Question about HP 4250 Monochrome LaserJet Printer
Printer 4250n no print
Printer 4250 prints only logo , I have changed toner and fusor and print the same
What do you mean by logo? Do you mean the Menu Page?
Posted on Jan 30, 2008
I have a HP Laserjet 4250 that is printing dirty prints. I have replaced the toner and the fuser unit and cannot correct the problem. I have 2 of these printers and the toner and fuser unit works no...
Try printing from the manual feed tray(tray 1). Put a few sheets of paper in the tray. Print anything that is more than two or three sheets of paper. The paper path test is good, 10 sheets. As the paper gets about halfway into the printer, open the top door. Pull out the toner cartridge. Look down at the paper. If it's dirty it has to be the toner or the transfer roller. If it's clean it could be a dirty paper path or fuser.
Vacuum out the printer, if you have mounds of toner laying in the paper path, everything that comes out of the printer will be dirty.
Aug 02, 2010 | HP LaserJet 4250n Printer
Hp laserjet 4250 prints 2 copies when using excel
Go into the print properties in Excel by clicking on Page Setup on the File menu, then hit Options. Next to "Copies," change it to "1" and hit OK.
Oct 08, 2009 | HP LaserJet 4250n Printer
The print comes out light
Make sure you are using an OEM toner not a refurb or compatibly cartridge. If the problem persist your toner is not getting enough voltage or your laser is dirty. Check all contacts and transfer roller(which sits under your toner cartridge)make sure it rotates. You can also raise your toner density level in your configuration menu and make sure you pull your toner strip out of your toner cartridge. If the problem still persist I recommend a service tech.
Apr 06, 2009 | HP LaserJet 4250n Printer
Using XP sp2, excel 2000 and HP 4250 printer. Any
The print settings can be different for different programs. Open Excel and in the File menu, choose Page Setup. Click on Options, and towards the bottom is a setting that says Copies. Change this to "1" and hit OK, and you should be fine.
Hope that helps!
Mar 09, 2009 | HP LaserJet 4250n Printer
Printing 2 copies
Please print a configuration page and let me know if that prints 2 copies as well, If yes,
within the menu, go to configure device > printing > copies, change the copies to 1
Let me know the next update.
Oct 29, 2008 | HP LaserJet 4250n Printer
Hp laserjet 4250
try this
1.when the printer start print turn off the printer after the paper go on side the printer to make paper jam
2.open the printer and pickup the paper out slowly
3.see the print area on the paper if the black par appears on the paper that mean the drum unit faulty if not the fusser unit faulty
May 14, 2008 | HP LaserJet 4250n Printer
HP 4250 DN
Change the tray one behavior from the front panels paper handling menu. from there you can tell tray 1 to print first if paper is present or default to tray 2.
factory settings are to print from tray 2.
are you keeping paper in both trays??
Mar 28, 2008 | HP LaserJet 4250n Printer
Hp 4250 GHOSTING
Are you telling the machine that paper type is letter head or envelopes, It must be done, it changes temp of fuser to suit the paper type, no it is not a power supply problem change paper type to card stock/thick/letterhead etc to suit then machine will adjust temp to suit.. ie file, print properties paper type.
50.2 fuser error replace fuser.
Dec 06, 2007 | HP LaserJet 4250n Printer
HP 4250 Monochrome LaserJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
