in subseq.copies
If the blank ink still cames in the printer means that their still ink inside the cartridge, kindly check if there are papers left inside the printer when it was removed if there is you have to take it off.
Turn off the printer, delete the remaining files that is to printed on the printer dialog box by just double clicking the icon found at the bottom of the task bar.
Turn on the power of the printer, have a printer test to test if the pritned copy is good. Clean the head, or the nozzle of the printer at the maintenance tab.
If the problem still arises means the head align was damage or mess align that happend when the paper was remove forcely.
That's all
Thank you.
Nov 10, 2008 | Canon PC-860 Black and White Copier
Canon PC-860 Black and White Copier Logo
215 people viewed this question
old marine
old marine
